Flying IFR with out STAND BY Vac & electrical is insane!
Flying IFR without a stand by Vaccum system AND some form of
INDEPENDENT back up electrical that can power the entire aircraft power buss is INSANE!!!!!! |
INDEPENDENT back up electrical that can power the entire aircraft power buss is INSANE!!!!!! Why? Care to quote some accident numbers? -- Thomas Borchert (EDDH) |
Don't feed the no-code, loser, troll...
denny |
On Mar 27, 10:19*am, Ross wrote:
What if one flies with a wet vacuum pump? Pretty much bullet proof. Ross Ross, I am not sure about wet vacuum being bullet proof. I recalled doing some extensive searches on the cost/benefit tradeoff of getting a wet pump or a backup vacuum pump and came across reports of sudden catastrophic failures of wet pumps. I ended up just replacing my dry pump with one with good reliability record/ long warranty life and adding a Precise Fliight backup system. Wet pumps may not fail frequently but they are not totally bullet proof. Hai Longworth |
Longworth wrote:
On Mar 27, 10:19 am, Ross wrote: What if one flies with a wet vacuum pump? Pretty much bullet proof. Ross Ross, I am not sure about wet vacuum being bullet proof. I recalled doing some extensive searches on the cost/benefit tradeoff of getting a wet pump or a backup vacuum pump and came across reports of sudden catastrophic failures of wet pumps. I ended up just replacing my dry pump with one with good reliability record/ long warranty life and adding a Precise Fliight backup system. Wet pumps may not fail frequently but they are not totally bullet proof. Hai Longworth I have heard of catastrophic failures but rather slow degrading. In any event, they are better than the dry. I will clean the belly anytime. Ross |
Similar Threads | ||||
insane IMC | Napoleon Dynamite | Piloting | 20 | August 4th 06 05:32 PM |
The insane spitfire video clip | Highwood | General Aviation | 1 | November 30th 03 11:48 PM |
The insane spitfire video clip | Highwood | Piloting | 1 | November 30th 03 11:48 PM |
The insane spitfire video clip | gatt | Piloting | 95 | November 10th 03 04:57 AM |
The insane spitfire video clip | gatt | General Aviation | 30 | November 4th 03 06:43 PM |
