Autorotation ? R22 for the Experts
Here is a good question for the more experienced helicopter pilot or
mechanic. A friend of mine that flies a late model Robison R22 Beta II asked this question of a number of individuals and no one seem to have an explanation. This included people at the manufacturer. I believe I know the answer, however, I would like to put the question out and see what others think before tainting their thoughts with my ideas. So here is the question: With one person flying the R22 (170lb), simulating an autorotation by rolling off throttle, the collective goes full down and pretty-much stays there to maintain proper rotor rpm. With two people, same maneuver, some collective has to be pulled to keep the main rotor from over-speeding. The amount of collective will obviously vary dependent on a number of factors, but for this example let's say about 1 inch off the stop. One more time with the same maneuver, with two on board, except let the governor control engine speed, and not rolling off throttle. In order to maintain rotor speed the collective has to be on the stop. The question is why? Please post your thoughts. Thanks, Eric D |
In the first instance, you are not "simulating" an autorotation; with no
engine OR no engine power applied to the rotor (throttle rolled off) you are "performing" an autorotation. With the engine throttle left in a flight position, the governor is GOVERNING rotor R.P.M. due to it's linkage to the collective and the engine which is what under any circumstances what it ACTUALLY GOVERNS, and ONLY THEREFORE can govern your rotor R.P.M. SO...collective bottomed...engine "running", governor GOVERNS rotor R.P.M. NO engine running (or no throttle applied) YOU govern rotor R.P.M. The other variables you alluded to will include gross weight per fuel on board, etc. Bob |
"Bob" wrote in message ...
In the first instance, you are not "simulating" an autorotation; with no engine OR no engine power applied to the rotor (throttle rolled off) you are "performing" an autorotation. With the engine throttle left in a flight position, the governor is GOVERNING rotor R.P.M. due to it's linkage to the collective and the engine which is what under any circumstances what it ACTUALLY GOVERNS, and ONLY THEREFORE can govern your rotor R.P.M. SO...collective bottomed...engine "running", governor GOVERNS rotor R.P.M. NO engine running (or no throttle applied) YOU govern rotor R.P.M. The other variables you alluded to will include gross weight per fuel on board, etc. Bob One pob = collective fully down to maintain rotor speed. Two pob = collective not fully down to prevent overspeed. If helicopter is heavier will not the coning angle be greater and therefore the rotor speed higher because of less effective rotor diameter. Hence the need to pull some collective at heavier weight to slow blades and increase rotor disk diameter? Or maybe I'm talking b****x! It has been known!! Herbie |
Herbie...
YES. BUT...that wasn't the question. The question was given weight-throttle on vs. given weight-throttle off. Bob |
"Bob" wrote in message news Herbie... YES. BUT...that wasn't the question. The question was given weight-throttle on vs. given weight-throttle off. Bob I'm not sure I'm getting this either. The original poster was confused because, engine out of the equation, they had to "raise" the collective to prevent an overspeed. With the engine / governor still in the equation, they "didn't" have to raise the collective to prevent an overspeed. Now, if the collective is bottomed out and the MR blades are at an autorotative angle, wouldn't the rotor system try to outrun the engine / drive system? Or, is the engine acting as a brake in the situation, kind of like a car coasting downhill, using engine compressionas a brake? Just wondering? Fly Safe, Steve R. |
And come to think of it...actually NO. Collective down, there's no cone to
speak of or your rotor speed would be drooping. |
"Bob" wrote in message ... And come to think of it...actually NO. Collective down, there's no cone to speak of or your rotor speed would be drooping. No cone? I'm not sure I agree with that. Even with the collective all the way down, there's still positive lift being generated by the rotor system. Maybe the coneing angle isn't what it would be in steady state, powered flight but I'm not sure it's accurate to say that there's "no" coning with the collective full down. Fly Safe, Steve R. |
Steve...
Kindly read my post carefully. I said NO CONE TO SPEAK OF. As in...it would not to compare to the cone present when trying to yank the helicopter off the ground at Max Gross Weight. The lift generated with the collective down is what keeps your rate of decent an "autorotative" rate, rather at terminal velocity As to your other post...when the collective is down with no engine power (on a real helicopter) the pitch links are adjusted to keep the auto-R.P.M. within an acceptable RANGE. That is a standard maintenance function, but it dosn't mean the pilot can go to sleep during an auto. Collective down, if rpm is too high- it's not adjusted properly, but the pilot can jockey the collective. If its too low it's DEFINATELY not adjusted properly and rots o' ruck. In my first post in this string ALL I was trying (apparently not too clearly) to explain is that if the engine is running (at all) the governor knows it. I am a heavy helicopter maintenance type and can't even spell Robinson, BUT even the most "rudimentary" if you will, helicopters have to operate with some derivation of dynamic principles and proven hardware concept application. The bottom line is in an auto, to keep the rotor in the green right off. Too High is always better than Too Low because the pilot can fix that. Good luck, Bob |
First off, thanks to everyone that has responded to my original
posting. Bob, Your response was super, and I understood what you wrote. I believe what you described is right on the money for larger aircraft that you mentioned you worked on. The governor on the Robison R22 Beta II does not have linkage to the collective. The scenario I described in my original post is due to the sprag clutch. During low overrun speeds there is some drag through the sprag. As the overrun speed increase this drag decreases. To clarify, when speaking of overrun speed, it is the velocity across the sprag clutch, not rotor speed. I have limited helicopter maintenance experience on anything larger then a Robinson R44. I received my A&P in the early seventies and also have IA. I have worked on many types of aircraft over the years. My passion for Robinsons came about four years ago, so I'm still learning. I also have a fixed wing pilot's license and I have started working on learning how to fly an R22. I'm finding it a blast and I am really enjoying it. Thanks again for the great responses, Eric D |
And THANK YOU ERIC. Thought the dog ate ya, and I've been up to my ears
since I replied to your first question. Out of courtesy to the group, I'll still consider whatever aircraft you were addressing a, uhhhhhh, helicopter and leave the rest of this mess in your hands. If there was any help on my part, you're most welcome. Happy flying or whatever that contraption does |
Similar Threads | ||||
Are There Any P-47 Experts Out There Too? | Schlomo Lipchitz | Naval Aviation | 10 | February 15th 05 03:06 AM |
Advice and experts with 400 series Cessnas (414 and 421), purchase and training | [email protected] | Owning | 36 | January 9th 05 02:32 AM |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
aero-domains for homebuilt experts | secura | Home Built | 0 | June 26th 04 07:11 AM |
Aircraft Id needed from newsgp experts! | RGP | Military Aviation | 1 | January 1st 04 07:15 PM |
