Engine stoppage during idle
I would start by checking idle at start and at operating temp.
To me, revs should not have been 500 Tony C-GICE In article , Peter wrote: IO-540-C4, Socata TB20 Just got this today. Landed, taxied off the runway, and before doing the post-landing procedure (ie, with the mixture on full rich and the fuel pump still running) noticed the revs to be very low, c. 500 and then unsuprisingly the engine stopped. Initially I suspected the idle setting had got moved. Did a start (hot start, the usual lots of cranking) and all was fine. Idle is perfect at 700rpm, just the way it was set up by a very good Socata engineer a couple of years ago. Mag checks fine, EDM700 fine. Nothing special about the conditions. OAT +19C, DP +15C, 1hr flight at 2000ft. Enquiries suggest this sort of thing happens every once in a while. I just haven't had it in 500+ landings in this aircraft, so it is suprising. Any views would be much appreciated. I am considering having the fuel system inspected for debris/blockages. -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
Similar Threads | ||||
Centurion FAQ with kibbitzing | Bret Ludwig | Home Built | 0 | November 12th 05 10:39 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
