Canadians Abandon 1000-point Scoring
Simple and elegant.
Could we add 15 minutes to everyone's time? running, ducking and grinning..... "Bill Feldbaumer" wrote in message m... The Canadians have been experimenting with a new scoring system for soaring contests. They will abandon 1000-point scoring with all its inaccuracies and complexities in 2004. Scoring will be based on distance with the exclusive use of the Time Distance Task. snip With the TDT, the CD specifies a flight time, 3 hours, for example. Some number of mandatory turnpoints is specified. Pilots are free to choose their own turnpoints after that. The CD could also specify a radius around the turnpoints, as is done with the Turn Area Task. The distance achieved by each pilot three hours after his start time is his score. A pilot may be in the air, at the home airport, or have landed out when his time is up. Land outs are scored the same as finishers, by distance; no arbitrary factors are needed. A bonus is given for landing at the home airport. The cumulative scores are simply the sum of the daily distances. The champion is the pilot with the greatest distance for the entire contest. Because the total flight time is a fixed number for the entire contest, the champion also has the highest speed for the total contest. This is, of course, how champions are chosen in other racing sports worldwide. snip |
It might be simple and elegant but, like the other
new type tasks, what it scores certainly isn't a race as the term is understood by the rest of the world who aren't glider pilots. John Galloway At 20:18 23 September 2003, 303pilot wrote: Simple and elegant. Could we add 15 minutes to everyone's time? 'Bill Feldbaumer' wrote in message om... The Canadians have been experimenting with a new scoring system for soaring contests. They will abandon 1000-point scoring with all its inaccuracies and complexities in 2004. Scoring will be based on distance with the exclusive use of the Time Distance Task. snip With the TDT, the CD specifies a flight time, 3 hours, for example. Some number of mandatory turnpoints is specified. Pilots are free to choose their own turnpoints after that. The CD could also specify a radius around the turnpoints, as is done with the Turn Area Task. The distance achieved by each pilot three hours after his start time is his score. A pilot may be in the air, at the home airport, or have landed out when his time is up. Land outs are scored the same as finishers, by distance; no arbitrary factors are needed. A bonus is given for landing at the home airport. The cumulative scores are simply the sum of the daily distances. The champion is the pilot with the greatest distance for the entire contest. Because the total flight time is a fixed number for the entire contest, the champion also has the highest speed for the total contest. This is, of course, how champions are chosen in other racing sports worldwide. snip |
Bill Feldbaumer wrote:
the Time Distance Task (TDT) has been approved by the International Gliding Commission for use in competitions. In fact there is no more TDT in IGC rules (see version 2002 of Annex A) - it's now called "Distance task" - but there *is* in the Annex A, of course, the possibility to choose the kilometer scoring system instead of 1000 pts. Joerg Stieber wrote: There is one disadvantage: * For an optimized flight, the pilot has to have converted as much energy as possible into distance at time-out. This leads to pilots timing out low in the vicinity of the contest site (to take advantage of the 10% home bonus) and wobbling with minimal energy over the fence. (Karl Striedeck was quick to point this out). We are looking at solutions, i.e. reduction of the home bonus to 5% for arrivals under 500 ft, timing-out as soon a pilots descend below 1000 ft agl (or an equivalent pre-defined MSL altitude) before finishing. In the Annex A there is already a possibility to avoid such a problem, by setting a minimum "finish" MSL altitude (minimum altitude at time-out - if a pilot happen to be lower than this altitude, only his last fix above it counts). And there is also a option to give a malus (20% of distance) to pilots who don't fly back home after the time-out - this is another incentive not to "finish" too low at time-out. I'm happy to see that such a system has been used with success in nationals. I see two main advantages to the distance scoring, by respect to the 1000 points system : - it gives more importance to longer tasks, which are usually with the best weather, and less importance to the shorter, in the poor weather, where luck is more important - it enhances the fact that gliders flew long distances (for the public or media) -- Denis Private replies: remove "moncourrielest" from my e-mail address Pour me répondre utiliser l'adresse courriel figurant après moncourrielest" dans mon adresse courriel... |
John
As a Canadian, forced to fly using this flawed system for the last two Canadian Nationals I have flown, I couldn't agree with you more. On a less extreme side (and more typical of the systems mass mentality for those who chose not to chance having to thermal from low altitude to get home after timeout) here are some other flaws: 1. The optimum finish, assuming you make it home before the timeout, is to head off to a few close in turnpoints and plan it so that you are on course line, at 0 MaCready for home airport, at timeout. This is extremely UNSAFE. It leads to many finishers coming back to the home airport from a low energy final glide from all directions. I remember a day at Rockton were we had about 4 gliders finish without a circuit from four directions. 2. To solution proposed for the flaw of many finishers from many directions at low energy, was simply to try to force everyone to timeout before they got back to the home area (I guess then you only have a lot of low energy finishes from the same direction). The winners, in this case, were the ones who got the closest to home at timeout which required the least altitude to make it home at 0 MaCready. The other poor folk were almost penalised by having to have the extra altitude (at least 1300 feet per 10 miles they were behind) to make it home from timeout. What actually happened was that, in almost every case after this solution was proposed, (due to difficult task planning requirements of this) the winners made it home before timeout anyway. There are other flaws but, as you can see I am not a proponent of this system. Dale Kramer K1 Minor disadvantage or fatal flaw? Actually, the optimal flight ends at minimum altitude as far downwind of the contest site as you dare. Then, scratch back home, arriving just as the sun goes down. (Not just opinion here, but reports from the last club class worlds.) The contest becomes a crapshoot about whether you pull this off or not. The min altitude doesn't really help; even a save from 1000' 30 miles downwind late in the day is a chancy proposition, but a contest-winning strategy. Then, there's the question, just how much wind does it take before it's advantageous to go straight downind and ignore the bonus points? More math problems, and a great task for motorgliders! The basic total distance scoring would be very attractive, if only giders didn't land out every now and then. For now, no one has solved this basic flaw in the system. John Cochrane |
Regarding the new Canadian scoring/tasking system: So far we've heard praise based on theory, objections based on theory, and objections based on experience. The only thing that's missing is praise based on experience. Is there anyone out there who has been scored using this system and who likes it? |
Pat Russell wrote:
Regarding the new Canadian scoring/tasking system: So far we've heard praise based on theory, objections based on theory, and objections based on experience. The only thing that's missing is praise based on experience. Is there anyone out there who has been scored using this system and who likes it? You're mixing two different issues : - the tasking system - use of distance tasks : ALL objections in this thread were about tasks, or more eactly task setting (because there were better ways to solve the issue of low finishes, such as setting a minimum altitude). Task setting raise a lot of objections too in usual racing tasks ! - the scoring system - use of distance scoring, which consist to score not on 1000 points, but on the maximum distance flown - if I refer to the title of this thread, this is what we should be speaking about ;-) Of course the distance scoring is better suited to tasks in a designated time (either "distance" or "speed" tasks in IGC Annex A terminology), but it may also be used for Racing tasks. And Distance tasks are been widely used, including in Worlds, with the 1000 points system and the same potential inconvenients that have been discussed in this thread - plus one : the minimum finish altitude is a good solution in areas where you find few outlanding areas but high cloudbases ; it's a bad choice if set too high in areas with good fieds everywhere but poor weather when you are barely able to fly above the minimum altitude ! -- Denis Private replies: remove "moncourrielest" from my e-mail address Pour me répondre utiliser l'adresse courriel figurant après moncourrielest" dans mon adresse courriel... |
tango4 wrote:
That's simply a non starter. Lets say you space the starts at 2 minute intervals, in a field of 40 the last guy to start has 39 thermal markers ahead of him. The first starter is 120km away on a medium competirion day. Even I could gain 20 places given those conditions. Gaggling or more precisely leeching has been the subject of many threads here and, I've no doubt, at IGC meetings and around every club bar. We haven't found a solution yet! except if the start is in the order of the overall standings (first first) and if the order at the finish line determines the new overall ranking... no leching, easy to understand for the public, and suspense up to the last day guaranteed ! -- Denis Private replies: remove "moncourrielest" from my e-mail address Pour me répondre utiliser l'adresse courriel figurant après moncourrielest" dans mon adresse courriel... |
Similar Threads | ||||
Revisiting lapse rates (From: How high is that cloud?) | Icebound | Instrument Flight Rules | 5 | November 26th 04 09:41 PM |
Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 01:48 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
new TASKs and SCORING - or roll the dice | CH | Soaring | 0 | August 10th 03 07:32 AM |
