Discus B Pilot Size
Old July 11th 17, 12:07 PM posted to rec.aviation.soaring
Default Discus B Pilot Size
Looking at the Discus B's for sale on W&W. Before I drive out to look at them, can anyone tell me what size pilots will fit in them?
Don't want to make the trip only to find out I don't fit!
Old July 11th 17, 02:11 PM posted to rec.aviation.soaring
I had one back in the 1980's, and flew it in 2 WGCs. I'm 6'2" and about 200 Lbs plus chute. Comfort was fine with the seat back removed, but due to sitting so far back, the rearward visibility was limited by the fuselage and canopy frame. This caused me issues with situational awareness in the huge 50+ glider WGC gaggles. To help with rearward visibility, I installed 2 round convex mirrors ( about 2" diameter ) on either side of the instrument panel glareshield. This helped, but with the disclaimer that if I could see a small glider in the mirror, it meant that someone was really close under or behind me. Maybe this situation is now better with FLARM, but the mirrors will still help if you plan on flying along with any other gliders.
RO
Old July 11th 17, 03:29 PM posted to rec.aviation.soaring
Clay[_4_]
I'm 6'5" 220 lbs. 34" inseam. Fit pretty well with seat back out. Tight in hip area if I wear jeans, thinner material pants solve that problem. Try to get your chute packer to taper it, making it thicker up top, that helps a little with problem RO describes.
Discus 2a cockpit size EdByars Soaring 1 March 18th 10 03:37 AM
Discus 2a cockpit size Stephen[_3_] Soaring 7 March 17th 10 05:57 PM
Discus verus Discus 2, LS8, ASW 28 Roger Soaring 45 October 31st 06 03:43 PM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
