Aero engineer for designing homebuilt aircraft.
Old June 11th 10, 03:43 AM posted to rec.aviation.homebuilt
Default Aero engineer for designing homebuilt aircraft.
On Jun 7, 8:58*am, Stealth Pilot
On Sun, 6 Jun 2010 23:27:43 -0400, "Peter Dohm"
"cavelamb" wrote in message
Peter Dohm wrote:
-----------------snipped-----------------
OTOH, the balance problems are "interesting" because, although I have yet
to build my own project, I have seen a few interesting issues crop up in
kits as well as plans built aircraft. *The most glaring problem that I
Richard Lamb
I agree, and it all was several years ago; but I will definitely use your
nomenclatu *Static Stabiliby Augmentation System.
That's really outstanding!
Peter
The Auster J1B isnt a kit aeroplane. down in the tail there is a
location where the fuselage tubes form a "V" shape.
on each side of this V shape is some 1/8" steel riveted in position to
make a box.
in the standard aircraft there is a 10lb triangular lead weight bolted
in front of this "V".
if you put a metal prop on the aircraft instead of a wooden prop there
is a couple of pounds of lead in a triangular wedge to go in the box.
if you add the exhaust muffler on to the straight stacks there is
another triangular lead piece to go in the box.
all told I think there can be 21lbs of lead in the tail.
in flight you notice nothing if the CG is in the right place.
I wouldnt feel embarassed about some lead ballast to get the cg
correct. the aircraft will be a lethal trap if you dont get the cg
right. your passengers wont even see the lead so why worry about it.
of course if you make a second aircraft the way is open for some
tweaking to remove the need.
Stealth Pilot
That Auster would have been better served with a moveable
battery rather than more lead weights. Some small helicopters have a
moveable battery to balance the machine when the passenger is there or
absent.
Dan
Old June 11th 10, 04:50 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
On Jun 7, 8:58 am, Stealth Pilot
kits as well as plans built aircraft. The most glaring problem that I
Richard Lamb
nomenclatu Static Stabiliby Augmentation System.
Peter
make a box.
Stealth Pilot
absent.
Dan
What battery?
Richard Lamb
Old June 12th 10, 06:33 PM posted to rec.aviation.homebuilt
On Jun 10, 9:50 pm, cavelamb wrote:
What battery?
Did the J1B not have a starter?
Dan
Old June 13th 10, 03:31 PM posted to rec.aviation.homebuilt
Brian Whatcott
Stealth Pilot wrote:
/snip/
Dan
the armstrong starter does not need battery power. ...just the
occasional sherbert in the evening.
just in case there is a doubt, yes, the J1B not have a starter.
Gypsy Major series 10 mark 1 is the neddy.
Stealth Pilot
Doesn't that apply to the J5N too?
I flew both, but it was quite a while ago...
Brian W
Old June 14th 10, 03:18 AM posted to rec.aviation.homebuilt
On Jun 13, 7:22*pm, "Peter Dohm" wrote:
"Stealth Pilot" wrote in message
On Sat, 12 Jun 2010 10:33:38 -0700 (PDT),
What battery?
*Did the J1B not have a starter?
Dan
Stealth Pilot
I have no experience with any of the Gypsy engines; but it seems like I
heard that some used a "shotgun" type impulse starter--at least in the
military trainer versions.
Just curious.
Peter
I had an Auster AOP VI, and it had a starter. Engine was Gipsy Major
7, IIRC.
Dan
DARPA calls for help in designing submersible aircraft Charles Vincent Home Built 20 October 14th 08 05:45 PM
How to License Your Homebuilt Aircraft [email protected] Home Built 0 January 26th 05 04:11 PM
aero-domains for homebuilt experts secura Home Built 0 June 26th 04 07:11 AM
I'm STILL trying to ID a homebuilt aircraft Phillip Rhodes Restoration 1 November 27th 03 06:59 AM
I'm still trying to ID a homebuilt aircraft Phillip Rhodes Home Built 1 November 26th 03 08:43 PM
