Killing the flagman at US Contest
Old June 29th 14, 10:04 PM posted to rec.aviation.soaring
Steve Koerner
Default Killing the flagman at US Contest
It hasn't happened yet, but we are going to kill or maim the flagman if we don't change our ways. It's just a matter of time.
This has become my personal pet peeve. Over the years, I have personally observed a lot of gliders drop a wing and veer off the runway. And admittedly a number of times my observation was from the driver's seat. My own launching technique is better now so my odds of staying on the runway are not as bad as they used to be. Yet, I know it can happen again. It can happen to anyone.
The matter of how to avoid wing drop is not what this writing is about. That's for another thread. This is about the fact that it does happen. This thread is about a potentially serious consequence when it does. Having a serious veer off the runway is an uncommon event for sure. It's one of those things where all goes well so often that it's easy to be neglectful of the low probability yet high consequence risk scenario that plays out at every contest launch.
We were all trained that there should be a safety cone in front of the glider when we launch. That being a zone in which there are no people or objects that have the potential to convert an embarrassing non-event into a small or large catastrophe. At US contests this important need for a safety cone is routinely overlooked. The flagman stands and does his work in a dangerous location in front of the launch.
Our contest flagmen are volunteers. I, for one, am very appreciative of all of the contest volunteers. Without the dedicated work of the volunteers, contests wouldn't happen. Certainly, there is a high obligation to not put volunteers at risk.
The manner by which a glider can come off the runway varies dramatically. Often, the affected pilot is faced with a real dilemma that plays out in a matter of seconds. A wing is low, perhaps dragging on the runway. He believes he can lift the down wing if he simply persists a bit and waits for airspeed to come up. In the mean time he's beginning to veer. If he releases early, the matter is low energy and low consequence. If he holds on for a little longer, he thinks he can raise the wing yet his speed is increasing and the potential for adverse consequences increase perhaps with the square of velocity. Should the pilot fail to get to the release quickly enough and the wing stays low, the resulting veer will be high energy. The veer off the runway can occur at speeds that can do real damage. I've seen it happen.
In my, thus far, unsuccessful efforts to change contest practice in this regard, I've spoken to several different contest operations managers and I've also spoken to flagmen about the issue. I'm routinely pooh-poohed. The flagman will tell me that he can run out of the way if a wing is coming at him. One flagman told me that he can jump over the wing if he needs to. But wait a minute... what if the wing that is coming at him is coming at 30 or 40 MPH? What if it happens to be the high wing that is coming at him or the fuselage?
What I observe at contests is that wing drops are sufficiently rare that the flagman always becomes complacent (assuming he or she is aware of the hazard in the first place). As the towplane and glider roar by, he'll be sipping from his water bottle while maybe sauntering a few step out of the way.
If it were the case that our flagmen were selected for sprinting ability and if their practice was to swing the flag then immediately begin sprinting for the sidelines then perhaps the present hazard wouldn't be. Yet, that is never what happens. Requiring a sprint from the flagman at every launch would be an unreasonable expectation for sure. At any rate, few would have the endurance strength and athleticism to do 30 to 50 successive 25 yard sprints in launch time summer heat.
It isn't as if there is no alternative to using a flagman for launch control. There is an alternative that works extremely well and puts no one at risk in the safety cone. The launch controller stands aside the sailplane with a handheld radio as the glider is being hooked up and readied for launch.. The launch controller gives particular radio commands to take up slack and then a particular distinctive word sequence command to commence the launch. Barb Smith, who's served as operations manager at a few Parowan contests in recent years, seems to have pioneered this method. This is really a very good scheme. There is no double communication required. The launch controller is in a position to easily observe the towline slack and also very well observe the readiness of the wing runner, the glider and the glider pilot too.
I urge that we adopt the radio method of launch control at US contests. Let's not wait until we've killed the flagman.
Old June 29th 14, 10:24 PM posted to rec.aviation.soaring
Gav Goudie[_2_]
I am staggered that it's still felt necessary to use a flagman/forward
signaller
when use of radio is so ubiquitous and the norm almost everywhere else?
we
don't change our ways. It's just a matter of time. =20
o=
admitted=
la=
not=
happe=
n to anyone. =20
Th=
This=
a
tho=
t=
eve=
ry contest launch. =20
glid=
objec=
smal=
c=
dan=
al=
volunteers,=
pu=
a
beli=
ai=
releas=
for=
increasi=
squ=
enoug=
vee=
it=
happen.
re=
I've=
f=
h=
B=
30
or=
the fuselage?
th=
haz=
sipp=
way.=
=20
an=
sprinting
i=
launch
have=
s=
prints in launch time summer heat.=20
contro=
ri=
wi=
launch=
slack
a=
laun=
conte=
really
launch=
v=
glide=
r pilot too. =20
Le=
Old June 30th 14, 04:54 AM posted to rec.aviation.soaring
It isn't as if there is no alternative to using a flagman for launch control. There is an alternative that works extremely well and puts no one at risk in the safety cone. The launch controller stands aside the sailplane with a handheld radio as the glider is being hooked up and readied for launch. The launch controller gives particular radio commands to take up slack and then a particular distinctive word sequence command to commence the launch. Barb Smith, who's served as operations manager at a few Parowan contests in recent years, seems to have pioneered this method. This is really a very good scheme. There is no double communication required. The launch controller is in a position to easily observe the towline slack and also very well observe the readiness of the wing runner, the glider and the glider pilot too.
I agree- mostly.
The mirror is adequate to know when to take up slack.
When the rope is tight- we're going flying.
Stop the launch- wing down.
Radio only when unusual happens.
UH
Old June 30th 14, 12:58 PM posted to rec.aviation.soaring
Gav Goudie[_2_]
I hope the full sequence includes the glider pilot releasing the rope
before the
wing goes down!
w=
e don't change our ways. It's just a matter of time. =20
=20
=20
=20
personally=
admitt=
own
n=
hap=
pen to anyone. =20
=20
=20
=20
Th=
Having
t=
of=
e=
very contest launch. =20
=20
=20
=20
gl=
obj=
sm=
safety=
d=
=20
=20
=20
of
volunteer=
not
=20
=20
=20
dramatically.=
in
be=
for
rele=
f=
increa=
s=
eno=
v=
seen
it happen.
=20
=20
=20
this
I'=
The=
at=
to.
3=
him
or the fuselage?
=20
=20
=20
that
h=
si=
wa=
y. =20
=20
=20
=20
ability
sprintin=
that=
launc=
ha=
yard=
sprints in launch time summer heat.=20
=20
=20
=20
cont=
at
sailplane
laun=
slack=
la=
con=
reall=
laun=
also=
gli=
der pilot too. =20
=20
=20
=20
I agree- mostly.
UH
Old June 30th 14, 01:32 PM posted to rec.aviation.soaring
before the
wing goes down!
Wing down is stop/hold. If tug pilot does not appear to respond, then release.
No need for stopping the operation to hook up again unless really needed.
Note this is a contest environment with pilots on the top of their game and not the local club operation.
UH
Old June 30th 14, 03:28 PM posted to rec.aviation.soaring
Gav Goudie[_2_]
So in effect the glider is now in a not ready to launch configuration (the
wing
is on the ground and probably being held there by the wing runner) yet
everything is primed to enable it to launch including the tug pilot who has
150 - 260hp available in an instant.
Unfortunately being at the top of ones game doesn't mitigate the risk that
could develop from the the above scenario and one could provide lots of
evidence where the competition environment can create extra pressure where
basic airmanship and experience evaporate in an instant.
I am all for an efficient launching machine in comps but you have to keep
basics in check, relying solely on a visual cue/clue isn't really using all
options that are available.
Typical parlance that seems to work on grid launches I have been involved
with as used by the launch marshall goes something like:
"Tug GC, next glider is Discus on the left hand side"
"Tug GC take up slack"
Or
"Tug GC take up slack and hold" (if a relight or a landing tug is on late
finals
etc)
"Tug GC all out, all out" or "STOP STOP STOP" (delete as appropriate)
The tug/towplane pilot has not had to respond to any of this, his or her
actions or rather lack of actions will alert the launch marshall that
he/she has
an issue or is unable to comply leaving them entirely focussed on
configuring
his tug for the launch and keeping his/her eyes moving around the sky, the
runway ahead and glider behind for any conflicts.
GG
(Comp Pilot & Towplane/Comp Towplane Pilot)
before the
wing goes down!
release.
and
UH
Old June 30th 14, 04:59 PM posted to rec.aviation.soaring
Brian[_1_]
Or
finals
etc)
I am not sure the system you are suggesting came across very well in your post.
I think you are saying that instead of using a signal relay person that you have a radio relay aka a Launch Marshall directing the tow plane.
It is probably a better idea than the signal relay person.
However the concern of course is to not clutter up the radio frequency so bad that aircraft (tow planes) in the pattern can't make adequate position reports with out stepping on each other transmissions.
Very doable, but all aspects of this procedure need to be considered for each site.
Brian
(Comp Pilot & Towplane/Comp Towplane Pilot) also.
Old June 30th 14, 05:23 PM posted to rec.aviation.soaring
Gav Goudie[_2_]
Messages get clipped and formatted badly here for some reason?
Brian,
Basically yes.
The launch marshall is in charge of the grid and he directs each tug to
each
glider and then away.
Most operations I have been involved with have a dedicated launch frequency
and with typically 10 towplanes, clutter is not an issue.
A thorough briefing on towing and recovery routes to/from the drop zone
(and use of similar performance aircraft) and other normal eventualities
(aborted tow/blocked runway etc) reduces the amount of required radio calls
to almost nothing in some cases. On airfields with limited space a little
bit of
inter-towplane RT keeps it all ticking.
And having good tow pilots and a capable launch marshall makes a big
difference to getting the grid away safely and efficiently.
GG
involved
Or
late
finals
etc)
post.
you
position
each site.
Brian
Old June 30th 14, 05:29 PM posted to rec.aviation.soaring
kirk.stant
I'm with Uncle Hank: The less chatter on the radio the less chance of a mistake, and leaves the radio available for emergencies ("RED PAWNEE 10 KNOTS FASTER!!!).
As a tuggie (and comp pilot) I prefer to base my decision to go on what I see, not on what someone else is directing (unless it's a STOP command, then It may be something I can't see) - and I can see if the rope is full out and the wings are level. At a comp, that's all I should need - the glider pilot ALWAYS has the option of releasing if he isn't ready!
In a club environment, add a nice rudder waggle, and all I really want the wing runner to do is watch for a problem and be prepared to stop the launch - I'm not going just because he thinks it time to fly!
On a related subject, I'm having a devil of a time convincing our club (non-comp, mainly also power pilots) glider pilots (including our friendly FAA reps!) to not stage at the very end of the runway, putting the initial part of the launch alongside other gliders, cars, spectators, dogs, etc. Aside from the problem of preventing the next gliders waiting to launch from gridding, the concept of a groundloop into the crowd seems inconceivable to these guys - and the usual answer is that they want all the runway available (we have a 2500' grass strip with good overruns and landable options in every direction).
Do other clubs have this problem? And how do you handle it, aside from stopping the launch and yelling at people (which is my usual response....).
Kirk
66
Old July 1st 14, 04:39 PM posted to rec.aviation.soaring
Dan Marotta
How about a light bar or light gun? Red - Stop/Hold, Yellow - Takeup
Slack, Green - GO!
Or car headlights? Steady on - Takeup Slack, Flashing - GO!
Now for my pet towing peeve: Takeup slack, STOP, GO. There's no need
to stop. The glider should be ready to launch when the rope is
attached. If the pilot needs more time, he should not have the rope
attached until he is ready. Or he should find another hobby. Rant off.
Dan Marotta
Kirk
66
Helicopter knocks out cable car, killing nine. Flyingmonk Rotorcraft 0 September 11th 05 12:44 AM
This is killing me!!! mindenpilot Piloting 109 February 5th 05 06:52 PM
I am in The Killing Zone Marco Rispoli Piloting 68 June 14th 04 05:16 PM
OT-Killing Pop-ups as a webmaster Jay Honeck Piloting 100 November 19th 03 10:25 PM
Car plows through market, killing 8 David Gunter Piloting 4 July 19th 03 09:04 AM
