Wing De-Icing Question
Hello,
I guess de-icing is going to be a popular subject. Question, please: On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob |
"Robert11" wrote in message ... Hello, I guess de-icing is going to be a popular subject. Question, please: On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Hot bypass air from the engines is what they use, in general. I have to admit I do not know it the 787 is going to go truly all electric, or still use hot engine air to heat the wings. Once you get up to airliners of a larger size, the use of boots is not common. In smaller turbine commuters, and in piston planes, (especially pistons) there is not enough heat produced to heat wings. -- Jim in NC |
On Feb 13, 1:44*pm, "Robert11" wrote:
Hello, I guess de-icing is going to be a popular subject. Question, please: *On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob Jets don't typically have boots. Most use hot air stollen from the engines to heat the leading edges. Some use a "leak" system to drip anti-freeze like solution on the tail surfaces to avoid having to plumb the hot air to the rear, although this is less common. I'm not sure that I woudl call the type of plane that crashed less modern than a 767 considering by-pass jet engines (the type in a 767) have been around longer than turbo prop engines that were involed in this recent crash. -Robert |
On Feb 13, 3:36*pm, "Robert M. Gary" wrote:
On Feb 13, 1:44*pm, "Robert11" wrote: Hello, I guess de-icing is going to be a popular subject. Question, please: *On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob Jets don't typically have boots. Most use hot air stollen from the engines to heat the leading edges. Some use a "leak" system to drip anti-freeze like solution on the tail surfaces to avoid having to plumb the hot air to the rear, although this is less common. I'm not sure that I woudl call the type of plane that crashed less modern than a 767 considering by-pass jet engines (the type in a 767) have been around longer than turbo prop engines that were involed in this recent crash. -Robert The more I hear about this, the more it sounds like tailplane icing. Take a look at http://video.google.com/videoplay?do...23060735779946 for a NASA produced video on the subject. Note that this flight started its plunge right at or after the outer marker. The outer marker is where you normally lower gear and flaps. Lowering flaps is the thing that causes the tailplane stall if the tailplane is iced up. K l e i n |
"Robert11" wrote in
: Hello, I guess de-icing is going to be a popular subject. Question, please: On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? on flight, generally, not at all. On most jets, only the wings and engines have anti or de-icing and it's accomplished by bleeding hot air out of the compressor section of the engines. The engine anti ice is used frequently, but wing de icing is seldom used simply because ice seldom forms on the wings in flight. There is no deicing for the tops of the wings in jets. Bertie |
"Morgans" wrote in
: "Robert11" wrote in message ... Hello, I guess de-icing is going to be a popular subject. Question, please: On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Hot bypass air from the engines is what they use, in general. I have to admit I do not know it the 787 is going to go truly all electric, or still use hot engine air to heat the wings. Once you get up to airliners of a larger size, the use of boots is not common. In smaller turbine commuters, and in piston planes, (especially pistons) there is not enough heat produced to heat wings. yes, there is. there have been many pistons with hot wings, fjukkwit. Bertie |
K l e i n wrote in
: On Feb 13, 3:36*pm, "Robert M. Gary" wrote: On Feb 13, 1:44*pm, "Robert11" wrote: Hello, I guess de-icing is going to be a popular subject. Question, please: *On commercial jet airliners like, e.g., a 767 or 7 57, is there any in-flight deicing system for the wing and tail surfaces, othe r than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob Jets don't typically have boots. Most use hot air stollen from the engines to heat the leading edges. Some use a "leak" system to drip anti-freeze like solution on the tail surfaces to avoid having to plumb the hot air to the rear, although this is less common. I'm not sure that I woudl call the type of plane that crashed less modern than a 767 considering by-pass jet engines (the type in a 767) have been around longer than turbo prop engines that were involed in this recent crash. -Robert The more I hear about this, the more it sounds like tailplane icing. Take a look at http://video.google.com/videoplay?do...23060735779946 for a NASA produced video on the subject. Note that this flight started its plunge right at or after the outer marker. The outer marker is where you normally lower gear and flaps. Lowering flaps is the thing that causes the tailplane stall if the tailplane is iced up. Rubbish. Bertie |
On Feb 13, 4:44*pm, "Robert11" wrote:
Hello, I guess de-icing is going to be a popular subject. Question, please: *On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob There's a very good chance the Boston crash might have been tailplane icing. DH |
On Feb 14, 9:12*pm, Bertie the Bunyip wrote:
K l e i n wrote : On Feb 13, 3:36*pm, "Robert M. Gary" wrote: On Feb 13, 1:44*pm, "Robert11" wrote: Hello, I guess de-icing is going to be a popular subject. Question, please: *On commercial jet airliners like, e.g., a 767 or 7 57, is there any in-flight deicing system for the wing and tail surfaces, othe r than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob Jets don't typically have boots. Most use hot air stollen from the engines to heat the leading edges. Some use a "leak" system to drip anti-freeze like solution on the tail surfaces to avoid having to plumb the hot air to the rear, although this is less common. I'm not sure that I woudl call the type of plane that crashed less modern than a 767 considering by-pass jet engines (the type in a 767) have been around longer than turbo prop engines that were involed in this recent crash. -Robert The more I hear about this, the more it sounds like tailplane icing. Take a look at http://video.google.com/videoplay?do...60735779946for a NASA produced video on the subject. Note that this flight started its plunge right at or after the outer marker. *The outer marker is where you normally lower gear and flaps. Lowering flaps is the thing that causes the tailplane stall if the tailplane is iced up. Rubbish. Bertie- Hide quoted text - - Show quoted text - The NASA study on tail stall notwithstanding? |
On Sun, 15 Feb 2009 06:00:13 -0800 (PST), Dudley Henriques wrote:
On Feb 13, 4:44*pm, "Robert11" wrote: Hello, I guess de-icing is going to be a popular subject. Question, please: *On commercial jet airliners like, e.g., a 767 or 757, is there any in-flight deicing system for the wing and tail surfaces, other than a leading edge pneumatic boot ? What about the "main," large upper surfaces ? How in general is wing de-icing accomplished on these new, modern jets ? Thanks, Bob There's a very good chance the Boston crash might have been tailplane icing. DH To explain the erratic flight behavior? |
Similar Threads | ||||
Wing walk ply question. | Mustardbuilder | Home Built | 20 | January 28th 07 10:16 AM |
Rotor-wing question | D. Andrews | Rotorcraft | 8 | October 2nd 05 11:43 AM |
Folded wing tip question | a425couple | Naval Aviation | 35 | May 12th 05 11:40 PM |
Spitfire Mk XIV Wing Question | [email protected] | Military Aviation | 3 | September 19th 03 09:54 AM |
Discus Wing question | John Galloway | Soaring | 6 | August 23rd 03 07:52 AM |
