Intermittant CAI-302a shutdown?
I have been experiencing some intermittant CAI-302a shutdowns, before,
during, and after flights lately. Here's what I have been able to determine so far The shutdown appears to be associated with the CAI-302a sensing that it's input voltage is too low for normal operation. When I have been able to get the CAI-302 to display power supply voltage, I have seen numbers as low as 4.5VDC, but typically something like 8.8VDC, just before shutdown. Switching from the front to the aft battery does not change the low voltage reading. I have two brand-new Werker 12V lead-acid batteries, both religously charged with Battery-Minder Plus chargers, so it is hard for me to believe that *both* batteries could be loaded down to 8.8V from 12-13 volts without a *lot* of smoke and heat (none detected). I have eliminated as many loads as I can so far, leaving only the CAI-302a and my IPAQ 3955 PDA/Cradle (I have plans to eliminate the PDA & cradle, but haven't done it yet) The CAI-302a power/data cable appears to be secure at the 302 and at the power buss. I have not yet tried to measure the actual 12V battery voltage in flight, but that's on the list to do. Obviously, this will a PITA, but do-able. Any other thoughts? Anyone else ever have this problem? Regards, Frank (TA) |
Frank--
Does your radio show low voltage? Beckers and Dittles can show by various means. Do you have the backup battery? If the 302A provides for one you can easily rig it with (dare I say it) Radio Shack parts cheaply. If not--Allied Electronics sells small panel mout digital voltmeters inexpensively. Can give advance warning of trouble! Doubt both batts are bad, but it can happen. Check them on the bench with a 1 amp load. Probably the 302A is having internal problems. -- best regards Hartley Falbaum "Frank" wrote in message ... I have been experiencing some intermittant CAI-302a shutdowns, before, during, and after flights lately. Here's what I have been able to determine so far The shutdown appears to be associated with the CAI-302a sensing that it's input voltage is too low for normal operation. When I have been able to get the CAI-302 to display power supply voltage, I have seen numbers as low as 4.5VDC, but typically something like 8.8VDC, just before shutdown. Switching from the front to the aft battery does not change the low voltage reading. I have two brand-new Werker 12V lead-acid batteries, both religously charged with Battery-Minder Plus chargers, so it is hard for me to believe that *both* batteries could be loaded down to 8.8V from 12-13 volts without a *lot* of smoke and heat (none detected). I have eliminated as many loads as I can so far, leaving only the CAI-302a and my IPAQ 3955 PDA/Cradle (I have plans to eliminate the PDA & cradle, but haven't done it yet) The CAI-302a power/data cable appears to be secure at the 302 and at the power buss. I have not yet tried to measure the actual 12V battery voltage in flight, but that's on the list to do. Obviously, this will a PITA, but do-able. Any other thoughts? Anyone else ever have this problem? Regards, Frank (TA) |
Hartley, Excellent point regarding the radio as an independent check! I have a Dittel, and am familiar with it's low-voltage indications (blinking display), and I haven't noticed anything like this that correlates to the CAI-302 symptoms. Batteries have been checked multiple times, including long-term load curve analysis. Regards, Frankl On Sep 7, 10:25*am, "HL Falbaum" wrote: Frank-- Does your radio show low voltage? Beckers and Dittles can show by various means. Do you have the backup battery? If the 302A provides for one you can easily rig it with (dare I say it) Radio Shack parts cheaply. If not--Allied Electronics sells small panel mout digital voltmeters inexpensively. Can give advance warning of trouble! Doubt both batts are bad, but it can happen. Check them on the bench with a 1 amp load. Probably the 302A is having internal problems. -- best regards Hartley Falbaum "Frank" wrote in message ... I have been experiencing some intermittant CAI-302a shutdowns, before, during, and after flights lately. *Here's what I have been able to determine so far The shutdown appears to be associated with the CAI-302a sensing that it's input voltage is too low for normal operation. *When I have been able to get the CAI-302 to display power supply voltage, I have seen numbers as low as 4.5VDC, but typically something like 8.8VDC, just before shutdown. *Switching from the front to the aft battery does not change the low voltage reading. I have two brand-new Werker 12V lead-acid batteries, both religously charged with Battery-Minder Plus chargers, so it is hard for me to believe that *both* batteries could be loaded down to 8.8V from 12-13 volts without a *lot* of smoke and heat (none detected). I have eliminated as many loads as I can so far, leaving only the CAI-302a and my IPAQ 3955 PDA/Cradle (I have plans to eliminate the PDA & cradle, but haven't done it yet) The CAI-302a power/data cable appears to be secure at the 302 and at the power buss. I have not yet tried to measure the actual 12V battery voltage in flight, but that's on the list to do. Obviously, this will a PITA, but do-able. Any other thoughts? *Anyone else ever have this problem? Regards, Frank (TA)- Hide quoted text - - Show quoted text - |
I had a similar problem last year. It turned out to be an intermittent
antenna connection. On Sep 7, 7:31*am, Frank wrote: I have been experiencing some intermittant CAI-302a shutdowns, before, during, and after flights lately. *Here's what I have been able to determine so far The shutdown appears to be associated with the CAI-302a sensing that it's input voltage is too low for normal operation. *When I have been able to get the CAI-302 to display power supply voltage, I have seen numbers as low as 4.5VDC, but typically something like 8.8VDC, just before shutdown. *Switching from the front to the aft battery does not change the low voltage reading. I have two brand-new Werker 12V lead-acid batteries, both religously charged with Battery-Minder Plus chargers, so it is hard for me to believe that *both* batteries could be loaded down to 8.8V from 12-13 volts without a *lot* of smoke and heat (none detected). I have eliminated as many loads as I can so far, leaving only the CAI-302a and my IPAQ 3955 PDA/Cradle (I have plans to eliminate the PDA & cradle, but haven't done it yet) The CAI-302a power/data cable appears to be secure at the 302 and at the power buss. I have not yet tried to measure the actual 12V battery voltage in flight, but that's on the list to do. Obviously, this will a PITA, but do-able. Any other thoughts? *Anyone else ever have this problem? Regards, Frank (TA) |
Frank wrote:
I have been experiencing some intermittant CAI-302a shutdowns, before, during, and after flights lately. Here's what I have been able to determine so far The shutdown appears to be associated with the CAI-302a sensing that it's input voltage is too low for normal operation. When I have been able to get the CAI-302 to display power supply voltage, I have seen numbers as low as 4.5VDC, but typically something like 8.8VDC, just before shutdown. Switching from the front to the aft battery does not change the low voltage reading. I have two brand-new Werker 12V lead-acid batteries, both religously charged with Battery-Minder Plus chargers, so it is hard for me to believe that *both* batteries could be loaded down to 8.8V from 12-13 volts without a *lot* of smoke and heat (none detected). I have eliminated as many loads as I can so far, leaving only the CAI-302a and my IPAQ 3955 PDA/Cradle (I have plans to eliminate the PDA & cradle, but haven't done it yet) The CAI-302a power/data cable appears to be secure at the 302 and at the power buss. I have not yet tried to measure the actual 12V battery voltage in flight, but that's on the list to do. Obviously, this will a PITA, but do-able. Any other thoughts? Anyone else ever have this problem? Regards, Frank (TA) Frank, It may very well be the PDA. If the PDA is trying to charge the battery it may try to draw enough current through the 302 to cause the 302 to quit. I had this happen and was able to fix it by adding a box that was available (think cumulus soaring?) that passes the data through, but provides independant power to the PDA so that the 302 doesn't have to provide PDA power. If that's the problem, adding that box will fix it. Gary |
Frank:
Sorry--forgot one thing. Check the wiring---if slightly loose can get reduced (and of course) no voltage! The connector on the back of the 302 is a bit funky. -- Hartley Falbaum "Frank" wrote in message ... Hartley, Excellent point regarding the radio as an independent check! I have a Dittel, and am familiar with it's low-voltage indications (blinking display), and I haven't noticed anything like this that correlates to the CAI-302 symptoms. Batteries have been checked multiple times, including long-term load curve analysis. Regards, Frankl On Sep 7, 10:25 am, "HL Falbaum" wrote: Frank-- Does your radio show low voltage? Beckers and Dittles can show by various means. Do you have the backup battery? If the 302A provides for one you can easily rig it with (dare I say it) Radio Shack parts cheaply. If not--Allied Electronics sells small panel mout digital voltmeters inexpensively. Can give advance warning of trouble! Doubt both batts are bad, but it can happen. Check them on the bench with a 1 amp load. Probably the 302A is having internal problems. -- best regards Hartley Falbaum "Frank" wrote in message ... I have been experiencing some intermittant CAI-302a shutdowns, before, during, and after flights lately. Here's what I have been able to determine so far The shutdown appears to be associated with the CAI-302a sensing that it's input voltage is too low for normal operation. When I have been able to get the CAI-302 to display power supply voltage, I have seen numbers as low as 4.5VDC, but typically something like 8.8VDC, just before shutdown. Switching from the front to the aft battery does not change the low voltage reading. I have two brand-new Werker 12V lead-acid batteries, both religously charged with Battery-Minder Plus chargers, so it is hard for me to believe that *both* batteries could be loaded down to 8.8V from 12-13 volts without a *lot* of smoke and heat (none detected). I have eliminated as many loads as I can so far, leaving only the CAI-302a and my IPAQ 3955 PDA/Cradle (I have plans to eliminate the PDA & cradle, but haven't done it yet) The CAI-302a power/data cable appears to be secure at the 302 and at the power buss. I have not yet tried to measure the actual 12V battery voltage in flight, but that's on the list to do. Obviously, this will a PITA, but do-able. Any other thoughts? Anyone else ever have this problem? Regards, Frank (TA)- Hide quoted text - - Show quoted text - |
Similar Threads | ||||
Landing to shutdown - KJAN | [email protected] | Piloting | 0 | July 14th 08 01:46 AM |
CH-47D shutdown 2 | Paul[_3_] | Aviation Photos | 0 | June 12th 07 04:11 AM |
CH-47D shutdown | Paul[_3_] | Aviation Photos | 0 | June 12th 07 04:03 AM |
Precautionary Shutdown | Overlord | Aviation Photos | 0 | January 25th 07 01:01 AM |
Bush Prepares for Possible GPS Shutdown | Chris Gumm | Piloting | 74 | December 20th 04 05:48 PM |
