#31
Rudder waggle
On Nov 19, 5:24 pm, "Vaughn Simon"
wrote: Then we will have to politely agree to disagree. I have heard of too many cases where tow plane releases failed to release, sometimes leading to loss of the tow plane or much worse. I have also heard of situations where a tuggy could not immediately reach the release. I have always been taught (and taught) that the wave-off is a command. You when you get a wave-off, you immediately release and then discuss things on the ground. If the towplane release fails, then I argue the tow pilot will dive, then perhaps give the wave off command. I can't imagine the tow pilot giving a wave-off in an IMMEDIATE danger situation, as it has likely been caused by the glider in the first place (kiting, for example). I am also not advocating NOT RELEASING. What I am advocating is a think before reacting attitude. If the glider pilot is taught to take a MOMENT to consider the wing rock, then a MOMENT will also be taken when faced with the rudder waggle. This MOMENT is used to decide whether to release because the tug is in trouble or to look over the glider first. Once the MOMENT has passed, if I realize the tug is indeed rocking the wings, I WILL RELEASE. But if the tow pilot is indeed in trouble, and the release has failed, I seriously doubt there will be time for a waggle, the tow pilot will be diving to get airspeed, and to get landed ASAP. So, if you advocate IMMEDIATELY releasing, then we still disagree, I refuse to do anything IMMEDIATELY without taking a MOMENT to consider the consequences. There are too many automobile accidents caused by someone swerving to avoid a minor mishap only to create a nasty pileup, for example. Let's keep our tuggies alive. Absolutely! I pay attention to the tow plane, and will likely see the problem develop before I see the wing wag, or might even give the TP a call if I see smoke or parts being shed. -Tom |
#32
Rudder waggle
ahh.. I think the tow pilot will release his end.. with you over head the
airport and in a position taht if the rope back releases it will not harm anything on the ground if neither can release.. then consider landing on tow BT "Bert Willing" wrote in message ... The book says that we are going to land on tow (and we practize for that). But then, I haven't heared of such a case in the last 27 years... Bert "Mike Lindsay" wrote in message ... I wonder what other people do in the event that the glider cant release? -- Mike Lindsay |
#33
Rudder waggle
On Nov 18, 7:06 am, toad wrote:
Since the rudder waggle signal was brought up in another thread, I have a few thoughts and would like to get other opinions. I am a glider and tow pilot for my club, so I have thought these through from both ends. To start with, if the tow plane gives you a wave off signal, THERE IS TIME TO THINK ABOUT IT ! If there was no time (30 sec or less to disaster) the tow pilot will just pull their release. So any signal that you get, you have enough time to carefully think. "What is that signal; check spoilers or wave-off ?" Take 10 seconds and THINK ! On the tow-pilot side, assume that the glider pilot will most likely release when you give the waggle, so don't waggle unless 1) you are going to die soon, if the glider doesn't close the spoilers, or 2) the glider is high enough and close enough to the airport to land with full spoilers out. If you have a radio, you could calmly call the glider and say "hey glider, are your spoilers open ?" Don't say the word release, because he might release. I still wouldn't do this close to the ground. Todd Smith 3S When you experience enough wave offs, you learn the signal. Years ago, when flying at 29 Palms behind what I think was a 170, our tows only went as high as the engine oil temperature would allow. Just wait for the wings to rock and then release. A comment regarding radios - using a radio would be nice but the towplanes where I fly either don't have a radio or do not have them turned on. In fact, I have never talked to a towpilot by radio in over 30 years of soaring! Steve |
#34
Rudder waggle
Similar Threads | ||||
WTD. SGS 2-33 Rudder | [email protected] | Soaring | 0 | December 20th 06 04:31 AM |
WTB. SGS 1-35 Rudder | [email protected] | Soaring | 0 | July 22nd 06 07:28 PM |
c-152 rudder??? | houstondan | Owning | 39 | December 21st 04 09:21 PM |
c-152 rudder??? | houstondan | Owning | 28 | December 15th 04 09:55 PM |
1-34 Rudder | DGRTEK | Soaring | 23 | February 16th 04 04:36 AM |
