What's Wrong With OLC?
Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products.
The best place for further discussion would be the CNi forum. Thanks Evan Ludeman |
But that's 1800 - 1801 local.Â* That doesn't make sense unless I'm
figuring Zulu time backwards.Â* I haven't been airborne that late in quite a while. See you on the CNi forum. On 5/18/2019 5:22 AM, Tango Eight wrote: Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products. The best place for further discussion would be the CNi forum. Thanks Evan Ludeman -- Dan, 5J |
2359 - 0000z rollover.
On Saturday, May 18, 2019 at 6:22:07 AM UTC-5, Tango Eight wrote: Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products. The best place for further discussion would be the CNi forum. Thanks Evan Ludeman |
1800 mountain time is 2400 Zulu or UTC
On Saturday, May 18, 2019 at 6:53:24 AM UTC-7, Dan Marotta wrote: But that's 1800 - 1801 local.Â* That doesn't make sense unless I'm figuring Zulu time backwards.Â* I haven't been airborne that late in quite a while. See you on the CNi forum. On 5/18/2019 5:22 AM, Tango Eight wrote: Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products. The best place for further discussion would be the CNi forum. Thanks Evan Ludeman -- Dan, 5J |
Good thing I'm not the guy that writes the code ;-)
T8 On Saturday, May 18, 2019 at 9:56:12 AM UTC-4, wrote: 2359 - 0000z rollover. On Saturday, May 18, 2019 at 6:22:07 AM UTC-5, Tango Eight wrote: Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products. The best place for further discussion would be the CNi forum. Thanks Evan Ludeman |
Dan's flight ended 2304 per the log, so doesn't sound like any kind of
rollover problem. On 5/18/19 7:56 AM, wrote: 2359 - 0000z rollover. On Saturday, May 18, 2019 at 6:22:07 AM UTC-5, Tango Eight wrote: Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products. The best place for further discussion would be the CNi forum. Thanks Evan Ludeman |
Looking at your April 25 flight on SeeYou, the GPS altitude graph shows
tons of dropouts (down to 0 altitude). This is absolutely not corruption on a USB stick, the file would show as invalid with the CRC check if it were. It's the logger showing bad altitude numbers, and at least one out of order time stamp. If these problems correspond to the jamming, then not much you can do. But I wouldn't rule out interference from inside the cockpit, maybe even the two CN antennas mounted next to each other and interfering with each other. Stranger things have happened. -Dave On 5/17/19 11:40 AM, Dan Marotta wrote: LOL...Â* I predate Windows; PCs and Apples, in fact. I have separate sticks for each device.Â* It's hard to imagine that both would fail in the same manner. As soon as I get a chance to fly again, I'll try three different sticks.Â* Winds are currently around 20G30 kts.Â* I don't mind landing in that, but I see no need to take off until things settle down. Ah... Spring time in Moriarty... On 5/17/2019 10:47 AM, Charlie M. (UH & 002 owner/pilot) wrote: Could be a bad stick...... I am from the age of, "Whoa.....a 30mb USB stick.....you know how many 3.5" floppies this replaces!!!!" First field job.....user PC was Windows NT.....no Frikkin USB support.........sigh........ Today, big USB sticks are like cheap butane lighters......the stick is cheap (make sure to format in correct OS/software) so when not sure, recycle and buy new...... |
I've just replaced the two CN antennae with new, 28 dB gain antennae
with uncut coax leads.Â* They're mounted on opposite canopy rails, at least 3 ft apart.Â* It's gusting 25 kts at Moriarty right now and forecast up to 40.Â* I probably won't be flying today. On 5/18/2019 9:25 AM, kinsell wrote: Looking at your April 25 flight on SeeYou, the GPS altitude graph shows tons of dropouts (down to 0 altitude). This is absolutely not corruption on a USB stick, the file would show as invalid with the CRC check if it were.Â* It's the logger showing bad altitude numbers, and at least one out of order time stamp. If these problems correspond to the jamming, then not much you can do. But I wouldn't rule out interference from inside the cockpit, maybe even the two CN antennas mounted next to each other and interfering with each other.Â* Stranger things have happened. -Dave On 5/17/19 11:40 AM, Dan Marotta wrote: LOL...Â* I predate Windows; PCs and Apples, in fact. I have separate sticks for each device.Â* It's hard to imagine that both would fail in the same manner. As soon as I get a chance to fly again, I'll try three different sticks.Â* Winds are currently around 20G30 kts.Â* I don't mind landing in that, but I see no need to take off until things settle down. Ah... Spring time in Moriarty... On 5/17/2019 10:47 AM, Charlie M. (UH & 002 owner/pilot) wrote: Could be a bad stick...... I am from the age of, "Whoa.....a 30mb USB stick.....you know how many 3.5" floppies this replaces!!!!" First field job.....user PC was Windows NT.....no Frikkin USB support.........sigh........ Today, big USB sticks are like cheap butane lighters......the stick is cheap (make sure to format in correct OS/software) so when not sure, recycle and buy new...... -- Dan, 5J |
Similar Threads | ||||
Pearl Harbor in Art - 14 - wrong place wrong time.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | December 7th 17 02:23 PM |
What Is Wrong With OLC? | Dan Marotta | Soaring | 49 | February 2nd 17 03:54 AM |
What Is Wrong With OLC? | Dan Marotta | Soaring | 5 | June 15th 16 03:05 AM |
what went wrong | Dick[_1_] | Home Built | 14 | August 10th 07 03:48 AM |
what am I doing wrong | gt[_2_] | Aviation Photos | 8 | June 4th 07 01:49 AM |
