#51
Spins, Spiral Dives and Training
At 19:45 04 July 2009, Derek Copeland wrote:
Nevertheless, if you get into an accidental spin, you have to make a recovery or die, whether or not the aircraft is certified for deliberate spinning. I have to take issue with that statement which nicely illustrates my point. Knowing any recovery technique is not going to help you at all if you spin from a low final turn, the only thing that will save you is recognising what is happening and stopping it happening. I would go further and say that recovery in such a situation should not be attempted. If you look at the video you see that the glider hit wingtip first, which is what wound up the rotational speed, and then the nose impacted, much of the impact was absorbed by this process and the crew survived. If you imagine the situation where the glider is just a little higher and recovery is attempted and part suceeds, what is the first thing that stops, the rotation so instead of impacting the ground and having some of the the impact energy absorbed the glider hits the ground, nose first, accelerating, known as tent pegging I believe. This is very bad news for the crew and yet we quite happily consider recovery from spinning of greater importance than recognition of the early signs and prevention. Knowing the spin recovery procedure would have been of no use whatsoever to the crew of the glider in the video. |
#52
I am not very experianced or an instructor, but see this video, ...
http://www.youtube.com/watch?v=jvK1ONl1CqE After being slow to recoginise the cable break, the glider is stalled and rotating, but the nose does not go down, so the crash is perhaps less painfull than going in nose first.? I hope I would have better recoginised/reacted to the break, but if not I would have still lowered the nose more to unstall the wing and hopefully flare the landing????? David. At 22:45 04 July 2009, Don Johnstone wrote: At 19:45 04 July 2009, Derek Copeland wrote: Nevertheless, if you get into an accidental spin, you have to make a recovery or die, whether or not the aircraft is certified for deliberate spinning. I have to take issue with that statement which nicely illustrates my point. Knowing any recovery technique is not going to help you at all if you spin from a low final turn, the only thing that will save you is recognising what is happening and stopping it happening. I would go further and say that recovery in such a situation should not be attempted. If you look at the video you see that the glider hit wingtip first, which is what wound up the rotational speed, and then the nose impacted, much of the impact was absorbed by this process and the crew survived. If you imagine the situation where the glider is just a little higher and recovery is attempted and part suceeds, what is the first thing that stops, the rotation so instead of impacting the ground and having some of the the impact energy absorbed the glider hits the ground, nose first, accelerating, known as tent pegging I believe. This is very bad news for the crew and yet we quite happily consider recovery from spinning of greater importance than recognition of the early signs and prevention. Knowing the spin recovery procedure would have been of no use whatsoever to the crew of the glider in the video. |
#53
At 21:15 04 July 2009, bildan wrote: (snip)
The Puchacz is not a dangerous glider. There may be dangerous pilots who fly them, however. How would you describe a glider in which so many people have been killed in spinning incidents? Unlucky? Challenging? or Misunderstood perhaps? I fully accept the reports of the pilots who tested the glider and found that it recovered, if it had not they would not have been able to report that it didn't. Of course no-one is going to design a glider that cannot recover from a spin, and of course no-one is going to design an airliner where the doors fall off either, causing major structural failure. I do not think that the level of expertise found at McDonnell-Douglas exists in a glider design facility. Design faults are found in aircraft after release to service and mostly something is done or at least restrictions are put in place to counteract the fault, not so with the Puchacz. The reason why no-one has reported that a Puchacz is impossible to recover is that if it has happened the pilots have not survived to do so. It is easy to blame someone when they are not around to challenge that finding and this is certainly what the Canadian report does. Is the best explanation that anyone can come up with is that the glider attracts more than it's fair share of dangerous pilots. I have little doubt that the Putchacz will go on killing people while it is permitted to continue to fly, it won't be me, I will never fly in one again. |
#54
Don,
The German DG500 pilots escaped serious injury because, being so low, they didn't have that far to fall when the spin developed. Also DG gliders have crash resistant cockpits. Even so I bet that hurt! If you are in a full spin, you are decending at 50-60 knots or 5000ft/min+, which is probably enough to kill you. It certainly killed a former syndicate partner of mine who spun off a slow autotow launch at about 800ft and failed to make any sort of recovery. Once in a fully developed spin it probably matters not if you spin into the ground, or dive into it. If you have enough height to do so, it is better to recover because you then stand a very good chance of staying alive. I have already pointed out that you cannot afford to spin once down to circuit height, so you have to have to fly accurately at a safe airspeed. Derek Copeland At 22:45 04 July 2009, Don Johnstone wrote: At 19:45 04 July 2009, Derek Copeland wrote: Nevertheless, if you get into an accidental spin, you have to make a recovery or die, whether or not the aircraft is certified for deliberate spinning. I have to take issue with that statement which nicely illustrates my point. Knowing any recovery technique is not going to help you at all if you spin from a low final turn, the only thing that will save you is recognising what is happening and stopping it happening. I would go further and say that recovery in such a situation should not be attempted. If you look at the video you see that the glider hit wingtip first, which is what wound up the rotational speed, and then the nose impacted, much of the impact was absorbed by this process and the crew survived. If you imagine the situation where the glider is just a little higher and recovery is attempted and part suceeds, what is the first thing that stops, the rotation so instead of impacting the ground and having some of the the impact energy absorbed the glider hits the ground, nose first, accelerating, known as tent pegging I believe. This is very bad news for the crew and yet we quite happily consider recovery from spinning of greater importance than recognition of the early signs and prevention. Knowing the spin recovery procedure would have been of no use whatsoever to the crew of the glider in the video. |
#55
I have done quite a few flights in the Puchacz. It is a perfectly nice
glider, albeit with a slightly greater tendency to spin than most West European designs. Ditto the Junior. They will both recover using the standard spin recovery, although you may have to get the stick well forward and hold it there until the spin stops. I personally prefer training gliders that spin properly and require a positive recovery. With the K13 for example, you are never quite sure whether it will go into a spin or a spiral dive, and it will usually recover from a spin as soon as the stick is moved off the backstop. not very realistic! Derek Copeland At 23:30 04 July 2009, Don Johnstone wrote: At 21:15 04 July 2009, bildan wrote: (snip) The Puchacz is not a dangerous glider. There may be dangerous pilots who fly them, however. How would you describe a glider in which so many people have been killed in spinning incidents? Unlucky? Challenging? or Misunderstood perhaps? I fully accept the reports of the pilots who tested the glider and found that it recovered, if it had not they would not have been able to report that it didn't. Of course no-one is going to design a glider that cannot recover from a spin, and of course no-one is going to design an airliner where the doors fall off either, causing major structural failure. I do not think that the level of expertise found at McDonnell-Douglas exists in a glider design facility. Design faults are found in aircraft after release to service and mostly something is done or at least restrictions are put in place to counteract the fault, not so with the Puchacz. The reason why no-one has reported that a Puchacz is impossible to recover is that if it has happened the pilots have not survived to do so. It is easy to blame someone when they are not around to challenge that finding and this is certainly what the Canadian report does. Is the best explanation that anyone can come up with is that the glider attracts more than it's fair share of dangerous pilots. I have little doubt that the Putchacz will go on killing people while it is permitted to continue to fly, it won't be me, I will never fly in one again. |
#56
On Jul 3, 12:00*am, Derek Copeland wrote:
If Noel Wade came to visit the UK, he would probably not be able to climb at all in our often tiny little thermals using the techniques he suggests.. The necessary skill is to be able to fly in accurate well banked turns at not more than about 5 knots over the turning stall speed. Otherwise he will be going round in thesinksurrounding the thermal. Derek - Thanks for attacking my skills rather than arguing the point from a logical perspective... I trained and fly in places that have both weak lift and narrow lift, and I stay in them just fine - for the record. Now, to actually defend the point: If your argument is that you have to fly slowly in order to stay in a small thermal, you're ignoring an alternate solution: tighten your bank angle. It is true that a slower speed gives you a smaller turning radius at the same bank-angle, but it has a number of drawbacks (many of which I touched on with my post - you're closer to stall speed, you're possibly below min-sink - and therefore not flying the glider as cleanly or efficiently as you could be). If you simply keep your speed up and tighten your bank angle, you'll achieve a smaller turning radius and you won't be in danger of stalling. I urge you to do the math, as I have done (or at least look it up online, there are webpages that illustrate this - such as: http://www.soarns.ca/crclmotn.html)... Down around the speeds we're talking about, you will have a _smaller_ turn radius at a 45-degree bank-angle than at a 30-degree bank-angle, EVEN if you add 5 - 7 knots of speed in the higher bank-angle turn. AND the additional G-loading does not increase your sink rate by that much (around 20 ft/min in my DG-300). Even in a small 2-knot thermal you're really only giving up a small percentage of performance in order to be a lot safer. And there are plenty of ways that the average pilot can "make up" that performance, by flying more cleanly in other phases of flight. Finally, if you _have_ been flying below min-sink speed (for a given bank-angle), you may actually find _improved_ climb performance by keeping your speed up and tightening your bank-angle. Take care, --Noel |
#57
Noel,
It was not my intention to attack your flying skills, but just to state a fact of life about flying in UK conditions. The tighter you turn, the more the stalling speed increases, due to the extra g loading, and the more the sink rate increases. Our thermals can also be quite weak, so excessive angles of bank can increase the glider's sink rate enough to cancel out the thermal. 5 knots over the turning stall speed at a 35-40 degree angle of bank usually works well in the UK, and that puts you at about the effective min sink speed. I have flown in central France, where the thermals are normally huge and strong. In the UK you normally turn as soon as you encounter lift, but there you had to wait for maybe twenty seconds before you reached the core of the thermal. The French pilots seem to thermal at only about 15 degrees angle of bank. One holiday I had over there consisted of a whole fortnight of low inversion blue days, so somewhat UK like conditions with small weak thermals. My syndicate partner and I where able to do a number of 200-300k flights when most of the locals (with one exception, who was a world class competition pilot) couldn't stay up at all. Maybe that is why the UK has produced so many World Gliding Champions, although I am not quite in that league myself. Derek Copeland At 23:06 05 July 2009, noel.wade wrote: On Jul 3, 12:00=A0am, Derek Copeland wrote: If Noel Wade came to visit the UK, he would probably not be able to climb at all in our often tiny little thermals using the techniques he suggests= .. The necessary skill is to be able to fly in accurate well banked turns at not more than about 5 knots over the turning stall speed. Otherwise he will be going round in thesinksurrounding the thermal. Derek - Thanks for attacking my skills rather than arguing the point from a logical perspective... I trained and fly in places that have both weak lift and narrow lift, and I stay in them just fine - for the record. Now, to actually defend the point: If your argument is that you have to fly slowly in order to stay in a small thermal, you're ignoring an alternate solution: tighten your bank angle. It is true that a slower speed gives you a smaller turning radius at the same bank-angle, but it has a number of drawbacks (many of which I touched on with my post - you're closer to stall speed, you're possibly below min-sink - and therefore not flying the glider as cleanly or efficiently as you could be). If you simply keep your speed up and tighten your bank angle, you'll achieve a smaller turning radius and you won't be in danger of stalling. I urge you to do the math, as I have done (or at least look it up online, there are webpages that illustrate this - such as: http://www.soarns.ca/crclmotn.html)... Down around the speeds we're talking about, you will have a _smaller_ turn radius at a 45-degree bank-angle than at a 30-degree bank-angle, EVEN if you add 5 - 7 knots of speed in the higher bank-angle turn. AND the additional G-loading does not increase your sink rate by that much (around 20 ft/min in my DG-300). Even in a small 2-knot thermal you're really only giving up a small percentage of performance in order to be a lot safer. And there are plenty of ways that the average pilot can "make up" that performance, by flying more cleanly in other phases of flight. Finally, if you _have_ been flying below min-sink speed (for a given bank-angle), you may actually find _improved_ climb performance by keeping your speed up and tightening your bank-angle. Take care, --Noel |
#58
At 20:04 04 July 2009, Jim Logajan wrote:
John Smith wrote: Jim Logajan wrote: Did it involve a fatality? Listen to the text: The pilot suffered only slight injuries. You elided the essential part where I pointed out that one can't view the video (and therefore "listen to the text") without first creating an account on Youtube and atesting that one is 18 or over. If it didn't involve a fatality, why is the video considered inappropriate for some viewers? Possibly because of the rude word in German uttered by a lady witness that you can also hear in the soundtrack! Even if there were no fatalities or serious injuries, this video should be X or 18 rated, and not viewed by those of a nervous disposition. Fortunately such accidents are quite rare, at least in Europe, so this video should not put you off gliding or winch launching. Derek Copeland |
Similar Threads | ||||
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (1/2) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 10th 07 02:39 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (2/2) | J.F. | Aviation Photos | 0 | August 10th 07 02:14 PM |
Spiral Dives Explanation. | Sandy Stevenson | Soaring | 6 | August 26th 05 12:34 PM |
Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 10:04 PM |
