Tost Rings
Old November 10th 14, 11:12 PM posted to rec.aviation.soaring
Scott Calvert[_3_]
Default Tost Rings
This weekend we found a tost ring that was split. It was difficult to
see because the rope was rapped around the split. From the looks
of it, it had been split for a long time. I do not know how old the
ring is or when it actually failed. Take a few minutes and inspect
your rings!
I would post a photo, but I am not sure how.
Safe Soaring,
Scott
Old November 10th 14, 11:51 PM posted to rec.aviation.soaring
Bill D
Default Tost Rings
your rings!
Safe Soaring,
Scott
Upload the photo to a photo site and then post a link here.
Old November 11th 14, 04:14 AM posted to rec.aviation.soaring
Bill T
Default Tost Rings
I found a split Tost ring last year. The larger of the two was split. The give away was the sound, more tinny higher pitch when you jingle the rings.
It had been in use for a while on pavement, so we could not see a serial number on the ring. No number, it's not a true Tost ring.
BT
Old November 11th 14, 05:52 AM posted to rec.aviation.soaring
Scott Calvert[_4_]
Default Tost Rings
The
the rings.
serial
BT
We operate on grass.
Old November 11th 14, 06:30 AM posted to rec.aviation.soaring
Frank Whiteley
Default Tost Rings
your rings!
Safe Soaring,
Scott
We had a ring break a few years ago at a CAP flight academy. It was found while winch launching. I don't have the rings, but they were purchased through a known vendor. The academy leader was to follow-up with the vendor but passed away, so I don't know if there was any resolution.
Frank Whiteley
Old November 11th 14, 11:17 AM posted to rec.aviation.soaring
Eric Munk
Default Tost Rings
Check if they are conform LN65091, or if they are cheaper welded ring. The
latter have a tendency to fail and cause significantly more wear than the
Tost rings.
Towing Schweizer Gliders with tost rings? [email protected] Soaring 12 December 22nd 10 04:59 AM
TE Probe O-rings vontresc Soaring 1 May 7th 10 12:56 AM
Dual tow rings brianDG303[_2_] Soaring 0 November 28th 09 02:06 AM
Dual tow rings brianDG303[_2_] Soaring 1 November 27th 09 11:15 PM
Libelles & Tost Rings nowhere Soaring 9 July 21st 04 05:08 PM
