New Mexico Fire-Devils
Bob Korves wrote:
Marc Ramsey wrote in . net: http://vortexengine.ca/ Wanna buy a bridge to go with that Atmospheric Vortex Engine? -Bob Quite. The Solar Chimney technology (trialled in Spain and, I think, currently being worked on in Australia) http://www.globalwarmingsolutions.co...ar_chimney.htm looks likely to be much more efficient. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
I can think of the following reasons why a visibly rotating dust devil =
can end in an apparently spin-less cloud: 1. The angular momentum carried in a dust devil is partially dissipated = to the neighbouring air through the normal momentum transfer mechanisms = that occur in all fluid flows, and very strongly in turbulent flows. 2. A rising thermal collects a large amount of surrounding air, = especially in its final (or higher) stages. This incorporated air likely = has statistically random angular momentum, thus diluting the specific = angular momentum in the whole thermal. 3. The thermal widens and the rotation speed drops by the inverse square = of the radius. 4. The angular velocity drops by the inverse cube of the radius. So a ten metre wide dust devil rotating once every two seconds can turn = into a two hundred wide cloud rotating once every sixty hours, without = violating any physical laws. Regards |
Oops! Made a mistake in point 4 of previous message.
So, where I wrote "once every sixty hours", please read "once every six hours". The cloud will anyway seem devoid of rotation to any human observer. Regards |
The idea looks to be interesting, although the problems in producing a
chimney with a height of 1000 metres would be interesting. :-( And more importantly, isn't this a bit high for a first thermal off of the launch? ;-) Be nice to have a dedicated thermal just off the runway though! Malcolm... "Martin Gregorie" wrote in message ... Bob Korves wrote: Marc Ramsey wrote in . net: http://vortexengine.ca/ Wanna buy a bridge to go with that Atmospheric Vortex Engine? -Bob Quite. The Solar Chimney technology (trialled in Spain and, I think, currently being worked on in Australia) http://www.globalwarmingsolutions.co...ar_chimney.htm looks likely to be much more efficient. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
There are some very optimistic people working on a 1000m high chimney in the prime soaring country north of Mildura, Australia at this very moment.
I asked the question on our aussie site if it could be used as a thermal generator for gliding, everyone was confident it would be no problem BEFORE twin towers 911, not now. Another good one George, thanks. |
Francisco De Almeida wrote:
Oops! Made a mistake in point 4 of previous message. So, where I wrote "once every sixty hours", please read "once every six hours". The cloud will anyway seem devoid of rotation to any human observer. I certain I've read that, on a calm day, if you lie on your back and cloud watch, you CAN see them rotate, just very slowly. Can't remember where I read that, though. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
Similar Threads | ||||
Inside the Cowling Fire / Heat Detector? | George Sconyers | Aviation Marketplace | 4 | May 31st 04 01:40 AM |
"Friendly fire" | Mike | Naval Aviation | 3 | April 6th 04 06:07 PM |
My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 05:02 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
"Friendly fire" | Mike | Military Aviation | 0 | March 19th 04 02:36 PM |
