Experimental LSA gliders?
Hi Gang
Having a LSA power plane and in reviewing the proposed new experimental certifications (FAA Order 8130.2F) which includes gliders left me very puzzled. Why would anyone register a glider or motor glider as an experimental or standard light sport aircraft (LSA) although 8130.2F specifically includes them? The reason for registering a power plane as a LSA is that no medical is required, only a valid driving license, with the caveat that one is never denied a medical. A glider or motor glider, whether registered as standard or experimental, does not require the pilot to have a medical PERIOD. So what am I missing? I am confused! Can anyone educate me please or is this bureaucratic BS. Dave |
The main benefit would probably be with a special light sport glider
like the TST -14 or Urban Air Lambada. If someone wanted to buy one and either use it for personal use or giving rides/instruction they could do their own maintenance including annuals and 100 hour inspections after taking an 80 hour maintenance course. That would give someone freedom from an A&P or IA if they chose to do so. The light sport gives many benefits besides skipping out on a medical. The main benefit is being able to try different types of aircraft without having to drop so much money. Once you have your first rating you can try out anything else that fits into light sport. That includes airplane and weight shift - land and sea, glider, powered parachute, rotorcraft (gyro), and lighter than air. You just have to become proficient in the new category/class and your instructor will sign you off to take a proficiency check with another instructor. No examiner or minimum times. If someone wanted to transition into gliders from another class they would be pretty limited since they made it a Vne of 120kts and gross weight of 1,320 lbs. The Vne limits a lot of gliders and they'd probably be stuck in Schweizers (nothing wrong with that per se). Anyone know of operations giving instruction in LSA gliders or towards the rating? |
On Feb 17, 7:13 pm, wrote:
The main benefit would probably be with a special light sport glider like the TST -14 or Urban Air Lambada. If someone wanted to buy one and either use it for personal use or giving rides/instruction they could do their own maintenance including annuals and 100 hour inspections after taking an 80 hour maintenance course. That would give someone freedom from an A&P or IA if they chose to do so. The light sport gives many benefits besides skipping out on a medical. The main benefit is being able to try different types of aircraft without having to drop so much money. Once you have your first rating you can try out anything else that fits into light sport. That includes airplane and weight shift - land and sea, glider, powered parachute, rotorcraft (gyro), and lighter than air. You just have to become proficient in the new category/class and your instructor will sign you off to take a proficiency check with another instructor. No examiner or minimum times. If someone wanted to transition into gliders from another class they would be pretty limited since they made it a Vne of 120kts and gross weight of 1,320 lbs. The Vne limits a lot of gliders and they'd probably be stuck in Schweizers (nothing wrong with that per se). Anyone know of operations giving instruction in LSA gliders or towards the rating? The LSA max cruise speed is limited to 120 knots at any altitude up to 10k feet msl (LSA rated pilot only) not VNE which is not defined. For home built gliders and powered aircraft both within the experimental categories including but not limited to LSA experimental, constructors can do their own annuals after they have taken and passed a course. I still don't see an advantage to register as a LSA except if it is a POWERED aircraft (not glider or motor glider) and there is a question concerning your medical. I am told that insurance companies are becoming reluctant to issue insurance policies to LSA pilots without medicals. I still have my medical so it is not yet an issue for me. Dave |
wrote in message ... On Feb 17, 7:13 pm, wrote: The LSA max cruise speed is limited to 120 knots at any altitude up to 10k feet msl (LSA rated pilot only) not VNE which is not defined. Has the unpowered LSA (Glider) regs been change from a VNE limit of 120 Kts? I know powered LSA have a Cruise limit of 120 kts. However, the last time I checked, LSA (Glider) limit was still a VNE of 120 Kts. Has reason prevailed a the Vne limit been removed? If so, could you please give me a reference? Wayne HP-14 "6F" http://www.soaridaho.com/ |
"Wayne Paul" wrote in message ... wrote in message ... On Feb 17, 7:13 pm, wrote: The LSA max cruise speed is limited to 120 knots at any altitude up to 10k feet msl (LSA rated pilot only) not VNE which is not defined. Has the unpowered LSA (Glider) regs been change from a VNE limit of 120 Kts? I know powered LSA have a Cruise limit of 120 kts. However, the last time I checked, LSA (Glider) limit was still a VNE of 120 Kts. Has reason prevailed a the Vne limit been removed? If so, could you please give me a reference? Wayne HP-14 "6F" http://www.soaridaho.com/ According to the following link, glider are still limited to a Vne of 120 kts. http://www.sportpilot.org/learn/sp_rule.pdf Wayne HP-14 "6F" http://www.soaridaho.com/ |
On Feb 17, 9:51 pm, "Wayne Paul" wrote:
"Wayne Paul" wrote in message ... wrote in message ... On Feb 17, 7:13 pm, wrote: The LSA max cruise speed is limited to 120 knots at any altitude up to 10k feet msl (LSA rated pilot only) not VNE which is not defined. Has the unpowered LSA (Glider) regs been change from a VNE limit of 120 Kts? I know powered LSA have a Cruise limit of 120 kts. However, the last time I checked, LSA (Glider) limit was still a VNE of 120 Kts. Has reason prevailed a the Vne limit been removed? If so, could you please give me a reference? Wayne HP-14 "6F" http://www.soaridaho.com/ According to the following link, glider are still limited to a Vne of 120 kts.http://www.sportpilot.org/learn/sp_rule.pdf Wayne HP-14 "6F"http://www.soaridaho.com/ Hi Gang I stand corrected. You all are right a LSA glider is limited to 120 knots VNE (SparrowHawk 123 knots) and a max stall speed of 45 knots. Surely these are yet more reasons to never register a glider in the LSA category. There are no speed limitations for a glider (non powered ultra light vehicle!) in Part 103 nor for regular gliders. OK Guys and Gals convince me - give me a single reason, just a single rational reason to register a glider as a LSA despite the multitude of reasons not to do so. Dave |
On Feb 18, 9:49 am, Marc Ramsey wrote:
wrote: OK Guys and Gals convince me - give me a single reason, just a single rational reason to register a glider as a LSA despite the multitude of reasons not to do so. I doubt very many Sparrowhawks are legal Part 103 ultralights, most are quite simply over the weight limitation. Owners of "fat" ultralights are being "encouraged" to recertify under LSA (though I believe there was a grace period which may be over, by now). If you're willing to take your chances on not getting a ramp check involving a scale, then there probably is no reason to switch. LSA certification does allow for the manufacture of a two seat training glider that can be used commercially, without going through a multi-million dollar certification process. And yes, the 10,000 foot limitation goes away if the PIC has a private license... Marc Hi Marc I do not disagree with what you are saying but you have not answered my question which is why register say a single place glider as a LSA glider instead instead of as a regular glider (experimental or standard). Except for the 2 place trainer which, as you point out, might make sense what's the rationale for a single place glider? Dave |
On Feb 18, 10:55*am, Marc Ramsey wrote:
... the FAA does have rules on the book that restrict series manufacture and sale of non- type certificated non-ultralight aircraft... Cite? I keep hearing that, but I keep not seeing it. All those Zunis got into the air somehow... Thanks, Bob K. |
Similar Threads | ||||
life/accident insurance in Experimental category gliders | Phillip LaBerge | Soaring | 5 | January 22nd 08 05:32 PM |
Experimental or not? | John D. Abrahms | Home Built | 23 | April 14th 05 01:45 AM |
Experimental/Exhibition | Juan Jimenez | Home Built | 14 | January 1st 05 01:56 AM |
Experimental? | Hankal | Piloting | 3 | July 5th 04 05:44 PM |
Q about an experimental | Me | Military Aviation | 2 | June 12th 04 04:32 PM |
