Tire Pressure Monitoring Systems for Trailers
Old July 23rd 17, 04:19 AM posted to rec.aviation.soaring
AS
Default Tire Pressure Monitoring Systems for Trailers
Hi - all in Gliderland,
I am picking up the subject of the tire pressure monitoring systems for trailers from another, unrelated thread.
I would like to hear more from others who have installed one on trailers. One unit was mentioned which looks very sophisticated.
Has anyone used this one, which is less expensive?
https://www.walmart.com/ip/GoSafe-TP...m #about-item
It has a simple readout but I am wondering if it would be able to receive the signals from a trailer - four tires in my case. I could install the receiver in the lighter outlet by the rear door of my van and just hope I will hear the warning tone.
Also, does anyone know if these systems operate on the same frequency? Would two systems installed on the tires of the towing vehicle and the trailer interfere with each other?
Uli
'AS'
Old July 23rd 17, 01:35 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Search around caravanning sites and you can find TPMS kits with six tyre
sensors on offer. Presumably these are good for trailers since none look
rugged enough for use on trucks, but nothing I've looked at gived a
maximum reception range in its specification or says anything about
interference. Six sensor kits are a lot more expensive than four sensor
kits, but I suppose that reflects market size and need for a different
display.
In the UK I've found six sensor kits being sold on Amazon, eBay and from
specialist suppliers.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 23rd 17, 03:54 PM posted to rec.aviation.soaring
Dan Marotta
Contact the supplier for the tech specs.
display.
Dan, 5J
Old July 23rd 17, 06:55 PM posted to rec.aviation.soaring
Forget the WalMart stuff. Go for the better built commercial products such as https://tsttruck.com/ .
Old July 27th 17, 04:18 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
AS wrote on 7/22/2017 8:19 PM:
I would not expect units intended for cars to the range to work well with a trailer.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old July 27th 17, 04:32 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Eric Greenwell wrote on 7/26/2017 8:18 PM:
.... intended for cars to HAVE the range ...
Old July 11th 18, 04:00 AM posted to rec.aviation.soaring
AS
Picking up that thread again. I purchased a system on Amazon capable of monitoring eight wheels via externally mounted pressure/temperature transducers and used it for the first time on a trip from SC to NM and back (1,500 miles each way). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I had the tires rotated and re-balanced before the trip although the tech at the tire shop mentioned that the monitors made hardly any difference (He ran a tire with and without a monitor on the balancer)
Setting up the pressure and temperature limits is pretty straight forward. The receiver - mounted with the supplied suction cup on the windshield - didn't seem to have any problems picking up the signals from the trailer. The display toggles through each tire about once a minute or so. One battery charge kept the display/receiver unit going for the whole trip. The transducers go to sleep shortly after no rotation is detected to save their batteries.
It was reassuring to see that the tire pressure was holding steady within 1/10 bar. It was also interesting to see the tire temperature rise and fall as road-and wind conditions changed. The unit warns when there is a slow leak well before the lower limit is reached by trending the pressure readings..
When the trailer is being detached, it can be 'un-linked', so the unit only looks for the tires of the tow vehicle.
All in all, I think a TPM system is cheap insurance against a blow-out. One saved fender and tire will already pay for the system.
Uli
'AS'
PW-5 Main Tire Pressure? JohnDeRosa Soaring 3 June 23rd 13 09:38 AM
Accurate tire pressure gage? Kurt Thams Soaring 6 September 25th 12 11:17 PM
Trailer tire pressure remote monitoring systems Eric Greenwell Soaring 11 August 9th 08 06:03 AM
Tire tread wear vs inflation pressure Ben Jackson Owning 22 October 6th 06 04:35 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
