#31
Get a ferry permit, or just fly it?
"Danny Dot" wrote in message
... Ferry permits are for planes that are not currently certified, e.g. not been inspected with a year. At least this is my understanding. Not correct, it has nothing to do with the annual. A plane that is out of annual can get a ferry permit but being out of annual is not a prerequisite. Thanks for the information. I gather if the plane is in annual, but "damaged" the rules state the pilot in command makes a decision if the plane is air worthy???? The PIC is responsible for ensuring that the airplane is airworthy. However, anything with respect to the airplane that does not meet the standards under which the airplane was granted an airworthiness certificate is automatically not airworthy. Whether the PIC determines this is the case or not doesn't matter with respect to whether the aircraft is or is not airworthy. Note that technically speaking, the annual inspection is not a question of airworthiness. That is, as far as I can recall, the airworthiness certificate doesn't require annual inspections. Part 91 does (FAR 91.409, specifically). An airplane without a current annual inspection is not legal to fly, but it may technically still be "airworthy" (assuming it still meets the criteria attached to the airworthiness certificate). Basically, a ferry permit is a method that can be used to legally obtain a waiver to allow the operation of an airplane outside of the normal regulations. This applies to a wide variety of situations including (but not limited to) lack of a current annual inspection, failure to meet the airworthiness certificate criteria, or even simply to operate the aircraft outside of the regulations (for example, exceeding the design maximum gross weight). Pete |
#32
"Robert M. Gary" wrote in
ups.com: Judah wrote: "Robert M. Gary" wrote in oups.com: I also can't imagine that a FSDO inspector simply walked up to the plane and randomly opened an inspection panel and found a loose bell crank. Could it be that there was some other symptom that caused the inspector to draw his attention there? Perhaps this symptom should have been noticed by a pilot and especially a CFI? No, the FSDO does onsite inspections of all FBO's in the district at least once every two years. Sometimes its a paperwork inspection, other times they pick a couple of airplanes and disassemble them. I spoke with several FBOs about this and they had all had this inspection done at least once. Some did better than others. At some point I think the FSDO is going to require all CFI's to have a valid IA certificate before they can instruct. I've never seen the FSDO rip apart planes on an FBO. I'm not completely surprised with that, especially if the FBO does its own service. You're saying the FSDO gave the CFIs crap for flying a plane that was properly annualed, maintained, and documented, but had some obscure fault that was not evidencible without ripping the plane apart? |
#33
Judah wrote: "Robert M. Gary" wrote in ups.com: I've never seen the FSDO rip apart planes on an FBO. I'm not completely surprised with that, especially if the FBO does its own service. You're saying the FSDO gave the CFIs crap for flying a plane that was properly annualed, maintained, and documented, but had some obscure fault that was not evidencible without ripping the plane apart? Absolutely. They wrote up 7 items. 2 of which were that the door seal on the C-182 was not glued down propertly (so you hold it against the door as you close the door), other items were the torque of the seat attachment bolts, two flight control issues (lose bell crank nut, and a rubbing cable internal), and a couple other similar issues. The FSDO said none of the items make the plane unairworthly but that they grounded for the "cummulative issues". After a couple of the CFIs called lawyers the FSDO "settled" by making us all go to a manditory safety meeting, no mention on our records. However, we did have to produce copies of our certificates and medicals (apparently the FSDO doesn't have a computer that they could look it up at registry.faa.gov), in addition to BFRs, CFI renewal dates, etc -Robert |
#34
"Robert M. Gary" wrote in news:1164771652.238928.229720
@n67g2000cwd.googlegroups.com: Absolutely. They wrote up 7 items. 2 of which were that the door seal on the C-182 was not glued down propertly (so you hold it against the door as you close the door), other items were the torque of the seat attachment bolts, two flight control issues (lose bell crank nut, and a rubbing cable internal), and a couple other similar issues. The FSDO said none of the items make the plane unairworthly but that they grounded for the "cummulative issues". After a couple of the CFIs called lawyers the FSDO "settled" by making us all go to a manditory safety meeting, no mention on our records. However, we did have to produce copies of our certificates and medicals (apparently the FSDO doesn't have a computer that they could look it up at registry.faa.gov), in addition to BFRs, CFI renewal dates, etc -Robert Wow. What ballbusters. |
#35
Robert M. Gary wrote: Again, contrary to my experience. In the Mooney community the factory service centers frequently fly out to airports with a prop and a pair of jacks after a gear up landing. Jack the plane up, swap the prop, and fly it back to the shop. I've never heard of any shop having any problems getting a Lycoming Mooney back to the shop -Robert That's normal procedure. Get it out of there with a ferry permit, then do the major work in the shop. The crank maty be bent or cracked, so that's the reason for the permit: to limit risk to passengers or people and property on the ground. The fact that they jacked it up, put on another prop and flew it back does not in any way prove that the engine isn't going to fail within the next 100 hours or whatever. Dan |
#36
"T o d d P a t t i s t" wrote in message
... That's an interesting difference between an experimental, such as my glider, and an aircraft with a standard type cert. The experimental does not require an annual, it requires a yearly "condition inspection," and *that* inspection, unlike an annual is required by the experimental airworthiness cert. Right. As described in 91.409(c), experimental aircraft (and others, including light-sport) are exempt from the requirement in 91.409(a) to have an annual inspection. Of course, as you note, an annual inspection is still actually required (though it's called something else)...the FAA causes that requirement to be incorporated into the airworthiness certificate. It's my assumption that this is specific to the kinds of "experimental" certificates that are likely to be attached to aircraft used in non-flight-testing situations (such as amateur built). This way, aircraft that really are true experimental flight design development platforms can get their exemption, while still applying the common-sense idea of having an aircraft used for transportation still comply with the spirit of 91.409(a). It may well be that experimentals used in the development of non-experimental certificated aircraft have no annual inspection requirement at all. Pete |
Similar Threads | ||||
radio permit for german registered glider | Andy Smielkiewicz | Soaring | 6 | February 24th 06 01:27 PM |
F4U-5 ferry range | [email protected] | Naval Aviation | 2 | January 31st 06 04:02 AM |
An EAC ferry to Red Flag | Maurice Hendriks | Naval Aviation | 0 | September 11th 05 11:04 PM |
Mexico Multi-Entry Permit | [email protected] | Piloting | 3 | August 26th 05 05:12 AM |
Ferry Permit? | Mackfly | Soaring | 7 | March 9th 04 02:23 AM |
