#111
Turn to Final - Keeping Ball Centered
Dudley Henriques wrote in
: Bertie the Bunyip wrote: Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in : Roger wrote: On Wed, 12 Mar 2008 10:52:38 -0800, Jim Stewart wrote: Ken S. Tucker wrote: On Mar 12, 3:39 am, Dan wrote: On Mar 12, 2:18 am, "Ken S. Tucker" wrote: -- IGNORE BELOW -- Depends on the A/C, what were you flying? In an F-4 doing a 3-4g bank is easy, but in a trainer I'd suggest 2g max. Ken -- IGNORE ABOVE --- Assuming you're not flying an F-4 in a sim, we'll move on to reality.... This fear is (correctly) pounded into every aspiring/training pilot -- don't cross control stall on turn to final! A pilot is trained to do 2g coordinated turns, even in twink flying, gee I wonder why. It's a perfectly safe thing to do and IIRC was Perfectly safe if not close to the ground and the pilot is proficient ant not just current. a requirement for a pilot's license. Are you just making this stuff up as you go along? The Practical Test Standard requires the demonstration of a steep turn at 45 degree bank and a safe or recommended airspeed. That's as steep and high g as it gets and it's not going to be 2g in my plane. 2Gg turns are fun nor are they hazardous when not done close to the ground. When I took Bo specific training the instructor started talking me into a steep turn. I asked if it was OK to just roll into it and go. I He said "OK", so I just rolled left and pulled. Coming up on the proper heading he said now lets do one the other direction where by I rolled to the right and pulled. This brought a laughing comment, "You really like to do these things don't you?" My puzzled "sure", brought the explanation that most of the Bo pilots would only grudgingly do 45 degrees let alone 60. You should have heard them complain when told the instructors would be blocking the yokes so they couldn't use the ailerons when doing stalls.:-)) I've found few of newer pilots and instructors like 2G at 60 degrees or the stalling characteristics of the Deb so when I go out to practice it's only the "old timers" who go along. When I took the PTS it was 60 degrees and 2Gs. By not going to 60 degrees in steep turns the students miss out on the different banking tendencies/characteristics. I often think it should be put back to that. There have been moments where I've been glad they did things that way back then. One such moment was when a ultra light flying far later than allowed popped out of the dark directly in front of me when I was no more than a couple hundred yards (if that) from the end of the runway. Another was on the VOR approach to MtPleasant where you fly directly over the runway at 500 feet to the VOR to go missed on 27. When the instructor's voice went up an octave and he said and I quote..."What that...Oh, ****! Pull UP, Pull UP! I went full power, stood the Deb on end and did a push over to level off that left things floating. He never would tell me how close we came but from his actions I'd say probably no more than a few feet. BTW I did all of that under the hood. I mentioned to the CFI that I figured had it been really close he'd have taken over. He said he figured that I knew the limits of the plane and would react quicker than he could even if he could see. He was right though, The urgency (I couldeven feel him tense sitting next to me) told me that this should be a maximum effort and not just a climb. Made me glad I use 120 for approaches instead of 80 or 90 too:-)) Neither of these were things covered in primary training or the PTS. They took a lot of time and practice getting to know the limits of the Deb. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I agree. I had to do 60 degree banked turns for my Private as well. Sheesh. I can't remember what I had to do . I do remember spins, some hood time and an engine failure on takeoff. I also remember filing and putting in a cruising altitude of say, 3500 and then being so afraid to deviate from it I flew underneat an overcast at that alt with my fin in the clouds.. Bertie A lot has changed since those days. If I remember right, the requirement was for a 60 degree banked turn in both directions entering one from the other within an altitude parameter either way of 50 feet. Just racking my memory here but that sounds close.....and this was for the PRIVATE!! I really can't remember, but I do remember being surprised when instructing years later that i learned that many considered 45 deg to be steep, so I must have learned at 60 degrees as well. Bertie I'm sure you did. The problem with 45 degrees of bank is that it teaches little about control in steep banked attitudes such as shallowing the bank before raising the nose in a nose low condition caused by over bank. Yeah. OK. That makes sense. I've never liked the 45 degree parameter and have always recommended to instructors that they teach bank control all the way out to 60 degrees regardless of the requirement. This entire movement to make flying more "comfortable" for the masses to sell airplanes and push aviation by lowering the requirements has been flawed from the beginning in my opinion. Well, exactly. If I've flown with one pilot I've flown with a hundred who, when put in a 60 degree banked turn with the nose going down and being told to raise the nose, pulled instead of shallowing out the bank first, tightening up the nose low condition. It's a shame really, and I hate to see it. Hmm. I've never othought of steep turns as this sort of exercise. I've alwyas looked at them as keeping, rather than a regaining control type of thing, but I might try this with some of my guys if we ever get the damned airplane! You're sort of crossing over into the spiral dive lesson there. Not a bad thing... Bertie |
#112
Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in : Roger wrote: On Wed, 12 Mar 2008 10:52:38 -0800, Jim Stewart wrote: Ken S. Tucker wrote: On Mar 12, 3:39 am, Dan wrote: On Mar 12, 2:18 am, "Ken S. Tucker" wrote: -- IGNORE BELOW -- Depends on the A/C, what were you flying? In an F-4 doing a 3-4g bank is easy, but in a trainer I'd suggest 2g max. Ken -- IGNORE ABOVE --- Assuming you're not flying an F-4 in a sim, we'll move on to reality.... This fear is (correctly) pounded into every aspiring/training pilot -- don't cross control stall on turn to final! A pilot is trained to do 2g coordinated turns, even in twink flying, gee I wonder why. It's a perfectly safe thing to do and IIRC was Perfectly safe if not close to the ground and the pilot is proficient ant not just current. a requirement for a pilot's license. Are you just making this stuff up as you go along? The Practical Test Standard requires the demonstration of a steep turn at 45 degree bank and a safe or recommended airspeed. That's as steep and high g as it gets and it's not going to be 2g in my plane. 2Gg turns are fun nor are they hazardous when not done close to the ground. When I took Bo specific training the instructor started talking me into a steep turn. I asked if it was OK to just roll into it and go. I He said "OK", so I just rolled left and pulled. Coming up on the proper heading he said now lets do one the other direction where by I rolled to the right and pulled. This brought a laughing comment, "You really like to do these things don't you?" My puzzled "sure", brought the explanation that most of the Bo pilots would only grudgingly do 45 degrees let alone 60. You should have heard them complain when told the instructors would be blocking the yokes so they couldn't use the ailerons when doing stalls.:-)) I've found few of newer pilots and instructors like 2G at 60 degrees or the stalling characteristics of the Deb so when I go out to practice it's only the "old timers" who go along. When I took the PTS it was 60 degrees and 2Gs. By not going to 60 degrees in steep turns the students miss out on the different banking tendencies/characteristics. I often think it should be put back to that. There have been moments where I've been glad they did things that way back then. One such moment was when a ultra light flying far later than allowed popped out of the dark directly in front of me when I was no more than a couple hundred yards (if that) from the end of the runway. Another was on the VOR approach to MtPleasant where you fly directly over the runway at 500 feet to the VOR to go missed on 27. When the instructor's voice went up an octave and he said and I quote..."What that...Oh, ****! Pull UP, Pull UP! I went full power, stood the Deb on end and did a push over to level off that left things floating. He never would tell me how close we came but from his actions I'd say probably no more than a few feet. BTW I did all of that under the hood. I mentioned to the CFI that I figured had it been really close he'd have taken over. He said he figured that I knew the limits of the plane and would react quicker than he could even if he could see. He was right though, The urgency (I couldeven feel him tense sitting next to me) told me that this should be a maximum effort and not just a climb. Made me glad I use 120 for approaches instead of 80 or 90 too:-)) Neither of these were things covered in primary training or the PTS. They took a lot of time and practice getting to know the limits of the Deb. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I agree. I had to do 60 degree banked turns for my Private as well. Sheesh. I can't remember what I had to do . I do remember spins, some hood time and an engine failure on takeoff. I also remember filing and putting in a cruising altitude of say, 3500 and then being so afraid to deviate from it I flew underneat an overcast at that alt with my fin in the clouds.. Bertie A lot has changed since those days. If I remember right, the requirement was for a 60 degree banked turn in both directions entering one from the other within an altitude parameter either way of 50 feet. Just racking my memory here but that sounds close.....and this was for the PRIVATE!! I really can't remember, but I do remember being surprised when instructing years later that i learned that many considered 45 deg to be steep, so I must have learned at 60 degrees as well. Bertie I'm sure you did. The problem with 45 degrees of bank is that it teaches little about control in steep banked attitudes such as shallowing the bank before raising the nose in a nose low condition caused by over bank. Yeah. OK. That makes sense. I've never liked the 45 degree parameter and have always recommended to instructors that they teach bank control all the way out to 60 degrees regardless of the requirement. This entire movement to make flying more "comfortable" for the masses to sell airplanes and push aviation by lowering the requirements has been flawed from the beginning in my opinion. Well, exactly. If I've flown with one pilot I've flown with a hundred who, when put in a 60 degree banked turn with the nose going down and being told to raise the nose, pulled instead of shallowing out the bank first, tightening up the nose low condition. It's a shame really, and I hate to see it. Hmm. I've never othought of steep turns as this sort of exercise. I've alwyas looked at them as keeping, rather than a regaining control type of thing, but I might try this with some of my guys if we ever get the damned airplane! You're sort of crossing over into the spiral dive lesson there. Not a bad thing... Bertie Actually you're right on how you view the exercise. It is an exercise in maintaining control. What happens however, with the average pilot, especially those not trained in steep turns at around 60 degrees, is that invariably, pilots trying to maintain that 60 degree bank will allow the nose to get lower than the horizon line as they attempt to maintain and control the over bank. When this happens, the only way to correct and get the nose back tracking again on the horizon is to shallow out FIRST, then raise the nose back up where it belongs. Trying to solve the error by pulling the nose back up without shallowing first just takes the pilot deeper into the error. The secondary error that is most common is in not releasing the back pressure properly then reapplying it again as the turn is reversed. All in all, 60 degree banked turn to alternating sides is a wonderful training tool. These turns teach control pressure blending and coordination better than any other maneuver I've ever used . If a pilot can enter alternating 720's and perform the turns AND the transition through the reversal between them within a 50 foot altitude error parameter, they KNOW control pressure and can FLY the airplane! A side advantage to learning steep 720's VFR really comes in handy later on if a pilot goes into serious instrument training where recovery from nose low unusual attitudes requires correcting the bank first, then raising the nose........as I've always maintained and always will...it's the way you learn the basics that will determine how well you eventually will fly all through your career in aviation. -- Dudley Henriques |
#113
"Dudley Henriques" wrote: When this happens, the only way to correct and get the nose back tracking again on the horizon is to shallow out FIRST, then raise the nose back up where it belongs. I guess a little top rudder is right out, eh? The secondary error that is most common is in not releasing the back pressure properly then reapplying it again as the turn is reversed. All in all, 60 degree banked turn to alternating sides is a wonderful training tool. These turns teach control pressure blending and coordination better than any other maneuver I've ever used . If a pilot can enter alternating 720's and perform the turns AND the transition through the reversal between them within a 50 foot altitude error parameter, they KNOW control pressure and can FLY the airplane! You're on. That will be the drill for Saturday. I've done a lot of low/slow/steep flying lately on photo missions. Your drill should help. -- Dan T-182T at BFM |
#114
Dan Luke wrote:
"Dudley Henriques" wrote: When this happens, the only way to correct and get the nose back tracking again on the horizon is to shallow out FIRST, then raise the nose back up where it belongs. I guess a little top rudder is right out, eh Top rudder will produce a slipping turn but won't counteract the nose down tendency. It will also take you out of complimentary coordination and into slip which is undesirable in this instance. Remember, you're holding in back pressure to produce the turn. The bank absolutely has to be shallowed to the point where the nose can be raised as opposed to pulled down deeper into the error. When you are trying out these turns, try using top rudder when nose down and note the result. -- Dudley Henriques |
#115
On Mar 13, 12:55 am, WingFlaps wrote:
On Mar 13, 7:37 pm, "Ken S. Tucker" wrote: On Mar 12, 6:05 pm, "Owner" wrote: "Ken S. Tucker" wrote in ... On Mar 12, 12:31 pm, Gig 601XL Builder wrote: Ken S. Tucker wrote: and as it turned out the fella was gov qualified to license me, which he did. Ken Which one is you? Total Names found for KEN TUCKER is 22. KENNETH CARDEN TUCKER KENNETH EDWARD TUCKER KENNETH W TUCKER KENDALL JOHN TUCKER KENNETH EDWARD TUCKER KENNETH RAY TUCKER KENNETH W TUCKER KENNETH THOMAS TUCKER KENNETH RICHARD TUCKER KENNETH DALE TUCKER KENNETH E TUCKER KENNETH J TUCKER KENNETH JOHN TUCKER KENT HOWARD TUCKER KENNETH W TUCKER KENNETH WAYNE TUCKER KENT DAVID TUCKER KENT LEE TUCKER KENNETH ROYAL TUCKER KENNETH CLAYTON TUCKER KENNETH STEVEN TUCKER KENNETH HAROLD TUCKER LOL, thank you for your interest in me. I'm afraid I cannot post my license number off my old paper license for security reasons, and not my Mensa number either, or social security number, CIA file etc. , it's all classified. Yes, your psychologist did say all your information is classified, but I thought that was due to doctor/patient privileges u1= -sin H sin P cos R + cos H sin R u2 = cos H sin P cos R - sin H sin R u3 = cos P cos R Unit vector u is up, H is Heading, R is Roll, P is Pitch. Vectors A = G+L+T+D A is net acceleration, Gravity, Lift, Thrust, Drag. G = -1k. Is any of that familiar? If so, are the components of u correct? I'm also a student of aerodynamics. Nope. Forces don't equal acceleration LOL, does a "unit" mass shine a light? Ken |
#116
On Mar 13, 6:23 am, Dudley Henriques wrote:
Bertie the Bunyip wrote: Dudley Henriques wrote in : Roger wrote: On Wed, 12 Mar 2008 10:52:38 -0800, Jim Stewart wrote: Ken S. Tucker wrote: On Mar 12, 3:39 am, Dan wrote: On Mar 12, 2:18 am, "Ken S. Tucker" wrote: -- IGNORE BELOW -- Depends on the A/C, what were you flying? In an F-4 doing a 3-4g bank is easy, but in a trainer I'd suggest 2g max. Ken -- IGNORE ABOVE --- Assuming you're not flying an F-4 in a sim, we'll move on to reality.... This fear is (correctly) pounded into every aspiring/training pilot -- don't cross control stall on turn to final! A pilot is trained to do 2g coordinated turns, even in twink flying, gee I wonder why. It's a perfectly safe thing to do and IIRC was Perfectly safe if not close to the ground and the pilot is proficient ant not just current. a requirement for a pilot's license. Are you just making this stuff up as you go along? The Practical Test Standard requires the demonstration of a steep turn at 45 degree bank and a safe or recommended airspeed. That's as steep and high g as it gets and it's not going to be 2g in my plane. 2Gg turns are fun nor are they hazardous when not done close to the ground. When I took Bo specific training the instructor started talking me into a steep turn. I asked if it was OK to just roll into it and go. I He said "OK", so I just rolled left and pulled. Coming up on the proper heading he said now lets do one the other direction where by I rolled to the right and pulled. This brought a laughing comment, "You really like to do these things don't you?" My puzzled "sure", brought the explanation that most of the Bo pilots would only grudgingly do 45 degrees let alone 60. You should have heard them complain when told the instructors would be blocking the yokes so they couldn't use the ailerons when doing stalls.:-)) I've found few of newer pilots and instructors like 2G at 60 degrees or the stalling characteristics of the Deb so when I go out to practice it's only the "old timers" who go along. When I took the PTS it was 60 degrees and 2Gs. By not going to 60 degrees in steep turns the students miss out on the different banking tendencies/characteristics. I often think it should be put back to that. There have been moments where I've been glad they did things that way back then. One such moment was when a ultra light flying far later than allowed popped out of the dark directly in front of me when I was no more than a couple hundred yards (if that) from the end of the runway. Another was on the VOR approach to MtPleasant where you fly directly over the runway at 500 feet to the VOR to go missed on 27. When the instructor's voice went up an octave and he said and I quote..."What that...Oh, ****! Pull UP, Pull UP! I went full power, stood the Deb on end and did a push over to level off that left things floating. He never would tell me how close we came but from his actions I'd say probably no more than a few feet. BTW I did all of that under the hood. I mentioned to the CFI that I figured had it been really close he'd have taken over. He said he figured that I knew the limits of the plane and would react quicker than he could even if he could see. He was right though, The urgency (I couldeven feel him tense sitting next to me) told me that this should be a maximum effort and not just a climb. Made me glad I use 120 for approaches instead of 80 or 90 too:-)) Neither of these were things covered in primary training or the PTS. They took a lot of time and practice getting to know the limits of the Deb. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I agree. I had to do 60 degree banked turns for my Private as well. Sheesh. I can't remember what I had to do . I do remember spins, some hood time and an engine failure on takeoff. I also remember filing and putting in a cruising altitude of say, 3500 and then being so afraid to deviate from it I flew underneat an overcast at that alt with my fin in the clouds.. Bertie A lot has changed since those days. If I remember right, the requirement was for a 60 degree banked turn in both directions entering one from the other within an altitude parameter either way of 50 feet. Just racking my memory here but that sounds close.....and this was for the PRIVATE!! :-)) Dudley Henriques An instrument that was stressed for me during instruction was this, http://en.wikipedia.org/wiki/Attitude_indicator The 60 degree banked turn (IIRC), did require that 50' +/- altitude, keeping the ball centered, and maintaining a constant KIAS with some +power. When that 50' +/- requirement was spec'd by the instructor I got fixated on the "rate of climb" indicator. Well he smirked and sent my concentration to the attitude indicator and to learn to use that. Other pilots have mentioned the attitude indicator is the most important instrument. What do you guys think? Ken |
#117
On Mar 14, 4:36*am, "Ron A." wrote:
I didn't know at the time about turning more than standard rate on the coordinator, it was something I hadn't done when he requested it. *The peg is around 45 degrees or so. *I was also watching my airspeed for decay while maintaining level flight. *And I know you aren't supposed to use the feeling in your butt for instrument flight, but it I couldn't help it being a newbie to instrument flight. *I of course rely on the instruments when they don't agree with my body. I think something is not quite right here. I may have this wrong, but the TC doesn't indicate angle of bank at all. It's a rate instrument and indicates rate of roll and rate of turn (plus ball) -at least that's what I learnt. In that case where the peg is does not inicate angle of bank but rate of bank/turn Cheers |
#118
On Mar 13, 1:19 pm, "Ken S. Tucker" wrote:
An instrument that was stressed for me during instruction was this,http://en.wikipedia.org/wiki/Attitude_indicator The 60 degree banked turn (IIRC), did require that 50' +/- altitude, keeping the ball centered, and maintaining a constant KIAS with some +power. When that 50' +/- requirement was spec'd by the instructor I got fixated on the "rate of climb" indicator. Well he smirked and sent my concentration to the attitude indicator and to learn to use that. Other pilots have mentioned the attitude indicator is the most important instrument. What do you guys think? Ken We think it shows you have not had any training. PPL students are told to LOOK OUTSIDE during steep turn training, not to fixate on instruments. They need to see what the horizon is up to, not what instruments are indicating. A glance at the ASI and altimeter every few seconds is in order, but they're not to refer to the AI constantly for steep turns. We've had students who were all over the sky, chasing instrument needles, so we sometimes cover up the whole panel and make them do it by looking outside; the airplane settles down and behaves itself. Amazing. This is standard Canadian PPL curriculum, and the US wouldn't be much different. Dan |
#119
On Mar 14, 8:33 am, WingFlaps wrote:
I think something is not quite right here. I may have this wrong, but the TC doesn't indicate angle of bank at all. It's a rate instrument and indicates rate of roll and rate of turn (plus ball) -at least that's what I learnt. In that case where the peg is does not inicate angle of bank but rate of bank/turn Needle Rate of turn. Ball Balanced turn |
#120
On Wed, 12 Mar 2008 11:16:23 -0800, Jim Stewart wrote:
I hesitate to add to this discussion because I'm not an instructor, just a rather slow student who's not qualified to give advice that might kill someone. I hope this isn't copyrighted because I just stole it. -- Remove numbers for gmail and for God's sake it ain't "gee" either! I hesitate to add to this discussion because I'm not an instructor, just a rather slow student who's not qualified to give advice that might kill someone. |
Similar Threads | ||||
Implications of.....keeping the speed up | [email protected] | Instrument Flight Rules | 48 | January 14th 07 11:41 PM |
Gamepad, stopping throttle axis from being auto-centered | DenisK | Simulators | 1 | December 20th 06 09:16 AM |
Keeping a builders log | Lou | Home Built | 24 | January 28th 06 10:46 PM |
Thanks for ideas on drilling a centered hole! | Scott | Home Built | 12 | October 25th 04 02:52 AM |
Keeping Me Out of Your Warbird? | Stephen Harding | Military Aviation | 47 | February 12th 04 04:34 PM |
