Garmin 396 Glitch??
Has anyone experienced significant "loss of signal" hiccups with their
new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've thought about re-installing the software. There is a new upgrade on the Garmin site so it wouldn't hurt, but none of the fixes address any "loss of signal" problems. Any similar experiences out there??? Thanks!!! |
Garmin 396 Glitch??
In article .com,
"Jeff B" wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've been using the 396 for almost 2 months, and I haven't had a loss of GPS signal in flight EXCEPT when I was using the "stick" GPS antenna on the unit. Since I switched to the external patch antenna, I've had no problems. However, I have continuously updated the software, so I would recommend that you update to the latest software (v2.60) and try again. I seem to recall that the 296 had a similar issue when it was new, and that successive software updates eventually fixed it. I would be surprised if that same issue exists in the 396 with current software. JKG |
Garmin 396 Glitch??
I used to get that problem with the stick antenna flying north. I started
using the other antenna and the problem went away. "Jonathan Goodish" wrote in message ... In article .com, "Jeff B" wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've been using the 396 for almost 2 months, and I haven't had a loss of GPS signal in flight EXCEPT when I was using the "stick" GPS antenna on the unit. Since I switched to the external patch antenna, I've had no problems. However, I have continuously updated the software, so I would recommend that you update to the latest software (v2.60) and try again. I seem to recall that the 296 had a similar issue when it was new, and that successive software updates eventually fixed it. I would be surprised if that same issue exists in the 396 with current software. JKG |
Garmin 396 Glitch??
"Jeff B" wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Nope. I've made a half dozen flights with the 396 with no problems. -- Dan C172RG at BFM |
Garmin 396 Glitch??
Hmmm...my problems occur WITH the external antenna (suction cup mount).
Garmin 396 Glitch??
In article .com,
"JB" wrote: Hmmm...my problems occur WITH the external antenna (suction cup mount). Perhaps you have a bad antenna? Might want to give Garmin a call and see what they say, but they are going to want to start troubleshooting from the latest software. JKG |
Garmin 396 Glitch??
"JB" wrote: Hmmm...my problems occur WITH the external antenna (suction cup mount). I use the external antenna, too. Maybe it's interference from one of your radios. I've replaced two Cessna ARC-385s because they messed up my GPS reception. Or it might be your antenna, as Jonathan suggested. I had one develop an intermittent open circuit in the cable where it entered the antenna. -- Dan C172RG at BFM |
Garmin 396 Glitch??
No loss of signal... but I just sent my 396 in for service.
Long story short -it would just stop working for no apparent reason. Screen would go black. Only way to restart was with a battery re-insert. The only apparent pattern it that it would never happen in the a/c. Only on the ground. Swapped everything except for the stick attenna which I used 100% on the ground and 0% in air. So back it goes for repair. Jeff B wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've thought about re-installing the software. There is a new upgrade on the Garmin site so it wouldn't hurt, but none of the fixes address any "loss of signal" problems. Any similar experiences out there??? Thanks!!! |
Garmin 396 Glitch??
"Maule Driver" wrote, "... So back it goes for repair."
Please let us know how it behaves after the repair and what, if anything, they said was wrong with it. Jon |
Garmin 396 Glitch??
I had a similar problem with my 296 except that is would turn itself off in
the air. I sent it in and Garmin ended up calling it corrupted user data. After they purged the stored data, it worked OK for a while. When it started doing it again the Garmin tech had me clear the data by removing and re-inserting the battery, then holding down three buttons to give it a lobotomy. It's working OK for now, but I suspect I will have to kill the user data again sometime to re-fix it. "Maule Driver" wrote in message . com... No loss of signal... but I just sent my 396 in for service. Long story short -it would just stop working for no apparent reason. Screen would go black. Only way to restart was with a battery re-insert. The only apparent pattern it that it would never happen in the a/c. Only on the ground. Swapped everything except for the stick attenna which I used 100% on the ground and 0% in air. So back it goes for repair. Jeff B wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've thought about re-installing the software. There is a new upgrade on the Garmin site so it wouldn't hurt, but none of the fixes address any "loss of signal" problems. Any similar experiences out there??? Thanks!!! |
Similar Threads | ||||
Garmin 96c glitch? | Barry | Piloting | 2 | January 11th 05 09:11 PM |
Garmin 96c glitch? | Barry | Rotorcraft | 0 | January 11th 05 06:24 AM |
Garmin 96c glitch? | Barry | Home Built | 0 | January 11th 05 06:23 AM |
Garmin 96c glitch? | Barry | Instrument Flight Rules | 0 | January 11th 05 06:22 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
