Launch point logging software flight accounting
Like many clubs mine blows hot and cold on using launchpoint logging
software. At present we have a legacy system handling flight recording from paper records taken at the launch point with a link to our accounting system which was written by a club member who left some time ago and the system should probably be overhauled/replaced regardless of adding a launchpoint bit. While it does tick the simple easy to use box I suspect that savings could be made in terms of staff time entering the data later. I suspect that many other clubs are in a similar position or are paying for the software. I would like to explore the possibility of a collaborative venture making the end result open source which will hopefully ensure that the support continues into the future and the package moves forward Would anyone who is interested in participating please contact me on the email address below. Would also be interested to hear from anyone who has a good robust system and is willing to donate it to the community as a starting point. A critical mass of at least 5-6 clubs and 4+ developers is probably required - location is not seen as an issue and it should be easy enough to make the software multilingual. I would also like to hear of other clubs experiences using launchpoint logging systems with respect to reliability, redundancy, ease of use etc etc. rgds Stephen sjhcon_at_gmail.com |
On Nov 26, 5:05*pm, stevehaley wrote:
Like many clubs mine blows hot and cold on using launchpoint logging software. At present we have a legacy system handling flight recording from paper records taken at the launch point with a link to our accounting system which was written by a club member who left some time ago and the system should probably be overhauled/replaced regardless of adding a launchpoint bit. While it does tick the simple easy to use box I suspect that savings could be made in terms of staff time entering the data later. I suspect that many other clubs are in a similar position or are paying for the software. I would like to explore the possibility of a collaborative venture making the end result open source which will hopefully ensure that the support continues into the future and the package moves forward Would anyone who is interested in participating please contact me on the email address below. Would also be interested to hear from anyone who has a good robust system and is willing to donate it to the community as a starting point. A critical mass of at least 5-6 clubs and 4+ developers is probably required - location is not seen as an issue and it should be easy enough to make the software multilingual. I would also like to hear of other clubs experiences using launchpoint logging systems with respect to reliability, redundancy, ease of use etc etc. rgds Stephen sjhcon_at_gmail.com Good idea. It strikes me that if both gliders and tugs carried GPS loggers, all flight data could be automatically captured except for matching flights to member names which should be fairly easy to do manually. Tows would be matched to glider flights since the logs are time stamped. A tow starting at exactly the same time as a glider flight would link them together. A software package that created a daily screen from the logs data where pilot names could be entered manually would make billing easier - and a lot more accurate. |
The manual operations required to download gps files from all the aircraft,
loading into a computer and adding pilot billing accounts would take more time than transferring a manual log to a spreadsheet. The trick is to get the spreadsheet data into the accounting and billing system. "bildan" wrote in message ... On Nov 26, 5:05 pm, stevehaley wrote: Like many clubs mine blows hot and cold on using launchpoint logging software. At present we have a legacy system handling flight recording from paper records taken at the launch point with a link to our accounting system which was written by a club member who left some time ago and the system should probably be overhauled/replaced regardless of adding a launchpoint bit. While it does tick the simple easy to use box I suspect that savings could be made in terms of staff time entering the data later. I suspect that many other clubs are in a similar position or are paying for the software. I would like to explore the possibility of a collaborative venture making the end result open source which will hopefully ensure that the support continues into the future and the package moves forward Would anyone who is interested in participating please contact me on the email address below. Would also be interested to hear from anyone who has a good robust system and is willing to donate it to the community as a starting point. A critical mass of at least 5-6 clubs and 4+ developers is probably required - location is not seen as an issue and it should be easy enough to make the software multilingual. I would also like to hear of other clubs experiences using launchpoint logging systems with respect to reliability, redundancy, ease of use etc etc. rgds Stephen sjhcon_at_gmail.com Good idea. It strikes me that if both gliders and tugs carried GPS loggers, all flight data could be automatically captured except for matching flights to member names which should be fairly easy to do manually. Tows would be matched to glider flights since the logs are time stamped. A tow starting at exactly the same time as a glider flight would link them together. A software package that created a daily screen from the logs data where pilot names could be entered manually would make billing easier - and a lot more accurate. |
On Nov 27, 5:50*am, bildan wrote:
On Nov 26, 5:05*pm, stevehaley wrote: Like many clubs mine blows hot and cold on using launchpoint logging software. At present we have a legacy system handling flight recording from paper records taken at the launch point with a link to our accounting system which was written by a club member who left some time ago and the system should probably be overhauled/replaced regardless of adding a launchpoint bit. While it does tick the simple easy to use box I suspect that savings could be made in terms of staff time entering the data later. I suspect that many other clubs are in a similar position or are paying for the software. I would like to explore the possibility of a collaborative venture making the end result open source which will hopefully ensure that the support continues into the future and the package moves forward Would anyone who is interested in participating please contact me on the email address below. Would also be interested to hear from anyone who has a good robust system and is willing to donate it to the community as a starting point. A critical mass of at least 5-6 clubs and 4+ developers is probably required - location is not seen as an issue and it should be easy enough to make the software multilingual. I would also like to hear of other clubs experiences using launchpoint logging systems with respect to reliability, redundancy, ease of use etc etc. rgds Stephen sjhcon_at_gmail.com Good idea. It strikes me that if both gliders and tugs carried GPS loggers, all flight data could be automatically captured except for matching flights to member names which should be fairly easy to do manually. Tows would be matched to glider flights since the logs are time stamped. *A tow starting at exactly the same time as a glider flight would link them together. A software package that created a daily screen from the logs data where pilot names could be entered manually would make billing easier - and a lot more accurate. Stephen, You may like the look of the software for gliding clubs described at the following page. http://datamodus.net/Index.htm My club looked at it several years ago. We didn't go ahead (& still use pen and paper), so no guarantees, but at least the supplier seemed genuine. Ian Grant ian dot grant12 at gmail,com |
On Nov 26, 7:05*pm, stevehaley wrote:
Like many clubs mine blows hot and cold on using launchpoint logging software. At present we have a legacy system handling flight recording from paper records taken at the launch point with a link to our accounting system which was written by a club member who left some time ago and the system should probably be overhauled/replaced regardless of adding a launchpoint bit. While it does tick the simple easy to use box I suspect that savings could be made in terms of staff time entering the data later. I suspect that many other clubs are in a similar position or are paying for the software. I would like to explore the possibility of a collaborative venture making the end result open source which will hopefully ensure that the support continues into the future and the package moves forward Would anyone who is interested in participating please contact me on the email address below. Would also be interested to hear from anyone who has a good robust system and is willing to donate it to the community as a starting point. A critical mass of at least 5-6 clubs and 4+ developers is probably required - location is not seen as an issue and it should be easy enough to make the software multilingual. I would also like to hear of other clubs experiences using launchpoint logging systems with respect to reliability, redundancy, ease of use etc etc. rgds Stephen sjhcon_at_gmail.com Do consider practical issues such as: - you can't see most computer screens outdoors - power will be needed near launch point - computaphobes in club - affect of rain on komputers - komputers often break - ease of info transfer from field to wherever billing is done Keep a paper backup in any case ! From a guy who specializes in practical solutions ;-) See ya, Dave |
We had a computer system running at our club about 8 years ago, but
have gone back to a paper system with the data entered into the accounting system at a later time. The intent of the computer system was to save the time punching in all the flight data. As it turns out, it didn't actually make much difference in time-savings over the course of a year. Some of the problems are much as Dave mentions above, such as a power source at the launch point and computaphobes. Other problems included: 1. The issue of small mid-week operation not taking the computer to the launch point to enter the flights (too much effort for just a couple of flights) and then someone else having to enter all the mid- week flights before the Saturday morning operation could start. 2. Entering new members into the system at the launch point - the member database was not easily updated on the fly. 3. Errors entered into the launch point computer are transmitted directly into the billing system. If there is no paper trail, these can be difficult to correct. With the paper system, one person in a quiet space enters all the data and checks it for validity before it gets to the billing system. Granted, this person does a lot of data entry, but we have also found that they catch 99% of the errors before the numbers hit the billing system. Our system (for a club of about 150 members with about 3500 flights per year) now works like this. a. The pilot fills out a flight card before take-off with glider ID, their name and account #, type of flight and tow height. (types of flight include Intro/Famil flight, student flight, solo flight, flight in private ship etc) b. The flight card is passed to the time keeper who enters the flight on the daily log sheet, assigns a flight number and then adds take-off and landing time on the card. c. The card is a two part carbon form, where one copy goes to the accounting system and the other goes to the pilot after the flight d. The flight info from all cards is entered into our "flight card processor" (FCP). This is a program written in Visual Basic with a MS Access backbone. This converts the feet and minutes for each flight into dollars and cents. It also produces a monthly listing for each member with all the details for each flight. e. At the end of each month the FCP data is entered into the accounting system (Quickbooks) f. Statements are emailed to each member the first week of each month with a complete listing of all their flight details from the FCP, as well as all the credits/debits to their account from Quickbooks. |
On Nov 27, 2:09*pm, Dave Springford wrote:
We had a computer system running at our club about 8 years ago, but have gone back to a paper system with the data entered into the accounting system at a later time. *The intent of the computer system was to save the time punching in all the flight data. *As it turns out, it didn't actually make much difference in time-savings over the course of a year. Some of the problems are much as Dave mentions above, such as a power source at the launch point and computaphobes. Other problems included: 1. The issue of small mid-week operation not taking the computer to the launch point to enter the flights (too much effort for just a couple of flights) and then someone else having to enter all the mid- week flights before the Saturday morning operation could start. 2. Entering new members into the system at the launch point - the member database was not easily updated on the fly. 3. Errors entered into the launch point computer are transmitted directly into the billing system. *If there is no paper trail, these can be difficult to correct. With the paper system, one person in a quiet space enters all the data and checks it for validity before it gets to the billing system. Granted, this person does a lot of data entry, but we have also found that they catch 99% of the errors before the numbers hit the billing system. Our system (for a club of about 150 members with about 3500 flights per year) now works like this. a. *The pilot fills out a flight card before take-off with glider ID, their name and account #, type of flight and tow height. *(types of flight include Intro/Famil flight, student flight, solo flight, flight in private ship etc) b. *The flight card is passed to the time keeper who enters the flight on the daily log sheet, assigns a flight number and then adds take-off and landing time on the card. c. *The card is a two part carbon form, where one copy goes to the accounting system and the other goes to the pilot after the flight d. *The flight info from all cards is entered into our "flight card processor" (FCP). *This is a program written in Visual Basic with a MS Access backbone. *This converts the feet and minutes for each flight into dollars and cents. *It also produces a monthly listing for each member with all the details for each flight. e. *At the end of each month the FCP data is entered into the accounting system (Quickbooks) f. *Statements are emailed to each member the first week of each month with a complete listing of all their flight details from the FCP, as well as all the credits/debits to their account from Quickbooks. You could consider using digital pen technology with a template that specifies all the relevant flight info fields to be filled out: http://www.livescribe.com/ At least then you'd have a paper copy of all the original entries. You'd need to figure out the OCR part - which in theory would be easier as you'd know whether each field was alpha or numeric - but even so it would be a fair amount of coding. And you'd need to make sure nobody lost the pen! Bill mentions integrating with GPS loggers. While interesting I think it may be overkill for the simple purpose of getting flight times - unless you had a wireless way of downloading everything from the aircraft. Even more coding and the wireless technology on loggers isn't quite available yet. 9B |
On Nov 28, 10:10*am, Andy wrote:
On Nov 27, 2:09*pm, Dave Springford wrote: We had a computer system running at our club about 8 years ago, but have gone back to a paper system with the data entered into the accounting system at a later time. *The intent of the computer system was to save the time punching in all the flight data. *As it turns out, it didn't actually make much difference in time-savings over the course of a year. Some of the problems are much as Dave mentions above, such as a power source at the launch point and computaphobes. Other problems included: 1. The issue of small mid-week operation not taking the computer to the launch point to enter the flights (too much effort for just a couple of flights) and then someone else having to enter all the mid- week flights before the Saturday morning operation could start. 2. Entering new members into the system at the launch point - the member database was not easily updated on the fly. 3. Errors entered into the launch point computer are transmitted directly into the billing system. *If there is no paper trail, these can be difficult to correct. With the paper system, one person in a quiet space enters all the data and checks it for validity before it gets to the billing system. Granted, this person does a lot of data entry, but we have also found that they catch 99% of the errors before the numbers hit the billing system. Our system (for a club of about 150 members with about 3500 flights per year) now works like this. a. *The pilot fills out a flight card before take-off with glider ID, their name and account #, type of flight and tow height. *(types of flight include Intro/Famil flight, student flight, solo flight, flight in private ship etc) b. *The flight card is passed to the time keeper who enters the flight on the daily log sheet, assigns a flight number and then adds take-off and landing time on the card. c. *The card is a two part carbon form, where one copy goes to the accounting system and the other goes to the pilot after the flight d. *The flight info from all cards is entered into our "flight card processor" (FCP). *This is a program written in Visual Basic with a MS Access backbone. *This converts the feet and minutes for each flight into dollars and cents. *It also produces a monthly listing for each member with all the details for each flight. e. *At the end of each month the FCP data is entered into the accounting system (Quickbooks) f. *Statements are emailed to each member the first week of each month with a complete listing of all their flight details from the FCP, as well as all the credits/debits to their account from Quickbooks. You could consider using digital pen technology with a template that specifies all the relevant flight info fields to be filled out: http://www.livescribe.com/ At least then you'd have a paper copy of all the original entries. You'd need to figure out the OCR part - which in theory would be easier as you'd know whether each field was alpha or numeric - but even so it would be a fair amount of coding. *And you'd need to make sure nobody lost the pen! Bill mentions integrating with GPS loggers. While interesting I think it may be overkill for the simple purpose of getting flight times - unless you had a wireless way of downloading everything from the aircraft. Even more coding and the wireless technology on loggers isn't quite available yet. 9B Wireless tech would make a nifty system but it isn't absolutely needed. If the GPS loggers recorded on SD cards, just bring them to the club office for the software to read. You'd still have to manually log who flew which glider but the altitudes and flight durations would be perfectly accurate. |
On Nov 28, 9:27*am, bildan wrote:
On Nov 28, 10:10*am, Andy wrote: Wireless tech would make a nifty system but it isn't absolutely needed. *If the GPS loggers recorded on SD cards, just bring them to the club office for the software to read. *You'd still have to manually log who flew which glider but the altitudes and flight durations would be perfectly accurate. Here's a logger with SD capability and Bluetooth: http://www.sparkfun.com/commerce/pro...oducts_id=8823 I still see a few potential problems: - I you relieve the ops/launch director and tow pilots from recording times and altitudes you are making the day's operations subject to the reliability of the technology. Since tow pilots wouldn't be using the logger for anything related to their duties they would have no idea whether it is functioning properly until the end of day data collection exercise - at which point it's really too late to recover. If you keep written logs as a backup you are giving up most of the benefit as I don't see much operational benefit to the end of day accounting - in one case you have to download a bunch of logs and manually sync them up with the aircraft bring towed versus simply putting in the altitudes and registration numbers off the tow pilots' sheets. - There are similar issues for logging club glider flights. Managing SD cards, making sure they are in and that the logger battery is charged before each flight are a couple of the operational issues I can imagine. - Wireless would be a way for the ops director to sync up after each flight and ensure that everything is working properly - but then you'd have to have a process to acquire the signal from the towplane each time. Bluetooth isn't great at this and the loggers may not be smart enough to automatically download. - At $150 a pop this becomes expensive, particularly if you want to include gliders in addition to just towplanes. You might rather have igc loggers in gliders, but that is even more expensive. - Even with all of this you still have to sync up each flight/tow with a customer. Some people just aren't good at doing this on a computer versus pen and paper. Not that it couldn't be done - eventually it will be I expect. But you need to get the infrastructure in place - I expect pure record keeping isn't enough justification for most clubs. A first step would be allowing off-the-shelf commercial loggers to be used for badge flights. If you already had a logger in every aircraft it would open up their use for other purposes. For the flight line I expect a touchscreen e-paper tablet would be a good solution. http://www.engadget.com/2009/03/03/h...n-pc-at-cebit/ Still needs development... 9B |
Similar Threads | ||||
Turn point website and flight logs | Udo | Soaring | 2 | December 5th 06 10:03 PM |
Logging Flight Time Question | Phoenix Pilot | Piloting | 1 | June 13th 04 06:23 PM |
Flight Logging - Cheap | Marry Daniel or David Grah | Soaring | 10 | March 10th 04 01:22 AM |
Safelog software/flight log software question | Mark | Piloting | 2 | December 8th 03 02:34 PM |
Club Accounting S/W | WDM | Soaring | 0 | October 27th 03 04:39 PM |
