Scientific Data on Engine Operations
Old July 25th 05, 12:11 AM
Matt Barrow
"Greg Copeland" wrote in message
news
On Fri, 15 Jul 2005 11:27:54 -0700, Michael wrote:
The extra vibration occurs only if you don't have proper fuel
distribution LOP
[snip]
Of course all the piston airliners routinely ran LOP - but it's
important to remember that over the course of its life, the cost of
fuel the engine burns is significantly higher than the cost of the
overhaul - and thus LOP operation, which can easily save 10-15% for the
same power and speed, can be economically advantageous even if it does
measurably shorten engine life.
Michael
This seems like one of the most straight forward and reasonable statements
you've made thus far. That's a good point. A very good point. Have
anything which validates that's the real reason they ran LOP?
Less fuel, cleaner, better internal pressures...all things that make for
BETTER TBO. Some of the airlines were running their radial engines to
3500-4000 hrs between overhauls.
  #32
Old July 29th 05, 04:38 PM
Matt Barrow
"Dan Luke" wrote in message
"Matt Barrow" wrote:
CHRIST-ON-A-BIKE, _why_? It's all HYPE, remember?
Because LOP saves fuel and keeps plugs clean. That much is proven. It
is a fact that lower combustion pressures are also proven - but how
this correlates to long term engine longevity is unknown.
DUH!!! And you're an engineer? HAHAHAHAHAHAH...
Evasion by ad hominem noted.
ALB
Running away noted.
Mental deficiency noted.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Looking for JPI's older software to download engine monitor data to a PC Peter R. Piloting 11 February 14th 05 08:58 PM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
