Seat repairs
On Tue, 07 Oct 2003 12:43:50 GMT, "John McFarlane"
wrote: Airtex? see TAP Did you have to spam every aviation newsgroup with this question? MikeM Recently I found an Interior/Seat refurbishment company that dealt with replacement seat cusions/covers for most GA aircraft - USA based. They were different in that there was no real need to remove the seating, as there product could replace the old gear in place. Simply replace take off the old, replace the cushions/foam with the supplied and zip the new covers back over the top - or something close to this - no apparent need for an A&P ? Could someone please supply the company's web link if it known or point me i the right direction, tried google and dogpile far to many links. Thanks in advance John |
supplied and zip the new covers back over the top - or something close to this - no apparent need for an A&P ? Having observed and participated in my recent (actually, ongoing) interior refurbishment, I can tell you that there is far more to quality seat reupholstery than what you describe. Simply "taking off the old" covers is a major chore in itself, requiring removal of the seats from the plane. Then the foam padding inside, especially if it's original, will most likely NOT be in great shape -- and removing the seat cover tends to wreck it even more. Re-using the foam may be possible, but putting in new is preferable -- but it must be contoured correctly or you will not have proper lumbar support, or you will have "hot spots" where the foam is too firm. And you can't just "replace the cushions/foam with the supplied" new stuff -- there's a lot more to it than that. It's got to be glued and/or stitched to the frame or webbing properly, which requires a knowledge of the seat design, positioning of the foam, and how thick to make it. Again, do this wrong, and you'll have uncomfortable seats. More importantly, the webbing underlying the foam padding will probably be degraded in some way. (The webbing on my co-pilot's seat was completely detached from the metal seat framework, underneath the foam, resulting in a "toilet seat" feel.) Re-doing the webbing is quite a task, and MUST be done properly or the seat will be either too firm or too soft. It takes a real pro to know how tightly to tension it, and how to properly attach it to the frame. (My guy used glue AND stitching, using a special tensioner.) To get at that webbing naturally requires the removal of ALL foam -- which may (or may not) destroy it, depending on the condition of the foam and the glue used to attach it. In my case, we were able to re-use a fair amount of the specially contoured backrest foam, but all of the seat foam had to be completely re-made. Then there's the matter of scraping/blasting/sanding the seat frames, and repainting them. (After many years, they invariably look like crap -- and you sure don't want nice new leather seats on top of cruddy, chipped frames.) This is no mean feat, and requires a large work room and a place to paint them without worrying about over-spray. Reassembly is quite a chore, since the upholstered seat covers are designed to fit over the foam very snugly. And, of course, there are those little details that make the seat cover stay firmly attached to the foam -- things like stitching, and very strong tie-downs that pass through the foam and attach to the bottom of the backrest cover and the seat frame. And then there are headrests. If your plane has headrests, you've got a pretty major job just recovering each of those little puppies. If you can find a place that advertises that you can just 'zip new covers back over the top" of some foam they supply, you will perhaps have found a solution to your cosmetic problem -- but the seat will not last long, and will most likely be uncomfortable. IMHO, comfortable seats are a critical requirement in my plane -- at least as important as good headsets -- and it's worth a few extra bucks to get it done right. We just got new leather seats, and they are fabulous. Comfortable, great looking, and obviously built to last. If your seats are just cosmetically bad, get yourself a nice set of sheepskin shearling seat covers. We found a very nice, very high quality set at Wal-Mart, believe it or not, that Mary "nipped and tucked" to fit perfectly. These looked very nice, were very comfortable summer or winter, and bought us a year's worth of time, which enabled us to find a good aircraft upholstery shop. (I've still got the seat covers, if you're interested. They're in excellent shape -- drop me an email "off-line" if you want 'em. Just eliminate "NOSPAM" from my email address.) Good luck! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Can't go wrong with www.airtexinteriors.com.
Sandy Mustard mikem wrote: On Tue, 07 Oct 2003 12:43:50 GMT, "John McFarlane" wrote: Airtex? see TAP Did you have to spam every aviation newsgroup with this question? MikeM Recently I found an Interior/Seat refurbishment company that dealt with replacement seat cusions/covers for most GA aircraft - USA based. They were different in that there was no real need to remove the seating, as there product could replace the old gear in place. Simply replace take off the old, replace the cushions/foam with the supplied and zip the new covers back over the top - or something close to this - no apparent need for an A&P ? Could someone please supply the company's web link if it known or point me i the right direction, tried google and dogpile far to many links. Thanks in advance John |
Similar Threads | ||||
Airliner Seats ... | smjmitchell | General Aviation | 6 | September 26th 04 10:00 PM |
Seat belts. | Paul Lee | Home Built | 0 | December 18th 03 09:35 PM |
Pitts Seat Mod | Martin Morgan | Aerobatics | 0 | November 21st 03 03:56 AM |
Seat cushion | Ernest Christley | Home Built | 14 | August 5th 03 07:16 PM |
Seat cushions | Big John | Home Built | 3 | July 31st 03 10:59 PM |
