Angle of incidence
After speaking with an instructor about my Pilatus B4 landings, he argued that
the angle of incidence on this glider has a great influence on the landing characteristics. I looked it up, and it was only 1.5 degrees. With the tailplane oriented at -3 degrees. However, I cannot figure out what other gliders have as the angle of incidence. I have 6 degrees in my head somehow, but I'm not sure where I get this from. Searching on Google does not give me figures, only stories about changing it (from Ls6 to Ls8 for example). I'm therefor wondering: can you tell me the angle of incidence on your glider if you know it? And how does it effect take-off and landing characteristics? For example: some people in my club argue that the Discus2 take-off characteristics are also to be blamed on its angle of incidence. regards, Roel |
Angle of incidence
On May 27, 11:21*pm, Roel Baardman wrote:
After speaking with an instructor about my Pilatus B4 landings, he argued that the angle of incidence on this glider has a great influence on the landing characteristics. I looked it up, and it was only 1.5 degrees. With the tailplane oriented at -3 degrees. However, I cannot figure out what other gliders have as the angle of incidence. I have 6 degrees in my head somehow, but I'm not sure where I get this from. Searching on Google does not give me figures, only stories about changing it (from Ls6 to Ls8 for example). I'm therefor wondering: can you tell me the angle of incidence on your glider if you know it? And how does it effect take-off and landing characteristics? For example: some people in my club argue that the Discus2 take-off characteristics are also to be blamed on its angle of incidence. regards, Roel Roel, According to the manual for my Mini Nimbus C the wing incidence is .7 deg and the tail incidence is 0 deg set to the rear fuse center line. I use to rent a B4 and found it to be a nice handling sailplane, never had a problem with landings. Mike |
Angle of incidence
On Monday, May 28, 2012 1:21:35 AM UTC-4, Roel Baardman wrote:
After speaking with an instructor about my Pilatus B4 landings, he argued that the angle of incidence on this glider has a great influence on the landing characteristics. I looked it up, and it was only 1.5 degrees. With the tailplane oriented at -3 degrees. However, I cannot figure out what other gliders have as the angle of incidence. I have 6 degrees in my head somehow, but I'm not sure where I get this from. Searching on Google does not give me figures, only stories about changing it (from Ls6 to Ls8 for example). I'm therefor wondering: can you tell me the angle of incidence on your glider if you know it? And how does it effect take-off and landing characteristics? For example: some people in my club argue that the Discus2 take-off characteristics are also to be blamed on its angle of incidence. regards, Roel What exactly is your problem with your landings in the B4? I remember flying the B4 our club had and it was one of the most benign and dorcile gliders to land. Uli |
Angle of incidence
On May 28, 12:21*am, Roel Baardman wrote:
After speaking with an instructor about my Pilatus B4 landings, he argued that the angle of incidence on this glider has a great influence on the landing characteristics. I looked it up, and it was only 1.5 degrees. With the tailplane oriented at -3 degrees. However, I cannot figure out what other gliders have as the angle of incidence. I have 6 degrees in my head somehow, but I'm not sure where I get this from. Searching on Google does not give me figures, only stories about changing it (from Ls6 to Ls8 for example). I'm therefor wondering: can you tell me the angle of incidence on your glider if you know it? And how does it effect take-off and landing characteristics? For example: some people in my club argue that the Discus2 take-off characteristics are also to be blamed on its angle of incidence. regards, Roel Angle of incidence does vary from glider to glider, and it's a useful point to note when making transitions to new gliders. Trainers like the ASK21 have a fairly high angle of incidence. Duos and standard class gliders have much lower angle of incidence, the latest (28, D2) especially. That, along with c.g. much further behind the main gear, is worth reflecting on and preparing for in a transition. Low angle of incidence in unflapped gliders means the fuselage is more aligned with the airflow at high speeds. Good for high speed performance, but it means that the nose points way up to achieve a high angle of attack at low speed. They can't achieve a stalling angle of attack even with the tail wheel on the ground. Thus, they have to take off at substantially higher airspeeds. There is a tendency to roll down the runway forever on the first few flights. One answer is to take off with the fuselage at a much higher pitch attitude in order to produce the same angle of attack at takeoff. Similarly, If you land close to a stall you will hit the tail wheel first and then plop down on the main. That's also why the nose is very high on tow and while thermaling. Some pilots find themselves thermaling at too high speeds early in the transition. Part of the reason is that the nose needs to be much higher on the horizon at thermaling angles of attack. If you put the nose at the ASK21 pitch attitude, the duo or a standard class glider will be screaming along. It's also useful to note that where the nose is pointing is not where the glider is going. That's what's going on with the feeling that the nose is high on takeoff, tow, and thermaling -- the nose is pointing up though the glider is gliding down. The converse issue happens at high speed. The wings are very efficient at high speed, so putting the nose down and pointing at the runway just means you speed up to 90 knots and keep going flat. Glider looks like this: (moving left to right) \ \ \ . That's part of the feeling that "spoilers don't work." No, you're not using them! To an eyeball approximation, the glide angle is always the same, but pointing the nose up or down just changes the airspeed. More than you asked for, but I've learned a lot about these sight angles while helping new pilots transition to our duo discus and asw24 lately John Cochrane |
Angle of incidence
On Sunday, May 27, 2012 10:21:35 PM UTC-7, Roel Baardman wrote:
After speaking with an instructor about my Pilatus B4 landings, he argued that the angle of incidence on this glider has a great influence on the landing characteristics. I looked it up, and it was only 1.5 degrees. With the tailplane oriented at -3 degrees. However, I cannot figure out what other gliders have as the angle of incidence. I have 6 degrees in my head somehow, but I'm not sure where I get this from. Searching on Google does not give me figures, only stories about changing it (from Ls6 to Ls8 for example). I'm therefor wondering: can you tell me the angle of incidence on your glider if you know it? And how does it effect take-off and landing characteristics? For example: some people in my club argue that the Discus2 take-off characteristics are also to be blamed on its angle of incidence. regards, Roel I remember a long final glide that I made with a friend (both flying LS-6's). We were dead even, flying best L/D, we had to make it over a lake with enough altitude to clear the ridge. After a few minutes my buddy said; "Watch this" and slowly, but surely, he started gaining altitude on me. After 10 miles he was a good 50 feet above me. So, I asked, "OK, what did you do"? He replied, I went to one notch of positive flap. Why did that work? Because the wing on the LS-6 is attached at zero incidence so as to make the fuselage align with the relative wind when flying fast, but at best L/D, the nose was up and selecting +1 flaps brought the nose down a tat and alighned it better into the relative wind. Good trick to remember. JJ JJ |
[quote=Mike C;815406]On May 27, 11:21*pm, Roel Baardman wrote:
After speaking with an instructor about my Pilatus B4 landings, he argued that the angle of incidence on this glider has a great influence on the landing characteristics. I looked it up, and it was only 1.5 degrees. With the tailplane oriented at -3 degrees. However, I cannot figure out what other gliders have as the angle of incidence. I have 6 degrees in my head somehow, but I'm not sure where I get this from. Searching on Google does not give me figures, only stories about changing it (from Ls6 to Ls8 for example). I'm therefor wondering: can you tell me the angle of incidence on your glider if you know it? And how does it effect take-off and landing characteristics? For example: some people in my club argue that the Discus2 take-off characteristics are also to be blamed on its angle of incidence. regards, Roel I would be interested in exactly what problems you are encountering on landing. I am interested in the Pilatus B-4 for its aerobatic capabilities. While it would not necessarily be a good cross country airplane, cross country does not interest me all that much. Having read the B-4 manual I was surprised to see that it did not discuss the landing process to any degree. I fly a SGS 1-34 which recommends a high energy landing and the manual specifically recommends against landings resulting in a tail first or tail strike landing. Somewhat nonintuitive for someone trained in powered taildraggers recommending a full stall, three point type landing in otherwise non windy conditions. Essentially the 1-34 is flown onto the ground and then flown to a stop as mentioned in the manual. I had the good fortune to talk to several pilots with extensive experience in the 1-34 prior to flying it. I would think this would always be advisable as we transition into other aircraft. Walt |
Angle of incidence
First of all: thanks for all the replies!
I find it incredibly interesting to ponder about these subjects, so more info is better :-) I also like the Ls-6 story! My tendency with the B4 is to approach with too much velocity, often 100 km/h. This gives me the feeling I have proper aileron control, so it's intentional. When I approach the deck and slowly start to bring the nose up, I encounter the ground effect that the B4 has. I either float for a long time before touching down with a two-point landing, or I make a touchdown on the main wheel only (sometimes with a slight jump after that). What happened yesterday, was that I was so busy compensating for crosswind (I don't want to have a traversed landing), that started floating again and gained some altitude (1 meter roughly). Knowing that the fault is probably in the velocity, I approached the instructor to learn from his B4 experience. I agree that the B4 is very friendly and benign. I will put effort in bringing my approach speed down to 90 in the upcoming flights. |
Angle of incidence
On May 28, 11:16*am, Roel Baardman wrote:
First of all: thanks for all the replies! I find it incredibly interesting to ponder about these subjects, so more info is better :-) I also like the Ls-6 story! My tendency with the B4 is to approach with too much velocity, often 100 km/h. This gives me the feeling I have proper aileron control, so it's intentional. When I approach the deck and slowly start to bring the nose up, I encounter the ground effect that the B4 has. I either float for a long time before touching down with a two-point landing, or I make a touchdown on the main wheel only (sometimes with a slight jump after that). What happened yesterday, was that I was so busy compensating for crosswind (I don't want to have a traversed landing), that started floating again and gained some altitude (1 meter roughly). Knowing that the fault is probably in the velocity, I approached the instructor to learn from his B4 experience. I agree that the B4 is very friendly and benign. I will put effort in bringing my approach speed down to 90 in the upcoming flights. Slightly too much airspeed at the start of the flare will have a large effect on float distance. The big culprit is ground effect which can as much as double the glider's L/D just as you are trying to land making it hard to get rid of that extra airspeed. I choose a small airspeed increment over the yellow triangle according to the gustiness of the day and use that for my "over the fence" (OTF) airspeed. In the pattern, I'll use whatever airspeed give me a good gust-stall margin then slow down to the "OTF" airspeed on short final. |
Angle of incidence
Hi Walt,
Although my opening post starts with the B4 and landing, this does not mean it's tough to land. Not at all. I have a tendency to fly fast on final, and the ground effect of the B4 makes it float when I do that. In my experience it is a great glider to fly. I can compare it with an ASK-23 and SZD Junior, both being gliders which are flown by pilots with some solo starts. In fact, the B4 has been used for this purpose in The Netherlands in the past. The glider is generally responsive and very friendly. Pitch is somewhat sensitive, but nothing you can't get used to. The same applies for rudder control. On my first flights I tended to put too much rudder in during thermaling. In terms of aerobatics I think the glider is a nice follow-up for the ASK-21 (on which I learned to fly aerobatics). The pitch-sensitivity requires more precise inputs during rolls. Also since the rudder is so effective, you can actually stall the rudder when flying knife-edge at 3/4 of the roll. After some practice I could do very nice rolls without having to pitch up 20 degrees. Stall-turns are not hard, especially if you side-slip a little on the vertical line up. It warns before you spin (I can hear the airflow get turbulent over my wings, and there's a *shoop* when it drops), the spin rotates quickly but can be stopped in 1/4 turn with rudder and then forward-stick. The glider then swiftly drops to 90 degrees down. Pretty perfect for competitions I would say. Tailslides have a tendency to drop canopy-down/wheel-up (due to the wing-profile I was told), so you should keep those a little positive if you want to drop canopy-up/wheel-down. I have tried inverted spinning, but am not sure how stalled the glider was during this maneuver. It can perform the figure though. I haven't tried snap-rolls, since I hear this will make the rivets in the tail pop and give the tail play. I have some videos with flights from start (tow) until landing. Drop me an e-mail if you're interested. Roel |
Angle of incidence
2cents from a partially reformed sinner...
I learned to fly in Bergfalkes that have all the penetration of a well thrown tissue. So I learned to approach with lots of speed - because it will disappear fast once the nose comes up, and because any lack will have you running out of energy very fast. Transition to a big, heavy, slippery single and there is still the tendency to want an extra few kt on the dial - and then it floats forever in ground effect. Have learned to bring the big Kestrel in a lot slower and the landings are a lot less exciting. Still have a way to go. She can be landed in an incredibly short distance if you have that approach speed nailed. In my case the magic number is 45kts - Stall at 32-34Kt *4/3 is 42-45kt. Now that feels just WRONG but in still air it is perfect. At 55kt (90km/h) you are carrying a massive 47% extra energy - that takes a lot of distance to dissipate at 1:40+ - check it - set the logger at 1s intervals, get it all stable at ~2m AGL over the numbers on a long runway an see how long you can keep the wheel off the ground for. Use the traces and try at a couple of approach speeds to see what your achieved L/D is in landing configuration. At 55kt the Kestrel is still in the air 100m later - and that is with landing flap and half airbrakes. At low speed the ailerons are less powerful, but a little airbrake increases effectiveness by diverting airflow over the controls so you should have more than enough control - you are trying to fly straight - not do aerobatics. On 2012/05/29 3:55 AM, Bill D wrote: On May 28, 11:16 am, Roel wrote: First of all: thanks for all the replies! I find it incredibly interesting to ponder about these subjects, so more info is better :-) I also like the Ls-6 story! My tendency with the B4 is to approach with too much velocity, often 100 km/h. This gives me the feeling I have proper aileron control, so it's intentional. When I approach the deck and slowly start to bring the nose up, I encounter the ground effect that the B4 has. I either float for a long time before touching down with a two-point landing, or I make a touchdown on the main wheel only (sometimes with a slight jump after that). What happened yesterday, was that I was so busy compensating for crosswind (I don't want to have a traversed landing), that started floating again and gained some altitude (1 meter roughly). Knowing that the fault is probably in the velocity, I approached the instructor to learn from his B4 experience. I agree that the B4 is very friendly and benign. I will put effort in bringing my approach speed down to 90 in the upcoming flights. Slightly too much airspeed at the start of the flare will have a large effect on float distance. The big culprit is ground effect which can as much as double the glider's L/D just as you are trying to land making it hard to get rid of that extra airspeed. I choose a small airspeed increment over the yellow triangle according to the gustiness of the day and use that for my "over the fence" (OTF) airspeed. In the pattern, I'll use whatever airspeed give me a good gust-stall margin then slow down to the "OTF" airspeed on short final. -- Bruce Greeff T59D #1771 |
Similar Threads | ||||
F8 Crusader Variable Incidence Wing | [email protected] | Naval Aviation | 8 | August 18th 09 01:57 AM |
Skybolt Tail Incidence Question | Scott Rodriguez | Home Built | 1 | November 20th 05 07:44 PM |
Skybolt Tail Incidence Question | Scott Rodriguez | Aerobatics | 0 | November 4th 05 04:16 PM |
Another angle... | tongaloa | Home Built | 0 | February 27th 04 11:13 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
