W&B-Where do you Measure People Positions
I'm helping a chapter member do the initial weight measurements on his
plane. I think we have everything except what point should be used for the seat positions. I didn't see it addressed in the weight and balance section of AC 43.13. What point along the seat is considered the center of a sitting person? I know an inch or two either way won't make a bunch of difference, but we might as well start with the best number achievable. Thanks |
On Jan 31, 2:14*pm, "Paul Dow (Remove CAPS in address)"
wrote: I'm helping a chapter member do the initial weight measurements on his plane. I think we have everything except what point should be used for the seat positions. I didn't see it addressed in the weight and balance section of AC 43.13. What point along the seat is considered the center of a sitting person? I know an inch or two either way won't make a bunch of difference, but we might as well start with the best number achievable. Thanks Use the guy's belt buckle. It's pretty close. Dan |
Or you could weigh the aircraft without the pilot. Then with the pilot. Take the difference in the tailwheel weights and multiply it by the distance between the tail wheel and main mounts. Divide the product of the calculation by the pilot's weight. The result will be the distance from the main mount to the pilot seat.
See paragraph B in the W&B calculation near the bottom of the following link: http://www.soaridaho.com/Schreder/Sc...976_HP-18.html Wayne HP-14 6F http://www.tinyurl.com/N990-6F wrote in message ... On Jan 31, 2:14 pm, "Paul Dow (Remove CAPS in address)" wrote: I'm helping a chapter member do the initial weight measurements on his plane. I think we have everything except what point should be used for the seat positions. I didn't see it addressed in the weight and balance section of AC 43.13. What point along the seat is considered the center of a sitting person? I know an inch or two either way won't make a bunch of difference, but we might as well start with the best number achievable. Thanks Use the guy's belt buckle. It's pretty close. Dan |
"Wayne Paul" wrote in message m... Or you could weigh the aircraft without the pilot. Then with the pilot. Take the difference in the tailwheel weights and multiply it by the distance between the tail wheel and main mounts. Divide the product of the calculation by the pilot's weight. The result will be the distance from the main mount to the pilot seat. See paragraph B in the W&B calculation near the bottom of the following link: http://www.soaridaho.com/Schreder/Sc...976_HP-18.html Wayne HP-14 6F http://www.tinyurl.com/N990-6F --------------new post begins--------- Remember to first level the aircraft. Assuming that it is not an original design, there should be a recomended datum line specified for that purpose. (Also, please use the axle positions rather than the undercarriage mounting positions.) Peter |
Thanks for the replies everyone.
The scales were borrowed, so it would be difficult to get them back again to do the measurements. That procedure makes sense though. The belt buckle idea seems pretty good. The seats don't have much recline, so my big butt / fat head should balance each other out. Paul |
I had asked another friend this question, and he's a member of our
chapter, and the one in Hartford. Joe Gauthier (EAA Homebuilt Council) is also a member of the Hartford chapter, and Joe agreed that the belt buckle method was what should be used if we couldn't use the 'weigh the pilot while the plane's on the scales' method. Thanks again. Paul |
On Sun, 31 Jan 2010 16:14:32 -0500, "Paul Dow (Remove CAPS in
address)" wrote: I'm helping a chapter member do the initial weight measurements on his plane. I think we have everything except what point should be used for the seat positions. I didn't see it addressed in the weight and balance section of AC 43.13. What point along the seat is considered the center of a sitting person? I know an inch or two either way won't make a bunch of difference, but we might as well start with the best number achievable. Thanks anthropomorphically a seated pilots cg is about an inch aft of his belly button. as dan says use the location of his belt buckle. you wont detect the difference. Stealth Pilot |
Similar Threads | ||||
"Airplanes don't kill people!, people kill people!" | Laonork | Owning | 8 | May 21st 12 05:56 AM |
Glider Pilots Wanted - Worldwide Positions | [email protected] | Soaring | 15 | October 16th 07 01:45 AM |
Saving windows positions in FS2004??? | jmiguez | Simulators | 0 | May 4th 05 12:34 PM |
B-17 forward guin positions | zxcv | Military Aviation | 13 | March 16th 04 01:04 AM |
Air Force to cut 297 positions in Alaska, Hawaii, Guam | Otis Willie | Military Aviation | 0 | July 26th 03 09:05 PM |
