A Poll on your weight and balance
Old December 16th 12, 05:33 AM posted to rec.aviation.soaring
JS
Default A Poll on your weight and balance
Oh, this has gone south... But it must be winter on RAS.
Jon Fitch might be the grand prize winner, and with a Martin Heide design...
Quelle surprise!
  #32
Old December 22nd 12, 09:58 AM posted to rec.aviation.soaring
CindyB[_2_]
On Saturday, December 15, 2012 7:07:37 AM UTC-8, JJ Sinclair wrote:
JJ, think "Doughnut Dolly"... ;^)
SNIPPED
She has been known to engage in ramp sex..............you know where you stand nose to nose and scream FUC* YOU at each other!
:) JJ
Oh My Gosh.
After all these years, I just discovered I have had sex in public!
Eeeekk.
I have given many lessons in tail dolly installation ( and removal) for
new owners of gliders. Lots of tips are available.
Leave your chute in the cockpit leaned forward, or drape it over the nosecone (non-sentient nose ballast)being careful of no loose buckles or canopy scraping.
Cockpit water containers or landout kits can be placed forward momentarily for this reconfiguration of ground handling equipment. Every bit of ballast helps.
Facing aft and straddling the boom, hold dolly handle in right hand and wheel in a perpendicular manner with your left. Set/fit top half over boom and fit to fin, leave open wheel-half resting on hinge line on the ground. Use linked hands forward of dolly to lift boom while sliding feet crossed or Very Close under boom, resting boom on pinched together calves. Dolly will rotate under boom by itself. Leave left hand underneath -- bringing lower half across, and use right hand to catch up a clasp or fidget dolly into snugging position. Take all that weight on your LEGS, not with your arms. If you have bad back history, use a short strap under the boom, and use your legs for the lift and pinch. (This strap might also be useful for fuselage transfers into and out of trailers.)
After latching clasps, you can allow glider to slide down your calves, or grasp
hands under again to set tail on ground.
For taller tail gliders, a friend to place palms under the horizontal, IMMEDIATELY adjacent to the vertical (not outboard) and hoist upwards close to the leading edge, while the pilot places a dolly can be a BIG service, if you gentlemen wish to avoid the Doughnut Dolly problem. Often there is someone more readily available aft of your gridding position.
But an aft-facing buddy perched on the side rail of your cockpit, near the panel rather than the turtledeck, is the best bet for monitoring the teeter-totter cooperation of taildolly installs and removals. Said buddy should be encouraged to have a hand lightly protecting/monitoring that open canopy during the job, with a grip on the frame only. The pilot/installer can direct the weight transfer audibly for install or removal by asking for weight or unloading.
A canopy rail percher is less likely to place hands on your valuable plexi,and make an inadvertent crack or scratches. There is less likelihood of them 'slipping off' or losing grip while trying to provide the counterbalance.. There is less likelihood of forcing cracking on the center seam due to 'unexpected' loads.
It may now be winter, but I have seen plenty of wave lift markers out my kitchen window these last few weeks. Whew. Headed for summer again.
Merry Christmas,
Cindy B
  #33
Old December 22nd 12, 03:19 PM posted to rec.aviation.soaring
Dave Nadler
On Saturday, December 22, 2012 4:58:51 AM UTC-5, CindyB wrote:
Oh My Gosh.
Eeeekk.
Cindy, we're awaiting the YouTube instructional video...
See ya, Dave "YO electric"
  #34
Old December 22nd 12, 06:24 PM posted to rec.aviation.soaring
CindyB[_2_]
Oh My Gosh.
Eeeekk.
Dave:
You'll have to wait perhaps a few months, for seasonally appropriate wardrobe. It has been overnight lows of 20F and 23F for several days. This avowed reptile is buried in thermal layers.
I can't bring myself to think about short-shorts
and strappy T's for a December teaching video, irregardless of the issue date of Sports Illustrated's most-'read' publication. Unless perhaps you want to donate a round trip ticket for me to South Africa. . . I know a fellow with a Nimbus 3 down there. That's got a beefy tail weight. Maybe the Jonkers boys would want an advertising 'trailer' of a light tail weight?
Or did you mean the video of 'ramp sex'?
That can be staged almost any time of year,and is
less wardrobe dependent! (Really folks, I seldom exercised my
side of rampsex, but you all know that anyway.)
Back to holiday baking, which is a thermal application all it's own.
Merry Christmas,
Cindy
ASK-21 Weight and Balance Carl Baxter Soaring 4 June 2nd 11 02:57 PM
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
