Cutting aircraft cable?
How do I cut 3/16" stainless steel aircraft cable? I've tried
wirecutters, tin snips, airplane sheers, and a branch lopper. Tough stuff! |
"Stubby" wrote in message ... How do I cut 3/16" stainless steel aircraft cable? I've tried wirecutters, tin snips, airplane sheers, and a branch lopper. Tough stuff! You need a dedicated cable/wire rope cutter. http://www2.northerntool.com/product-1/200308983.htm |
"John Kunkel" wrote: "Stubby" wrote in message ... How do I cut 3/16" stainless steel aircraft cable? I've tried wirecutters, tin snips, airplane sheers, and a branch lopper. Tough stuff! You need a dedicated cable/wire rope cutter. http://www2.northerntool.com/product-1/200308983.htm A big hammer and a sharp chisel against an anvil will work, too. -- Remove _'s from email address to talk to me. |
Orval Fairbairn wrote:
In article , "John Kunkel" wrote: "Stubby" wrote in message ... How do I cut 3/16" stainless steel aircraft cable? I've tried wirecutters, tin snips, airplane sheers, and a branch lopper. Tough stuff! You need a dedicated cable/wire rope cutter. http://www2.northerntool.com/product-1/200308983.htm A big hammer and a sharp chisel against an anvil will work, too. Ah. The big hammer solution. I like that. Thanks. |
Stubby wrote:
Orval Fairbairn wrote: In article , "John Kunkel" wrote: "Stubby" wrote in message ... How do I cut 3/16" stainless steel aircraft cable? I've tried wirecutters, tin snips, airplane sheers, and a branch lopper. Tough stuff! You need a dedicated cable/wire rope cutter. http://www2.northerntool.com/product-1/200308983.htm A big hammer and a sharp chisel against an anvil will work, too. Ah. The big hammer solution. I like that. Thanks. Yes! that one appeals to me too...must be a man thing eh?... -- -Gord. "I'm trying to get as old as I can, and it must be working 'cause I'm the oldest now that I've ever been" |
Orval --
A quick question from somebody who farms that part of the job out when it has to be done...since the end doesn't take any of the tension of the cable, what would be wrong with torching it and then nicropressing it outside of the torched area? Jim A big hammer and a sharp chisel against an anvil will work, too. -- Remove _'s from email address to talk to me. |
On Fri, 17 Jun 2005 13:31:38 -0700, "RST Engineering"
wrote: Orval -- A quick question from somebody who farms that part of the job out when it has to be done...since the end doesn't take any of the tension of the cable, what would be wrong with torching it and then nicropressing it outside of the torched area? Jim Doing things the boring, conventional way has a benefit: reducing the unknowns. Brian W. |
"RST Engineering" wrote: Orval -- A quick question from somebody who farms that part of the job out when it has to be done...since the end doesn't take any of the tension of the cable, what would be wrong with torching it and then nicropressing it outside of the torched area? Jim The problem is -- you just don't know how much of the cable has been heat-damaged that way. I have used the hammer/chisel and it works. Make sure that you have a good, sharp chisel (and a big hammer). A big hammer and a sharp chisel against an anvil will work, too. -- Remove _'s from email address to talk to me. -- Remove _'s from email address to talk to me. |
In article , "RST Engineering" wrote: Orval -- A quick question from somebody who farms that part of the job out when it has to be done...since the end doesn't take any of the tension of the cable, what would be wrong with torching it and then nicropressing it outside of the torched area? Jim The problem is -- you just don't know how much of the cable has been heat-damaged that way. At the risk of agreeing with Jim here I'll venture to say "Sure you do...only the 'ends' are heated and those are inside the clamped areas at the 'ends' of the cable..." -- -Gord. "I'm trying to get as old as I can, and it must be working 'cause I'm the oldest now that I've ever been" |
"RST Engineering" wrote in message ... Orval -- A quick question from somebody who farms that part of the job out when it has to be done...since the end doesn't take any of the tension of the cable, what would be wrong with torching it and then nicropressing it outside of the torched area? Stainless steel does not burn in oxygen like carbon steel does. You can CUT stainless steel with a plasma torch or with an abrasive disk cutoff saw. With an oxy-acetylene torch you could MELT the stainless cable (and blow the melted metal away as opposed to burning away like carbon steel) and you may be able to fuse the ends of the cable as is often done with regular wire rope. Since stainless is normally welded inside an inert atmosphere (argon or helium), you should expect less than perfect results if fusing the end of the cable in an oxygen atmosphere. Some people use solder or silver solder(brazing) to seal the cable ends and contain the jagged ends. Stainless does not conduct heat as well as regular steel so it will stay hot longer but will not conduct the heat as far down the cable as regular wire rope. You could stop the heat traveling very far by quenching in water or oil. YMMV and I doubt that it is approved as per EA-AC 43.13-1A&2A An abrasive disk cutoff saw and a blob of 5 min. epoxy would be the easiest and would solve worries about the heat affected zone, or just put an extra nico over the jagged ends. Blue skies to all. |
Similar Threads | ||||
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
