#11
Duo Turbo Climb / Altitude performance
I fly a Ventus CM which uses the same basic SOLO engine block. The
major problem I have with higher flights is the progressive over rich mixture at altitude ( there is no mechanism for leaning.) I have climbed to 12,000 but started with marginally lean carburator jet settings. I think John Lubon (who also flys a CM) told me he was able to get to the 14,000 ft. published service ceiling by setting the mixture so lean on the ground that the engine would only run with partial choke! One technique I don't recommend is to try to lean by partially closing the fuel shut of valve. I managed to burn a cylinder trying this trick. BTIZ wrote: Thanx Walter.. I take it you are referring to the DuoT "Walter Kronester" wrote in message ... To supply some real world data: At density altitudes from around 3500 ft to 7000 ft I got between 250 and 300 fpm with 170 lbs pilot weight and 180 - 230 fpm with (2 persons) 380 lbs (no additional water). (VSI-Output, no precise measurement, but in correlation with altimeter data). Theese values were very similar in two different airplanes. I think this climb rate is really acceptable for a sustainer only engine, but please do never expect to escape from a downwash with a sustainer engine. A glide ratio of 16 seems realistic for me with the engine extended but not running. So before extending the engine look out for an emergency field near by. I hope this helps Walter Kronester PS: I love this bird! |
At Boulder we had a DG808B & my DG500M this past Summer. The DG808B
seems to outperform the Pawnee by most everyone's estimation probably regularly beating 500fpm on the 8500 DA typicall day as quoted below, thats without water but still very impressive to watch and very quiet. My DG500M doesn't do as well as the 808 but has less power and much more weight. Looking through my notes where I actually recorded data I see on July 10 at Boulder (1V5) approx 5300MSL, 88F, Baro 30.01, 9 minutes to shutdown at 8300 ft. Probably a minute of that was with the engine idling before shutdown. So about 375fpm actual but I was solo. A few weeks before that flying dual with my buddy Rolf at Gallup NM dual climb rates at DA of about 10k looked to be about 300fpm. From the logger traces no averages below 250fpm nor any above 400fpm dual over a week with typicall DA 10k. Without checking all the data (aren't loggers cool ?) it feels like the DG500M gets better climb performance on its own then when behind the 180HP Super Cup but not as good as the 235HP Pawnee. It also feels that weight makes more of a difference then DA. I have never self launched my DG below Boulder's field elev nor fly in cooler weather so can't really comment on the other side of the spectrum. Though I read (maybe on the Aux Sailplane Assc news group or the DG owner site) that the flapped ships do much better. It is interesting that DG had problems certifying the new non-flapped DG-1000 as a self launcher and for now its only available as a "turbo" like the Duo Discus. I follow the manual and climb at flaps +10degrees at Vy 49kts. Graham Beasley DG-500M Hotel Golf home.comcast.net/~grahambeasley/dg4sale BTIZ wrote: Now that is an interesting data point... I'd be interested in others also.. If that DuoT can't climb above 6500ft MSL at better than 150fpm, then I would not even attempt a takeoff out here in the summer time. Airport Elev, 2833MSL, Baro 30.00, Temp 100F, puts the DA at 6000ft. Granted there can be found a thermal right on the runway to assist, but there is also strong down near strong up. Another favorite launch site, at 5500MSL, Baro 30.00 and 90F puts the DA at 8500, even if the temp is still only 80F, the DA is 7940. I've noticed a DG500M on the market that flies regularly out of Colorado, would the seller care to offer some data points? Maybe the DG808B? BT "Gary Emerson" wrote in message news Greetings, Looking for some real world data on what the max altitude that a Duo T can sustain level flight. Would also be nice to know what sort of climb performance people have seen at lower altitudes. I know it'll climb to 6500ft MSL and average around 150 FPM, but hoping to get more data points. Gary |
At 00:54 27 November 2005, Walter Kronester wrote:
To supply some real world data: At density altitudes from around 3500 ft to 7000 ft I got between 250 and 300 fpm with 170 lbs pilot weight and 180 - 230 fpm with (2 persons) 380 lbs (no additional water). (VSI-Output, no precise measurement, but in correlation with altimeter data). Theese values were very similar in two different airplanes. I think this climb rate is really acceptable for a sustainer only engine, but please do never expect to escape from a downwash with a sustainer engine. A glide ratio of 16 seems realistic for me with the engine extended but not running. So before extending the engine look out for an emergency field near by. I hope this helps Walter Kronester PS: I love this bird! If your Duo T is giving those climb rates you should be very happy:-) |
Though I read (maybe on the Aux Sailplane Assc news group or the DG owner site) that the flapped ships do much better. It is interesting that DG had problems certifying the new non-flapped DG-1000 as a self launcher and for now its only available as a "turbo" like the Duo Discus. I follow the manual and climb at flaps +10degrees at Vy 49kts. Graham Beasley DG-500M Hotel Golf home.comcast.net/~grahambeasley/dg4sale DG have always intended to produce a selflaunch DG 1000. It is going to have the flapped wing for the reason above. They are just searching for the right engine. I think they prefer to go a four stroke at the 60 to 80 hp mark. ( If you know of one that would suit let them know :-) The turbo version is a result of asking customers what they would prefer/buy. Paul |
John Galloway wrote:
Even with zero rate of climb in the US midwest then if the Duo T engine is started at a safe altitude then the likelyhood of an off-airfield landing will be considerably reduced - it just might not be the home airfield:-) With my self-launcher, I usually (but not always) consider 1000' agl a safe altitude to start the engine . In the situation you describe, what would you consider a "safe altitude"? High enough to fly level to the airport, or would you count on some climb along way, or ? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Have a look at the real DDT data from IGC files.
I have a few available via these links: http://www2.onlinecontest.org/olcphp...&ein_name=1355 and http://www.onlinecontest.de/olcphp/2...&ein_name=1355 In SeeYou you can put markers at the begin and at the end of the climb on engine power and SeeYou will calculate the average rate of climb. At lower altitudes the avarage rate of climb is about 0.9 meter/second when you maintain the speed at the blue mark (95 kph). The best thing is to fly a DDT as a pure glider, always within gliding distance from an outlanding field or airfield. When getting lower I usually configure the glider for landing, position it on a downwind position with the gear down. I start the engine at that position. If the engine does not start I continue the landing. Also after engine start you have to be able to be able to survive an engine failure. This means that at low altitude with the engine running you have to stay within gliding distance (engine out) of a landing field. Ruud. On Fri, 25 Nov 2005 23:18:44 GMT, Gary Emerson wrote: Greetings, Looking for some real world data on what the max altitude that a Duo T can sustain level flight. Would also be nice to know what sort of climb performance people have seen at lower altitudes. I know it'll climb to 6500ft MSL and average around 150 FPM, but hoping to get more data points. Gary |
Similar Threads | ||||
Metric Instruments | Roy Bourgeois | Soaring | 29 | May 27th 13 01:53 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
