Transponder installation article- Soaring Magazine
Old December 14th 20, 06:22 PM posted to rec.aviation.soaring
Default Transponder installation article- Soaring Magazine
Within the past 2-3 years, someone did a very nice article on installing a transponder, I believe it was a Trig21 or 22, in their DG303. I've searched but can't find the article/issue. Does anyone recall this or happen to know the issue?
Thanks
Old December 14th 20, 11:27 PM posted to rec.aviation.soaring
Dan Marotta
Thanks
I installed a Trig 22 in my Stemme and one in my gyroplane. It's
straight forward especially if you also buy a pre made harness. Simply:
1. Find a place and install the remote box.
2 Install the control head in the panel.
3 Connect the control head with the remote box using the purchased
cable. (You can make your own cable if you're handy with that, the
connectors and pins are included with the transponder.
4. Connect 12v and ground to the red and black (respectively) wires.
5. Connect the static line to the static ports using the supplied
T-fitting.
6. Install the antenna and connect the coax to the transponder
7. Power on and configure per the instructions.
If you're also installing ADS-B, it's even easier than the steps above:
1. Install the GPS,
2. Connect the GPS to the transponder. It's powered via the Y-cable
(ordered separately)
3. Mount the GPS antenna and connect the coax cable.
4. Power on and configure per the instructions.
Hope that takes the mystery out of it.
Dan
5J
Old December 14th 20, 11:54 PM posted to rec.aviation.soaring
kinsell
Thanks
http://ourdigitalmags.com/publication/?i=563086&p=34
Old December 15th 20, 12:15 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Thanks
T-fitting.
1. Install the GPS,
Dan
5J
I can supply custom length cables that power both the TT22 and TN72.
http://www.craggyaero.com/transponder.htm
Richard
www.craggyaero.com
Old December 15th 20, 01:02 AM posted to rec.aviation.soaring
2G
Thanks
T-fitting.
1. Install the GPS,
Dan
5J
To that list I will add one more item: you must get installation tested and inspected by an FAA approved avionics repair station with an entry to that effect made in the glider's logbook prior to use. This check must be repeated every 24 months.
https://www.law.cornell.edu/cfr/text/14/91.413
Tom
Old December 15th 20, 10:02 AM posted to rec.aviation.soaring
A few random notes from my TT22 installation:
- From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power."
-- A proven hazard demonstrated (luckily) by someone else
- Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on.
- If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed.
-- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers.
Old December 15th 20, 11:51 AM posted to rec.aviation.soaring
After installation and testing are complete, take a flight and the check your FAA performance report he
https://adsbperformance.faa.gov/PAPRRequest.aspx
Mine flunked the first time. I had one of the configuration settings wrong, but it was easily sorted out with information provided by Prof. Pfiffner:
http://www.craggyaero.com/tt22_tn72_settings.htm
Cheers,
...david
Old December 15th 20, 12:53 PM posted to rec.aviation.soaring
India November[_2_]
Cheers,
...david
- Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on..
I am thinking of installing a TRIG xponder for next season, maybe with ADS-B, but this would mean installing multiple GPS antennas (FLARM, C302, Xponder) and I'm running out of room under the glareshield.
Questions for the experts out the need there be a minimum spacing between GPS antennas (i.e. do they interact); and is there a way to connect one GPS antenna to feed one or more boxes?
Thanks!
Ian IN
Old December 15th 20, 04:56 PM posted to rec.aviation.soaring
Dan Marotta
Good information about the firmware. I had to send the control head for
the TT22 in the Stemme to the avionics shop for upgrade. There was no
charge for the service IIRC.
Dan
5J
Old December 15th 20, 05:15 PM posted to rec.aviation.soaring
Dan
5J
Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article.
Thanks
Maxim Magazine soaring article [email protected] Soaring 15 April 1st 17 05:40 PM
October Soaring magazine OLC League article Mark628CA Soaring 22 October 11th 14 05:51 PM
Need help locating article from Soaring Magazine Tim Taylor Soaring 1 March 26th 10 10:57 AM
Need help locating article from Soaring Magazine Tim Taylor Soaring 0 March 24th 10 01:20 AM
Subaru magazine soaring article JS Soaring 9 March 21st 08 03:41 AM
