#31
wing tape
On Sunday, August 9, 2020 at 1:04:44 AM UTC-4, Ben Hirashima wrote:
I've been using the wing tape sold by Craggy, but I'm not happy with it. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap? Ben - if the tape is 'sinking into the gaps', especially when going around the leading edge, you may have stretched it too much before applying it to the surface. After unrolling a length, just stick the first inch or so into the surface and wait for the vinyl to contract again, then apply it without a lot of pull-force. BTW - take a look at https://www.tapedepot.com/ If it comes on a roll and is sticky on at least one side, they have it. As far as the white vinyl goes, the quality is at least that of the 3M brand but they sell it for way less. They even carry special sizes like 1" or 2" or the textile tape used on the rudder. Look for 'Gaffer Tape'. Uli 'AS' |
#32
wing tape
On Sunday, August 9, 2020 at 2:26:29 PM UTC-7, AS wrote:
On Sunday, August 9, 2020 at 1:04:44 AM UTC-4, Ben Hirashima wrote: I've been using the wing tape sold by Craggy, but I'm not happy with it.. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap? Ben - if the tape is 'sinking into the gaps', especially when going around the leading edge, you may have stretched it too much before applying it to the surface. After unrolling a length, just stick the first inch or so into the surface and wait for the vinyl to contract again, then apply it without a lot of pull-force. BTW - take a look at https://www.tapedepot.com/ If it comes on a roll and is sticky on at least one side, they have it. As far as the white vinyl goes, the quality is at least that of the 3M brand but they sell it for way less. They even carry special sizes like 1" or 2" or the textile tape used on the rudder. Look for 'Gaffer Tape'. Uli 'AS' Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Richard |
#33
wing tape
Also much thicker. |
#34
wing tape
On Sunday, August 9, 2020 at 6:59:22 PM UTC-4, Richard Pfiffner wrote:
On Sunday, August 9, 2020 at 2:26:29 PM UTC-7, AS wrote: On Sunday, August 9, 2020 at 1:04:44 AM UTC-4, Ben Hirashima wrote: I've been using the wing tape sold by Craggy, but I'm not happy with it. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap? Ben - if the tape is 'sinking into the gaps', especially when going around the leading edge, you may have stretched it too much before applying it to the surface. After unrolling a length, just stick the first inch or so into the surface and wait for the vinyl to contract again, then apply it without a lot of pull-force. BTW - take a look at https://www.tapedepot.com/ If it comes on a roll and is sticky on at least one side, they have it. As far as the white vinyl goes, the quality is at least that of the 3M brand but they sell it for way less. They even carry special sizes like 1" or 2" or the textile tape used on the rudder. Look for 'Gaffer Tape'. Uli 'AS' Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Richard Where does it need to stretch? Not stretching is the whole point! Uli 'AS' |
#35
wing tape
On Sunday, August 9, 2020 at 4:59:39 PM UTC-7, AS wrote:
On Sunday, August 9, 2020 at 6:59:22 PM UTC-4, Richard Pfiffner wrote: On Sunday, August 9, 2020 at 2:26:29 PM UTC-7, AS wrote: On Sunday, August 9, 2020 at 1:04:44 AM UTC-4, Ben Hirashima wrote: I've been using the wing tape sold by Craggy, but I'm not happy with it. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap? Ben - if the tape is 'sinking into the gaps', especially when going around the leading edge, you may have stretched it too much before applying it to the surface. After unrolling a length, just stick the first inch or so into the surface and wait for the vinyl to contract again, then apply it without a lot of pull-force. BTW - take a look at https://www.tapedepot.com/ If it comes on a roll and is sticky on at least one side, they have it. As far as the white vinyl goes, the quality is at least that of the 3M brand but they sell it for way less. They even carry special sizes like 1" or 2" or the textile tape used on the rudder. Look for 'Gaffer Tape'. Uli 'AS' Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Richard Where does it need to stretch? Not stretching is the whole point! Uli 'AS' |
#36
wing tape
On Sunday, August 9, 2020 at 6:59:22 PM UTC-4, Richard Pfiffner wrote: On Sunday, August 9, 2020 at 2:26:29 PM UTC-7, AS wrote: On Sunday, August 9, 2020 at 1:04:44 AM UTC-4, Ben Hirashima wrote: I've been using the wing tape sold by Craggy, but I'm not happy with it. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap? Ben - if the tape is 'sinking into the gaps', especially when going around the leading edge, you may have stretched it too much before applying it to the surface. After unrolling a length, just stick the first inch or so into the surface and wait for the vinyl to contract again, then apply it without a lot of pull-force. BTW - take a look at https://www.tapedepot.com/ If it comes on a roll and is sticky on at least one side, they have it. As far as the white vinyl goes, the quality is at least that of the 3M brand but they sell it for way less. They even carry special sizes like 1" or 2" or the textile tape used on the rudder. Look for 'Gaffer Tape'. Uli 'AS' Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Richard Where does it need to stretch? Not stretching is the whole point! Uli 'AS' When the wing flexes the tape can be stretched repeatedly a small amount. And a tape's ability to stretch is reduced when exposed to cold temperatures of high altitude. After having the glider assembled for weeks at a time I see splits in even the excellent 3M electricians' tape I use. Tom |
#37
wing tape
On Sunday, August 9, 2020 at 8:55:30 PM UTC-4, 2G wrote:
On Sunday, August 9, 2020 at 4:59:39 PM UTC-7, AS wrote: On Sunday, August 9, 2020 at 6:59:22 PM UTC-4, Richard Pfiffner wrote: On Sunday, August 9, 2020 at 2:26:29 PM UTC-7, AS wrote: On Sunday, August 9, 2020 at 1:04:44 AM UTC-4, Ben Hirashima wrote: I've been using the wing tape sold by Craggy, but I'm not happy with it. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap? Ben - if the tape is 'sinking into the gaps', especially when going around the leading edge, you may have stretched it too much before applying it to the surface. After unrolling a length, just stick the first inch or so into the surface and wait for the vinyl to contract again, then apply it without a lot of pull-force. BTW - take a look at https://www.tapedepot.com/ If it comes on a roll and is sticky on at least one side, they have it. As far as the white vinyl goes, the quality is at least that of the 3M brand but they sell it for way less. They even carry special sizes like 1" or 2" or the textile tape used on the rudder. Look for 'Gaffer Tape'. Uli 'AS' Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Richard Where does it need to stretch? Not stretching is the whole point! Uli 'AS' When the wing flexes the tape can be stretched repeatedly a small amount. And a tape's ability to stretch is reduced when exposed to cold temperatures of high altitude. After having the glider assembled for weeks at a time I see splits in even the excellent 3M electricians' tape I use. Tom Tom - please read the last part of my original post. I am talking about the cloth tape used on the rudder - not the vinyl tape that holds the wings on! ;-) Uli 'AS' |
#38
wing tape
On Sunday, August 9, 2020 at 8:17:11 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Ben, About your comment that, "...but it sinks into the gaps that it's covering, which sort of defeats the purpose." Why do you feel that the tape sinking into the gap between the wing root and the fuselage is something to be avoided? To me the main purpose of wing tape is to seal the gap against air intrusion, not necessarily to continue the wing's airfoil without deformation. It seems that all wing tape "sinks" to one extent or another. My $0.02. If the main purpose of wing tape is to seal against air intrusion, that problem could be better solved with a simple rubber gasket where the wing joins the fuselage. It's just common sense that you would not want any departures from a smooth surface at the wing root. If you want to claim that it doesn't make a difference aerodynamically, then show me the data. |
#39
wing tape
The best tape is the 3M 483, but the price has gotten so out of hand that it is hard to justify. It will not sink in as much as the other tapes. One option is to make some thin mylar covers that you tape over with the softer tape. This will prevent the tape from sinking into the gap.
I still have a few rolls of 483 that use only when I can’t use something else. I have been researching alternatives and looking to buy some to test. 3M white electrical tape is what I use for anything that doesn’t need 483. |
#40
wing tape
At 17:59 10 August 2020, Tim Taylor wrote:
The best tape is the 3M 483, but the price has gotten so out of hand that i= t is hard to justify. It will not sink in as much as the other tapes. One= option is to make some thin mylar covers that you tape over with the softe= r tape. This will prevent the tape from sinking into the gap. =20 I still have a few rolls of 483 that use only when I can=E2=80=99t use some= thing else. I have been researching alternatives and looking to buy some t= o test.=20 3M white electrical tape is what I use for anything that doesn=E2=80=99t ne= ed 483. One of our club members was a master machinist and came up with the idea to slice the 1" 483 tape into 1/2" rolls in order to double the amount of uses one could get from an expensive roll of that tape. Unfortunately, he passed away, but beforehand had cut me about 15 rolls of it. It lasted me for years, but as I finally neared the end of my supply, I Googled the 483 tape and looked for equivalents from sources other than 3M. I found something similar, but just a little stiffer, on a closeout in 2" x 60!! yard rolls which I bought and had another club machinist slice into 4 x 1/2" - 60!! yard rolls. Due to its length, one roll will go for a long time. I probably have 20 or 30 rolls left, so if you want to try one, send me an email. $10 + shipping. Pics at: https://photos.app.goo.gl/deSxU1mUj7XctTXY7 RO |
Similar Threads | ||||
Wing Tape | Craig[_2_] | Soaring | 0 | May 5th 11 05:09 PM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
Wing Tape - Does Thickness Affect Performance? | ContestID67 | Soaring | 87 | February 1st 07 04:24 PM |
Wing Tape - Does Thickness Affect Performance? | Charles McLaurin | Soaring | 2 | January 30th 07 07:00 PM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 04:46 PM |
