Earth shattering news for GNSS, commercial availability of Chip ScaleAtomic Clock (CSAC)
Atomic Clock (CSAC) For 1st generation CSAC, amazing: 16 cc volume (1 cu inch) 35 grams weight 115mW of power 4 orders of magnitude better clock stability than typical frequency crystals found in typical GPS receivers, that means that a CSAC will drift in about 3 hours what a typical crystal would drift in a single second. According to the supplier, Symmetricon, this CSAC is already as accurate as a Caesium atomic clock ! So cost seems to be the only bottleneck before this component is everywhere ultra high accuracy is desired. With WAAS receivers costing around US$ 10k, a US$ 200 atomic clock might be an acceptable extra cost. Although it probably costs a more than that right now (no price estimates are to be found). Currently, WAAS enhanced GPS ranging typically have a worst case uncertainty of 7-20 meters due to errors that can't be 100% corrected (ionospheric error, tropospheric error, multipath error and uncorrected GPS ephemeris and clock errors). In order to calculate a position, typical WAAS receivers consider the clock an uncertainty as well, since their internal clocks drift too fast to be considered stable, so they are being constantly corrected with the received signal, with an on board atomic clock, the receiver clock becomes stable enough that they're no longer a full uncertainty, they still need some clock updates, but only when the sky is full of satellites, allowing for a very, very accurate time calculation. So having a CSACs onboard removes the clock uncertainty, requiring one less satellite for any given performance level, so a basic 3d fix with 3 satellites, RAIM navigation with 4 satellites and FDE RAIM with 5 satellites (fault detection and exclusion). With a CSAC onboard, LPV200 approach availability would improve to 99.99% of the time in CONUS, and would become available 98% of the time in places where today it might be available 70 or 80% of the time (Mexico, Caribean, western Alaska). CSACs might also make their way into all DPGS stations, improving their calculated corrections. All current WAAS stations have a standard Rb atomic clock (costs US$ 35000 each, lasting less than 10 yrs), replacing each Rb atomic clock with a triple redundant CSAC facility will save a bundle on WAAS maintenance (with three clocks a single faulty unit can be detected, excluded and marked for replacement without stopping the station). Regular atomic clocks also are temperature sensitive, requiring air conditioning, this CSAC can handle temperatures from -10C to +50C. One interesting improvement to the worldwide aviation network that has been much talked about for a while, but it's still just academic work is the DME pseudolite. Current DME is a low accuracy (550 ft / 0.1 nm) solution compared to WAAS, in their current active way (aircraft need to send a pair of pings, listen to the pair of pongs, before they can use that distance information). DME pseudolites would enhance DME stations with a passive (regular GPS like data message, in the same way ADS-B sends each aircraft position to everybody else regularly instead of requiring secondary radar inquires to respond to). DMEs already respond (transmit to aircraft) using the L5 band that is coming online as the next GPS signal (just one lonely GPS satellite broadcasting it so far, more coming, plus all WAAS GEOs also have an L5 signal). Eventually WAAS receivers will listen to GPS signals using the current L1 band plus L5 as well. So adding a GPS like signal to each DME station would make a lot of sense, future receivers will be listening anyways, and the fact that DME stations don't need to go through 1000 miles of atmosphere to each aircraft can hugely improve the accuracy of this GPS like signal to each user, as long as each DME pseudolite (pseudo satellite) has an atomic clock, a CSAC. Each DME pseudolite transmission reaches all aircraft in view, allowing DME pseudolites to be used with no congestion concerns. No ping-pong for new (passive) users. At the same time, current DME system provides the user with actual ranging to the station. DME pseudolite provides users with an additional GPS like ranging source, potentially far more accurate even than normal GPS satellites. It doesn't directly provides the user with the distance to the station, GPS methods are needed to calculate that. But most uses of DME today are in DME-DME systems that determine actual aircraft position, much like WAAS, but far less accurate. Like a WAAS reference station, DME pseudolites know precisely where they are, down to a tenth of an inch (millimeter). To function the only other information they need is an ultra accurate clock synchronized to GPS time. By having a local atomic clock, they no longer need to constantly calculate the current time from GPS/WAAS signals, they can just compare the local clock with the GPS/WAAS calculated time, and periodically use the GPS/WAAS calculated time to make tiny corrections to the local atomic clock, at times when the GPS signal availability is excellent. A DME pseudolite could also detect bad GPS signals, since it know where it is and what time is it, it can validate each ranging signal it receives from each GPS satellite, much like WAAS and LAAS does. A CSAC enhanced DME pseudolites with GBAS aviation receivers with an integrated CSAC and a IMU (inertial navigation unit) might just make LAAS obsolete, since both CSAC and IMU both provide with means to verify the validity of the GBAS augmented navigational fix, detecting both jamming, spoofing and solar storms. DME pseudolites could perform basic localized integrity monitoring just flagging bad satellite signals instead of transmitting a full fledged correction signal. It could also transmit ionospheric corrections observed as part of the ranging calculation process, there are a lot more DME stations in the world than there will ever be GBAS reference stations. The receiver could use the pseudolite iono correction say if it's less than 50nm from the station, otherwise it would use the GBAS iono corrections. You might ask why a dual frequency GBAS receiver that can calculate its own iono corrections need iono corrections for, the answer is, it will take a long time until all GPS satellites are broadcasting an L5 signal and without L1+L5 signal from a satellite, the user can't calculate it's iono free pseudo range by itself, it might take another 20 or more years realistically until all active GPS satellites are broadcasting L5 signals, having great iono corrections allow for end users to calculate higher accuracy ranging calculations from all healthy GPS satellites, not just from satellites with an L5 signal. One would hope DME pseudolites will be able to use current semi- codeless GPS techniques, but will also be able to use L1, L2C and L5 to perform ultra accurate triple frequency iono corrections, to calculate iono free pseudo ranges with just 1 mm uncertainty instead of the usual 1-2 inch uncertainty with a stationary receiver, and in GPS time is distance and vice-versa (conversion via the speed of light). This might even allow for survey free DME pseudolite installations, the pseudolite can easily determine its own precise location within one day of test activity. Ultimately, we could have far more pseudolite only DME stations than we currently have regular DME stations, since a single DME channel can be shared between many passive DME stations (CDMA based PRN codes, like GPS uses today). Areas with CAT III and CAT II approaches could benefit from multiple DME pseudolites, allowing VPL and HPL in the 1 meter range (CAT IIIb using satellite requirement). Marcelo Pacheco |
Earth shattering news for GNSS, commercial availability of Chip Scale Atomic Clock (CSAC)
On Tue, 18 Jan 2011 19:36:20 -0800 (PST), macpacheco
wrote: Earth shattering news for GNSS, commercial availability of Chip Scale Atomic Clock (CSAC) For 1st generation CSAC, amazing: 16 cc volume (1 cu inch) 35 grams weight 115mW of power 4 orders of magnitude better clock stability than typical frequency crystals found in typical GPS receivers, that means that a CSAC will drift in about 3 hours what a typical crystal would drift in a single second. According to the supplier, Symmetricon, this CSAC is already as accurate as a Caesium atomic clock ! So cost seems to be the only bottleneck before this component is everywhere ultra high accuracy is desired. With WAAS receivers costing around US$ 10k, a US$ 200 atomic clock might be an acceptable extra cost. Although it probably costs a more than that right now (no price estimates are to be found). It seems to be $1500 each for small quantities: http://classic.cnbc.com/id/41131245 -- Muzaffer Kal DSPIA INC. ASIC/FPGA Design Services http://www.dspia.com |
Earth shattering news for GNSS, commercial availability of ChipScale Atomic Clock (CSAC)
On Jan 19, 4:34*am, Muzaffer Kal wrote:
On Tue, 18 Jan 2011 19:36:20 -0800 (PST), macpacheco wrote: Earth shattering news for GNSS, commercial availability of Chip Scale Atomic Clock (CSAC) For 1st generation CSAC, amazing: 16 cc volume (1 cu inch) 35 grams weight 115mW of power 4 orders of magnitude better clock stability than typical frequency crystals found in typical GPS receivers, that means that a CSAC will drift in about 3 hours what a typical crystal would drift in a single second. According to the supplier, Symmetricon, this CSAC is already as accurate as a Caesium atomic clock ! So cost seems to be the only bottleneck before this component is everywhere ultra high accuracy is desired. With WAAS receivers costing around US$ 10k, a US$ 200 atomic clock might be an acceptable extra cost. Although it probably costs a more than that right now (no price estimates are to be found). It seems to be $1500 each for small quantities:http://classic.cnbc.com/id/41131245 -- Muzaffer Kal DSPIA INC. ASIC/FPGA Design Services http://www.dspia.com Great info, thanks Muzaffer. Given typical advancements in this kind of technology, should mean $500 CSACs for high volume purchasers in 2-3 yrs, good enough for mass usage. |
On 2011.01.18 22:36 , macpacheco wrote:
CSACs might also make their way into all DPGS stations, improving their calculated corrections. All current WAAS stations have a standard Rb atomic clock (costs US$ 35000 each, lasting less than 10 yrs), replacing each Rb atomic clock with a triple redundant CSAC facility will save a bundle on WAAS maintenance (with three clocks a single faulty unit can be detected, excluded and marked for replacement without stopping the station). Regular atomic clocks also are temperature sensitive, requiring air conditioning, this CSAC can handle temperatures from -10C to +50C. The CSAC is not a deploy-able product. It has to be integrated into a receiver. That, with design, integration, testing and certification will drive up the cost considerably. The $1500 will go to about $10 - $15K as an educated guess. For a fielded WAAS station, the -10°C may be unacceptable. (There is the military version which is likely more expensive, that goes lower, -40°C). -- gmail originated posts filtered due to spam. |
On Jan 19, 3:43*pm, Alan Browne
wrote: On 2011.01.18 22:36 , macpacheco wrote: CSACs might also make their way into all DPGS stations, improving their calculated corrections. All current WAAS stations have a standard Rb atomic clock (costs US$ 35000 each, lasting less than 10 yrs), replacing each Rb atomic clock with a triple redundant CSAC facility will save a bundle on WAAS maintenance (with three clocks a single faulty unit can be detected, excluded and marked for replacement without stopping the station). Regular atomic clocks also are temperature sensitive, requiring air conditioning, this CSAC can handle temperatures from -10C to +50C. The CSAC is not a deploy-able product. *It has to be integrated into a receiver. *That, with design, integration, testing and certification will drive up the cost considerably. *The $1500 will go to about $10 - $15K as an educated guess. For a fielded WAAS station, the -10°C may be unacceptable. *(There is the military version which is likely more expensive, that goes lower, -40°C). -- gmail originated posts filtered due to spam. From what I've seen all WAAS stations today are co-located with Air traffic control centers. Perhaps one or two in alaska are stand alone. Even -40C is probably not cold enough for Alaska, there it will need some climatization. Anything new will take years before the FAA is willing to touch it. They are a lot more conservative even than the military. The current WAAS network is operational, what's the need to replace things out of the blue. By the time they start considering it, price will have dropped considerably, probably when they perform the migration from semi codeless to L1 CA+L5, probably circa 2020 (they stated that their plan is an all or nothing thing, once they migrate, all WAAS reference stations won't receive nor P(Y) nor L2C, L1 CA+L5 only, so they can't migrate before L5 reaches FOC anyways, its a step backwards in my opinion, but I digress) ... But as far as integration, atomic clocks are a misnomer anyways, they are actually frequency sources, a timing signal, or am I wrong ? I mean... they don't really keep time (nanoseconds since a given date), they make a 10 MHz timing output plus one or two other formats, that in turn is used not only to track time, but also used for all kinds of very important receive/transmit actual RF hardware (the more accurate clock available for the GPS RF receive can improve receive SNR margins for instance and can transmit a more precise signal for instance when generating the C band uplink for the GEOs). A 10 MHz clock is a 10MHz clock, sure it will require a ton of testing, but making it work, is it that expensive ? Marcelo Pacheco - Not an electronics expert. |
There's a lot of literature describing how a precise clock can
mitigate the strong correlation between the clock and vertical position states, hence improve VDOP, improve integrity monitoring, etc. Pratap Misra has written quite a bit on the topic. An early paper on clock coasting (there were earlier experiments): Sturza, Mark A., "GPS Navigation Using Tbree Satellites and a Precise Clock", NAVIGATION, Vol. 30, No. 2, Summer 1983, pp. 146-156, http://www.3csysco.com/Pubs/GPS%20Na...se%20Clock.pdf Can't find an on-line copy of this one: “The Role of the Clock in a GPS Receiver” by P.N. Misra in GPS World, Vol. 7, No. 4, April 1996, pp. 60–66. A dissertation that involved flight testing with a Boeing 767 at the FAA's Atlantic City test site: Kline, Paul A., "Atomic Clock Augmentation For Receivers Using the Global Positioning System," Ph.D. Dissertation, Virginia Polytechnic University, 1997, http://scholar.lib.vt.edu/theses/ava...2516142975720/ A thesis sponsored by Misra: Sean G. Bednarz, "Adaptive Modeling of GPS Receiver Clock for Integrity Monitoring During Precision Approaches," M.S. Thesis, Massachusetts Institute of Technology, 2004, http://dspace.mit.edu/handle/1721.1/17756 A GPS World Innovations column from 2007: http://tf.boulder.nist.gov/general/pdf/2267.pdf |
How sensitive are these CSACs to other environmental variables? What about
shock, or position? Are they robust enough to be used in wris****ches and portable timepieces (disregarding cost)? Which reminds me: why are there no wris****ches that use GPS just for a time reference, without the geolocation functions? Or are there? Seems like there'd be a market for such watches to replace "radio-controlled" watches depending on WWVB and the like, if the price isn't too high. They wouldn't need a CSAC, although that would be a nice bonus. |
Mxsmanic wrote:
How sensitive are these CSACs to other environmental variables? What about shock, or position? Are they robust enough to be used in wris****ches and portable timepieces (disregarding cost)? Which reminds me: why are there no wris****ches that use GPS just for a time reference, without the geolocation functions? Or are there? Seems like there'd be a market for such watches to replace "radio-controlled" watches depending on WWVB and the like, if the price isn't too high. They wouldn't need a CSAC, although that would be a nice bonus. No GPS unit is low-power enough to be used as a pure wris****ch, where a single button battery is supposed to last for years. You might get away with a very good crystal plus a GPS that only wakes up once (or a few times) per day or so, in which case you have made yourself a very expensive chronometer. :-) Instead of spending power on an oven for a TCXO you could use the Garmin approach of a tiny temperature sensor (_very_ low power) plus an automatically calibrated temp adjustement table for the XO. Terje -- - Terje.Mathisen at tmsw.no "almost all programming can be viewed as an exercise in caching" |
On Jan 20, 4:46*am, Mxsmanic wrote:
How sensitive are these CSACs to other environmental variables? What about shock, or position? Are they robust enough to be used in wris****ches and portable timepieces (disregarding cost)? Which reminds me: why are there no wris****ches that use GPS just for a time reference, without the geolocation functions? Or are there? Seems like there'd be a market for such watches to replace "radio-controlled" watches depending on WWVB and the like, if the price isn't too high. They wouldn't need a CSAC, although that would be a nice bonus. This first generation chip atomic clocks are still in the US$ 1000+ price scale. That should keep it's use down to where really needed. Probably another 20 yrs until we have a micro chip scale atomic clock. No clarification were given in the accuracy of the equipment at its temperature limits. It's very likely that CSAC measures its own temperature and compensate its output with measured temperature, so its entirely possible that its accuracy stay within specs for its entire operating temperature envelope. A wrist watch that can keep time down to one second per year precision is more than good enough, except for those who want to waste money on pricey status objects. Current quartz frequency standards already can keep time down to 30 ms per year (source wikipedia) ! Though its likely that accuracy is attained by larger chip sized quartz oscillator instead of the tiny quartz circuits found in wrist watches. Even smaller last generation micro quartz oscillators should be able to reach one second per year accuracy, so why would you want a GPS receiver just to set the clock ???? Just so you don't need to ever set your watch again ? |
On Jan 20, 12:08*am, "Ed M." wrote:
There's a lot of literature describing how a precise clock can mitigate the strong correlation between the clock and vertical position states, hence improve VDOP, improve integrity monitoring, etc. *Pratap Misra has written quite a bit on the topic. An early paper on clock coasting (there were earlier experiments): Sturza, Mark A., "GPS Navigation Using Tbree Satellites and a Precise Clock", NAVIGATION, Vol. 30, No. 2, Summer 1983, pp. 146-156,http://www.3csysco.com/Pubs/GPS%20Na...Three%20Satell... Can't find an on-line copy of this one: “The Role of the Clock in a GPS Receiver” by P.N. Misra in GPS World, Vol. 7, No. 4, April 1996, pp. 60–66. A dissertation that involved flight testing with a Boeing 767 at the FAA's Atlantic City test site: Kline, Paul A., "Atomic Clock Augmentation For Receivers Using the Global Positioning System," Ph.D. Dissertation, Virginia Polytechnic University, 1997,http://scholar.lib.vt.edu/theses/ava...2516142975720/ A thesis sponsored by Misra: Sean G. Bednarz, "Adaptive Modeling of GPS Receiver Clock for Integrity Monitoring During Precision Approaches," M.S. Thesis, Massachusetts Institute of Technology, 2004,http://dspace.mit.edu/handle/1721.1/17756 A GPS World Innovations column from 2007: http://tf.boulder.nist.gov/general/pdf/2267.pdf Coasting studies I've read seem to assume usage of a worse CSAC than a Cs atomic clock, something with at least one order of magnitude less stability than your typical Cs atomic clock. Taking Symmetricon's claims at face value here... Top of the line quartz oscillators = 30ms per year stability, four orders of magnitude better would be roughly 3 micro seconds per year stability, 8 ns per day stability, or 1 ns every 4 hours. Or 10 cm per hour drift. In an unjammed environment, today even in the middle of a GPS maintenance event, PDOP spikes don't last 2 hrs for the same area. And a 20cm error would be acceptable even for a CAT I autoland (VPL around 10 meters). Expecting the need to coast for more than 2 hours would be an nuclear war or extreme military jam requirement, not a civilian need. The most exciting aspect is this is only the first generation implementation. There are no competitors yet. 2nd generation should be here in lets guess 5 yrs. Imagine a CSAC on par with current Rb atomic clock for short term stability ! This not only helps with GNSS applications, but also helps every radio transmitter/receiver, 4g/ WiMax cell towers, ultra high speed laser transceivers, the list goes on and on. CSACs will directly replace current 10 MHz GNSS based frequency standards, used on any serious data communication/telecom environment, even small rural ISPs are more and more using WiMax or high end WiFi towers that require a more accurate frequency standard than a quartz oscillator. 5g cell systems might use upcoming 100 MHz atomic clock frequency standard to improve current RF performance by a mile. Marcelo Pacheco |
Similar Threads | ||||
CHIP LITE | Stuart & Kathryn Fields | Rotorcraft | 3 | March 28th 08 01:30 AM |
Chip-Red formation 2 | alf blume | Aviation Photos | 1 | December 4th 06 08:06 PM |
1 Amp DC/DC Converter Chip? | bcjames | Soaring | 11 | September 25th 04 06:32 AM |
Garmin 430 data chip | PaulaJay1 | Instrument Flight Rules | 6 | December 29th 03 05:43 PM |
ADC chip detectors | CS_Mike | Home Built | 2 | September 3rd 03 06:26 AM |
