LS3A flap/aileron mixer
I got laser cut templates and accurately marked the neutral point and deflection limits. Worked great.
Roger on the 20 which is even better because you have the end of the aileron as a reference and the flap/fuselage fairing as another reference point. I have found adjustments that were made to stop a turning tendency by cranking one aileron up or down to stop the turn, but that doesn’t work! Both ailerons will equal out the new setting by flying up (or down) a tad and the turn remains. The only way to stop a turn is by installing a small trim tap, bent up or down in the direction indicated.
JJ |
Or with eccentric wing carry through pins, as a few ASW 19s required back in the late 1970s. They altered one wing's angle of incidence. Or maybe both.. They apparently brought the two wings more into alignment. I've never understood how the main spar pins still went in. I suppose the adjustment was very small and one wing was very slightly twisted. Anyone recall this?
Chip Bearden JB |
Similar Threads | ||||
Rolladen- Schneider LS3A flap seals- Do they really make any difference? | [email protected] | Soaring | 0 | April 8th 18 05:44 AM |
Rolladen- Schneider LS3A flap seals- Do they really make anydifference? | Dan Marotta | Soaring | 0 | February 19th 18 04:39 PM |
Rolladen- Schneider LS3A flap seals- Do they really make any difference? | [email protected] | Soaring | 9 | February 19th 18 01:50 AM |
FA: M18B Dromader Flap & Aileron | BFC | Aviation Marketplace | 0 | September 24th 04 04:29 PM |
Flap/aileron don't line up -- always a problem? | Ben Jackson | Owning | 4 | April 13th 04 01:53 AM |
