#11
2 recent incidents
What is wrong wit a mandatory waving off the gliders at the end of the tow?
Wrong is that I, the glider pilot, want to decide where to be towed and when to release. Because I, the glider pilot, am in the air without an engine after the release. No tuggie, no matter how experienced he may be, will ever tell me when and where to release. |
2 recent incidents
On Jun 26, 8:20*am, John Smith wrote:
What is wrong wit a mandatory waving off the gliders at the end of the tow? Wrong is that I, the glider pilot, want to decide where to be towed and when to release. Because I, the glider pilot, am in the air without an engine after the release. No tuggie, no matter how experienced he may be, will ever tell me when and where to release. This attitude terrifies me as a tow pilot. If the tug pilot waves you off- GET OFF NOW! You do not know if there is an emergency. If you don't want to be waved off in lift, discuss with tug pilot, and his boss, if you wish, later. A tow pilot with a failing airplane does not have enough time or hands to deal with a stubborn glider pilot. Been There- done That UH |
2 recent incidents
Jim Logajan wrote:
Some silly ideas: Since the aircraft are attached anyway, one could just wrap the tow cable with a couple strands of wire and rig things so the tow pilot can press a button to zap the glider pilot, alerting them to check the spoilers. An aft facing bull horn on the tow plane rigged so the tow pilot can speak directly to the glider pilot sans radio ... and everyone else within a half mile. :-) How about setting up the equivalent of two tin cans and a string, with the tow rope as the string? Of course it will only work when it's taut, but if your spoilers are open then I imagine the rope would be pretty taut.... -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
2 recent incidents
As I think about it, it might be best if there was a single array of high output LEDs. *When both "colors" of the array are "on" then you have a single visible color that means "ok" (red and blue make green in concept, but in emitted light that combination doesn't work). *That way the glider pilot can verify at the start that both signals "work" and they stay "on" for the duration of the tow. *If either the "warning" or "get off" switches are selected in the cockpit then only the corresponding "color" is then visible to the glider pilot. *Perhaps with the "warning" being a steady signal and "get off" being a rapid flash to help with fast recognition and a sense of urgency. Other thoughts? People will misunderstand lights just as easily as a rudder waggle. Its a training issue and they just need to know what the signal means by practice. It takes a bit of time to learn and mistakes WILL be made but that is no reason to throw out the standard signals becasue of a few. Of the 10,000+ glider pilots I am sure only a couple dozen have released on rudder waggles. Thats 0.24%, and completely insignificant justification to change anything but the rigor of those few pilots training who are having problems. Lights fail, radios fail, tow plane electircal systems fail and a Wag or a Rock will still communicate with a glider on tow. The signal system works just fine, its just that the receivers of the signal are learning something new to them and sometimes mistakes are made. We should start a thread on Pilot Mistakes, and you can be sure there will be 1000 hr pilots making entires there as well. Ray |
2 recent incidents
On Jun 26, 8:25*am, jb92563 wrote:
As I think about it, it might be best if there was a single array of high output LEDs. *When both "colors" of the array are "on" then you have a single visible color that means "ok" (red and blue make green in concept, but in emitted light that combination doesn't work). *That way the glider pilot can verify at the start that both signals "work" and they stay "on" for the duration of the tow. *If either the "warning" or "get off" switches are selected in the cockpit then only the corresponding "color" is then visible to the glider pilot. *Perhaps with the "warning" being a steady signal and "get off" being a rapid flash to help with fast recognition and a sense of urgency. Other thoughts? People will misunderstand lights just as easily as a rudder waggle. Its a training issue and they just need to know what the signal means by practice. It takes a bit of time to learn and mistakes WILL be made but that is no reason to throw out the standard signals becasue of a few. Of the 10,000+ glider pilots I am sure only a couple dozen have released on rudder waggles. Thats 0.24%, and completely insignificant justification to change anything but the rigor of those few pilots training who are having problems. Lights fail, radios fail, tow plane electircal systems fail and a Wag or a Rock will still communicate with a glider on tow. The signal system works just fine, its just that the receivers of the signal are learning something new to them and sometimes mistakes are made. We should start a thread on Pilot Mistakes, and you can be sure there will be 1000 hr pilots making entires there as well. Ray What matters is the percentage of pilots that get a waggle and then release by mistake. Open spoilers on tow does not seem that common - so how many pilots per year get to see a rudder waggle? Clearly a signal system does not "work fine" if we are seeing multiple crashes and people getting killed - I assume you mean it could work fine if more pilots were better trained and proficient. So I agree with all that, but just becasue a radio might not work all the time is no reason not to try to have more operators and tow pilots adopt a procedure where if possible they use the radio first. Tow pilots also need to understand how apparently easy it is for glider pilots to screw up and if possible tow them to altitude before waggling. Not all tow pilots understand how apparently likely a waggle may be misunderstood - some tow pilots spend a lot of hours towing and it is easy for them to forget how less proficient the guy at the other end of the rope may be. As a community we need to stop saying things like "the waggle signal works fine", people are being killed and hurt. The reality is there probably needs a significant improvement in training of glider pilots and tow pilots to improve safety on this. Glider pilots recognizing signals, positive checks, including visual of spoilers, deliberate spoiler open on ground roll procedures, better understanding of tow pilot issues by glider pilots, better understanding of impacts of a low rudder waggle by the tow pilots, better use of radio where possible, improved BFR/spring checkouts to include actually demonstrating/practicing these things, etc. etc. Darryl |
2 recent incidents
jb92563 wrote:
It takes a bit of time to learn and mistakes WILL be made but that is no reason to throw out the standard signals becasue of a few. Rudder waggle wasn't a standard signal when I learned. During my first decade of flying (70s), rudder waggle was commonly used by tow pilots with newbies (like myself) to suggest a point of release. Of the 10,000+ glider pilots I am sure only a couple dozen have released on rudder waggles. I've done it, and I knew (in theory, anyway, what the signal was supposed to mean). Grob 103, spoiler not properly secured at takeoff (my bad), spoilers crept open during climb out, no dramatic sounds, buffeting, etc. I could tell the tow wasn't going right as we tuned at about 300 feet, continued slow climb rate as the tow pilot made a big sweeping back towards the airport. When we got back over the airport at 1000 ft, he wagged the rudder, and I, fulling expecting to be rocked off at any moment, pulled the release. The tow plane shot up like a rocket, a light bulb lit up in my brain, and I looked back to see the spoilers hanging out in the breeze. I think it clear what would have happened had I been wagged at 300 feet. Thats 0.24%, and completely insignificant justification to change anything but the rigor of those few pilots training who are having problems. I bet it's a lot more than 0.24%, I know of more than one tow pilot that is very careful where they use this signal, from experience. We should start a thread on Pilot Mistakes, and you can be sure there will be 1000 hr pilots making entires there as well. I had 1200 hours at the time. Marc |
2 recent incidents
John Smith wrote:
What is wrong wit a mandatory waving off the gliders at the end of the tow? Wrong is that I, the glider pilot, want to decide where to be towed and when to release. Because I, the glider pilot, am in the air without an engine after the release. No tuggie, no matter how experienced he may be, will ever tell me when and where to release. I can promise you, if, I were towing you, and you did not get off when I waved you off. You would be wearing the rope. I have done it before, and I still have lots more rope available to me. Aside, from that, I will normally take you where you want to go, but if, I want you gone, You will be gone. |
2 recent incidents
Wrong is that I, the glider pilot, want to decide where to be towed and when to release. Because I, the glider pilot, am in the air without an .... This attitude terrifies me as a tow pilot. If the tug pilot waves you off- GET OFF NOW! You do not know if there is an emergency. If you don't want to be waved off in lift, discuss with tug .... You can misunderstand everything if you really want to, can't you. Somebody suggested to wave off the glider at the end of *every* tow. My answer was that in a *normal* tow, it's the glider pilot who says where and how hight the tow goes. Period. Because he will have to deal with the release and because he will pay the tow. Of course *in an emergency*, the tow pilot has every right to wave me off. More precisely, in a true emergency, I wouldn't even expect him to wave me off but rather to just release his end of the rope. |
2 recent incidents
jb92563 wrote:
As I think about it, it might be best if there was a single array of high output LEDs. Details snipped... Other thoughts? People will misunderstand lights just as easily as a rudder waggle. Its a training issue and they just need to know what the signal means by practice. Details snipped... Lights fail, radios fail, tow plane electircal systems fail and a Wag or a Rock will still communicate with a glider on tow. The signal system works just fine, its just that the receivers of the signal are learning something new to them and sometimes mistakes are made. We should start a thread on Pilot Mistakes, and you can be sure there will be 1000 hr pilots making entires there as well. Ray Panacea fixes...what a panacea it would be if a few of them actually worked. (WARNING: Dry humor nearby.) Some pertinent realities... - Perfection is never an option. - Panacea fixes aren't. - Thought processes matter. - Training is good, too. Here's a thought process that has worked for me...so far. Being fairly simple-minded, I struggle with remembering rules for rules' sake. I compensate by a reasonably decent ability to remember WHY certain rules/guidelines/suggestions exist...and I seek to prioritize things I DO remember. (I care little about remembering trivia; I care a LOT about remembering 'important stuff.') Here's a couple of soaring examples: 1) Visual tow signals (work all the time, unless being towed in [*really*] hard IFR) - In life and death terms, a strong argument can be made that only one need be remembered, the wing-rock signal. None of the others are indicative of (immediately) life-threatening (to you or the tuggie) situations. Can't remember what a rudder waggle (or any other arcane/new/untrained-for/yet-to-be-devised) signal is for? No problem! It's NOT the dreaded wing-rock...so no precipitate action is necessary. Heck, you could even turn on the radio and ask, if your Embarrassment Quotient hasn't been exceeded on that particular tow. 2) Landing pattern mistakes - THE one boo-boo practically guaranteed to kill you in a landing pattern is the inadvertent stall/spin. I deal with that not by trying to remember all of the books'-worth of advice out there (mostly useful and sensible and germane), but by a combinatorial thought approach: a) Kid(s) - don't DO that (i.e. the inadvertent uncoordinated pattern stall)!!! b) Pay attention to Rule a). Everything else rule-based falls out in the wash...requisite pattern speed, requisite pattern coordination, requisite pattern pattern, etc... 3) Soaring-in-general - Soaring is real safe as long as you don't hit anything (hidden assumption...that you don't want to hit). For what it's worth, I can't recall learning any of the above from any of my (generally excellent) instructors (and the comment is not intended to be in any way derogatory or condescending). Nevertheless, I'm happy with the (36-year) results-to-date. I did yank off on my (sole) wing-rock received. I haven't inadvertently stalled in the pattern. I haven't inadvertently hit anything I wasn't already intentionally aiming at. Nor have I (yet) seen a rudder waggle...but if I DO see one, I'm pretty certain I'm not going to yank off for mis-interpretational reasons... Respectfully, Bob - VRAM-limited - W. |
2 recent incidents
Just this past Sunday I had a glider's spoilers open on tow just after
takeoff. ASW-19, behind the Pawnee I was flying, in Illinois, so not a real problem - and easily solved with a quick radio call. I'm a big fan of radios - and try to make radio contact with every glider I tow before takeoff. When I fly club ships that aren't radio equipped, I have my handheld clipped to my harness, with a hand speaker-mike at hand, and try to establish contact with the tow pilot before launching. Easy, quick, safe. That being said - we still need the standard signals as backups, and everybody (on both ends of the string) need to think about them. Good flight review material. Along with proper use of radios! I confess, I had the spoiler problem solved by radio before I even thought of the proper rudder waggle signal! Probably a good thing, since we were at 500' at the time, and the glider's stick actuator was a bit rushed at the time (second flight on type, I think). Kirk 66 |
Similar Threads | ||||
NTSB Accidents & Incidents | john smith[_2_] | Piloting | 33 | August 23rd 07 08:43 PM |
Aviation incidents | [email protected] | Piloting | 2 | June 22nd 06 06:45 AM |
Looking for (recent, I believe) article about Va | Andrew Gideon | Piloting | 4 | October 29th 04 03:06 PM |
IGC-approvals, recent changes | Ian Strachan | Soaring | 3 | January 5th 04 06:48 AM |
U.S. won't have to reveal other friendly fire events: Schmidt's lawyers hoped to use other incidents to help their case | Otis Willie | Military Aviation | 0 | December 18th 03 08:44 PM |
