Ka-6 TE Probe
Or buy a vario with electronic compensation and forego the probe all
together. John Cochrane BBG |
Ka-6 TE Probe
I had a nice vertical fin installation on my Ka-6E. Roger Frank did the work. It was quite "spendy"; however, worked great. (http://www.soaridaho.com/photogallery/valley/Ka-6E.jpg) Wayne HP-14 "6F" http://'www.soaridaho.com/Schreder wrote in message ... On Aug 28, 12:24 pm, vontresc wrote: Take the time to put it in the fin. This keeps it out of the wing root wash and will make the variometer reflect what the glider is doing instead of how it responds to effect of gusts on wing root. It may be easier than trying to work as far behing wing root as it should go. Just put one in a K-21 fin and it is MUCH better than aft fuselage. Good Luck UH |
Ka-6 TE Probe
Like JJ said
If you want to do it easy and perfectly adequate as well, install a nearly vertical tube ahead of the canopy near the bulkhead ahead of the instrument panel (above the static buttons on the side of the fuselage). I would suggest angling it slightly forward at the top so that the tube is about perpendicular to the upwash induced by the wing. The top of the tube could be about 6-8" outside the fuselage. Plug the top end and put the hole or holes or slots in the back of the tube as drirected from your favorite article by Oran Nicks' (Nicks tube) or Dick Johnson or insert other favorite name here. The plumbing is short, easy to do, and will give a reading that is well compensated. Our club Ka6CR has one like this and it works well. I would not suggest over the wing in the turtledeck, since it could require uncoupling and coupling the pressure tube with some regularity and it would be easy to damage when the turtledeck is off. The position on top of the fuselage near the trailing edge of the wing, however is not a bad one. The flow around the wing is nearly back to a freestream static condition at the trailing edge and the flow had better be attached while cruising or thermalling or there are other problems. If one flys slow enough to separate the flow there, the inboard wing is already stalled and that's flying too slow. ...... Neal JJ Sinclair wrote: Eric wrote....... So, I'd suggest trying the very easiest thing first: a TE probe mounted on the removable turtledeck, probably towards the rear it. If it works, great; if not, very little effort wasted. Yeah, what he said......................I used a vertical TE probe on my Duster a hundred years ago and it worked as good as I did. If your intimidated my the thought of drilling and stringing tubes, go the easy way, it can be mounted forward of the canopy where there isn't any interference with the wings. Wings & Wheels sells them and I believe the top bent portion in set to be vertical with the ship set in flying position (W&B level) JJ |
Ka-6 TE Probe
On Aug 28, 7:05*pm, Neal Pfeiffer wrote:
Like JJ said If you want to do it easy and perfectly adequate as well, install a nearly vertical tube ahead of the canopy near the bulkhead ahead of the instrument panel (above the static buttons on the side of the fuselage). * I would suggest angling it slightly forward at the top so that the tube is about perpendicular to the upwash induced by the wing. *The top of the tube could be about 6-8" outside the fuselage. *Plug the top end and put the hole or holes or slots in the back of the tube as drirected from your favorite article by Oran Nicks' (Nicks tube) or Dick Johnson or insert other favorite name here. *The plumbing is short, easy to do, and will give a reading that is well compensated. *Our club Ka6CR has one like this and it works well. I would not suggest over the wing in the turtledeck, since it could require uncoupling and coupling the pressure tube with some regularity and it would be easy to damage when the turtledeck is off. The position on top of the fuselage near the trailing edge of the wing, however is not a bad one. *The flow around the wing is nearly back to a freestream static condition at the trailing edge and the flow had better be attached while cruising or thermalling or there are other problems. If one flys slow enough to separate the flow there, the inboard wing is already stalled and that's flying too slow. ..... Neal JJ Sinclair wrote: Eric wrote....... So, I'd suggest trying the very easiest thing first: a TE probe mounted on the removable turtledeck, probably towards the rear it. If it works, great; if not, very little effort wasted. Yeah, what he said......................I used a vertical TE probe on my Duster a hundred years ago and it worked as good as I did. If your intimidated my the thought of drilling and stringing tubes, go the easy way, it can be mounted forward of the canopy where there isn't any interference with the wings. Wings & Wheels sells them and I believe the top bent portion in set to be vertical with the ship set in flying position (W&B level) JJ- Hide quoted text - - Show quoted text - If objective is just simple installation, do what JJ says and put it on the nose. Putting it anywhere close to the flow field of the wing- that is anywhere near the top, means that the local pressure changes every time you change angle of attack. This is the reason why it is on the fin on essentially all modern gliders. UH |
Ka-6 TE Probe
The fin is not the only location for good compensation.
A total energy probe works best when the flow passes by it at nearly the same angle and at nearly freestream static pressure for the range of speeds of interest. Mounting in front of the fin puts the probe in a location that is close to the freestream static pressure. The flow angularity may vary some amount, but the combination of glider angle of attack and the downwash field of the wing will tend to reduce the overall variation in flow angle. Changing flap position will induce a step change in flow angle, but again this is not too large. Mounting the probe on the top of the fuselage a little aft of the wing again puts the probe in a region that is close to freestream static pressure and the straightening effect of the wing and fuselage produce only a very small change in the flow angle at the probe. Now, what about the forward fuselage? For a Ka6, the static buttons are on the side of the fuselage at the bulkhead ahead of the instrument panel, where they register near the freestream static value for the thermaling and cruise conditions. On the top of the forward fuselage, the canopy will slow the flow at its base, producing higher than freestream static pressure, and then rapidly accelerate the flow as it moves up and over the curved portion of the canopy, thus producing a lower than freestream pressure. By placing the probe at the bulkhead ahead of the panel, it is enough ahead of the canopy disturbance to have a pressure value that is close to freestream, but possibly with more variability than for the other two locations mentioned above. The pitch flow angularity is pretty constant though. For the Ka6 with the speeds mostly between 40 to 70 knots, the forward position is reasonable. ...... Neal wrote: - Show quoted text - If objective is just simple installation, do what JJ says and put it on the nose. Putting it anywhere close to the flow field of the wing- that is anywhere near the top, means that the local pressure changes every time you change angle of attack. This is the reason why it is on the fin on essentially all modern gliders. UH |
Similar Threads | ||||
TE Probe on ASW-15 | [email protected] | Soaring | 4 | April 29th 07 01:43 AM |
More on CHT probe replacement | Jim Burns | Owning | 12 | September 1st 05 10:45 PM |
Replacement JPI EGT probe | Robert M. Gary | Owning | 4 | July 16th 05 02:28 AM |
Replacement JPI EGT probe | Robert M. Gary | Piloting | 4 | July 16th 05 02:28 AM |
TE-Probe for 1-26D | Heinz Gehlhaar | Soaring | 6 | January 17th 05 10:52 PM |
