Cobra trailer wiring diagram
FYI: You can purchase a 7-to-4 pin adapter at auto
and RV supply stores. If you have a 7-pin female electrical plug on your car, this will convert it to the American 4-pin plug on many trailers. Rick At 06:42 18 April 2007, wrote: On Apr 17, 10:14 pm, Tuno wrote: Dave, The Cobra site has diagrams for 7-pins and 13-points. My Cobra has a 7- pin blade connector, which according to my on-site engineer says is wired incorrectly compared to the diagram. Has anyone changed the Cobra 7-pin setup to a 4-pin? My last Cobra trailer had a 4-pin flat connector. I'm wondering if I should switch it to that. ~ted/2NO Ted - The Cobra trailer can be ordered with the European standard connector (big round connector with big round pins), or a USA RV common trailer connector (blade pins, round connector). Perhaps yours is the latter ? Is this trailer as new or has it been rewired ? See ya, Dave |
Dave, it's the latter, it came with a "7-way blade" which is round.
I'm the second owner and the first tells me he made no modifications. However my on-site engineer (who goes by "Dad") sent me the following report this morning: snip The problem I had this morning was with the 7/4-pin adapter. That sucker did not have the common wire connected thru from the 4-pin plug to the 7-pin plug. Ordinarily that should not be a problem PROVIDED the trailer is physically hitched to the tow car--the system uses chassis metal for the common return. But I did not have a physical connection this morning, only the electrical connection. This evening, when I jumpered the common lead through from the 4-pin to the 7-pin, everything worked like the factory said it should (but not like that wiring diagram you found on the net this morning). The upper (amber) lamp is the turn signal, the middle (red) lamp is the brake, and the lower (red) is the tail light. So I made the change that Mac described. Removed the lead from the brake lamp and taped it off. Switched the lead from the turn lamp to the brake lamp (in the 4-pin system, that serves as both brake and turn signal). Then I gave it a full test. Tail only, tail and turn, brake only, brake and turn, and brake, tail, and turn. Everyting now works like it should in a 4-pin setup with my van. /snip Thanks to everyone for the feedback on this topic. I'll be prepared for the new trailer this summer! 2NO |
and RV supply stores. If you have a 7-pin female electrical plug on your car, this will convert it to the American 4-pin plug on many trailers. I use two tow vehicles -- a Toyota pickup for some weekends and an RV for others. The pickup has both 7-way blade and 4-way flat. The RV has 6-way round (that's with one in the center). A problem I had (until yesterday) was I could not find a 6-way to 7-way adapter, only 7-way to 6-way (which of course are backwards gendered), so when pulling with the RV I had to use a 6-to-4 and a 4-to-7, which looked like something Rube Goldberg put together. As my engineer reported in my earlier post, there was a problem with the 4-to-7 adapter. He fixed that, and did the rewiring that Marc suggested, now everything works -- with his van at least. 2NO |
Similar Threads | ||||
Wiring diagram for GA radio/mic? | Gary G | General Aviation | 15 | November 23rd 05 03:33 PM |
Wiring diagram for mic? | Gary G | Home Built | 5 | November 3rd 05 03:21 PM |
Wiring diagram for GA mic | Gary G | Piloting | 0 | November 2nd 05 01:15 PM |
looking for Dittel FSG 60M wiring diagram | ken ward | Soaring | 1 | May 29th 05 02:54 AM |
King KMA-26 Wiring Diagram | Keith Dobbins | General Aviation | 0 | August 23rd 03 04:03 AM |
