Dump The Navy's Version Of The JSF (F-35C?)
Old January 12th 10, 08:57 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Default Dump The Navy's Version Of The JSF (F-35C?)
""“I’m growing more and more convinced that the Navy variant of the
F-​​35
might not be worth buying. The program is sliding further and further
to
the right, as costs increase. When we have an 80 percent solution in
active production, and significantly cheaper, the F-​​35C looks like a
great
candidate for cancellation,” said one congressional aide."
See:
http://www.dodbuzz.com/2010/01/12/na...amid-jsf-woes/
Would the Navy be better off skipping the F-35, and using upgraded F/
A-18's
until UCAS-D, or some other solution, is ready?
Old January 12th 10, 09:14 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jack Linthicum
F-​​35
to
great
See:
A-18's
Back in the same day once again
No consequences in a life without an end
so you take the money and watch it burn
as it all goes up in flames
Until you realize what you got to learn
you'll make the same mistake over and over again
say goodbye to one more day
and another chance for you to change
spinnin' circles' round the sun
but tomorrow never comes
Old January 13th 10, 02:13 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Typhoon502
F-​​35
to
great
See:
A-18's
I'd go the other way around, dump the AF version and make the F-35C be
the only non-STOVL option, then put STOVL off until F-35C is up to
speed. But F-35 is probably going to go the way of the F-22 in any
case.
Old January 13th 10, 08:45 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
The Raven[_2_]
"Typhoon502" wrote in message
On Jan 12, 3:57 pm, wrote:
""?oI?Tm growing more and more convinced that the Navy variant of the
F-??35
to
active production, and significantly cheaper, the F-??35C looks like a
great
candidate for cancellation,? said one congressional aide."
See:
A-18's
case.
Agreed, the STOVL option is what's pushing up the overall per unit
design/manufacturer costs. Wait until the conventional models are well into
production (and where 90+% of the market is) then develop STOVL for those
with a harrier fixation.
Old January 15th 10, 05:12 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
hcobb
case.
An AF Lt wrote a paper about using the F-35C for short field
operations by setting up arresting wires, but I lost the link.
The problem with the F-35 is the tiny range. The F-35C is only
slightly longer ranged than the F-22.
Just look at the stats:
F-22, RCS of 0.0002 m^2, Combat radius: 410 nmi
F-35C, RCS of 0.0015 m^2, Combat radius: 640 nmi
Sukhoi PAK FA, RCS of 0.5 m^2, Combat radius: 800 nmi (Spots the
F-35 just outside of Sidewinder range and the F-22 just outside of
cannon range.)
-HJC
Old January 15th 10, 01:35 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
guy
F-​​35
to
great
See:
A-18's
case.- Hide quoted text -
- Show quoted text -
Just out of interest what are the benefits of the small wing on the A
model over the big wing on the C? (purely an airframe question,
nothing to do with equipment etc)
Guy
Old January 15th 10, 10:20 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
eatfastnoodle
F-​​35
to
great
See:
A-18's
Isn't the cost per unit for F35 already exceeds $100 million? How can
that price tag make F35 an "affordable" alternative for F22? And I
don't think it's realistic, budget wise, to expect the Pentagon to
really fulfill its contract of buying 2443 F35.
Why can't the French dump fuel? Robert M. Gary Piloting 77 October 28th 08 02:02 AM
F-111-Fuel-Dump%2C-Avalon%2C-VIC-23_03_2007.jpg [email protected] Aviation Photos 0 November 3rd 07 03:04 PM
Dump valve for Ls4a Robert Harvey Soaring 0 November 20th 05 08:47 PM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 02:21 AM
What is this? An ammo dump? TooPlaneCrazy7 Military Aviation 3 August 10th 03 01:29 AM
Copyright 2004-2024 AviationBanter.
