Glider Batteries and Chargers
On Aug 24, 7:08*pm, brianDG303 wrote:
More about Glider Batteries: My club's gliders use Gel batteries, probably because they fit the mounts so well, but mostly the private gliders use a battery type with many names, I guess it's an SLA (Sealed Lead Acid) except it's not really sealed. I started to call it an AGM (Acid Glass Matt) which it has, but suddenly it started to be called a VRLA (Valve Regulated Lead Acid). Anyway they are very interestingly made. Although they look sealed many of these have a separate and tightly fitting top which is glued on only at the short sides, (the Valve Regulated gas being allowed to escape through the unglued long sides) and this cap can be pulled off pretty easily exposing the sub-assembly consisting of small recessed nipples rising from the center of little 'moats' that have a fabric packing in them, I guess to absorb any acid that gets out of the valve. Each of these little nipples has a rubber cap which forms a one way valve. Pictures of this can be found he http://picasaweb.google.com/BrianDG3...laneBatteries# As far as I can tell the battery exhausts gas (and/or liquid) whenever the internal pressure rises very much beyond the ambient, but seals tightly when the internal pressure is lower than ambient. When the top is removed the caps are dished down into the nipple from negative pressure and when you pull the cap off there is a considerable hiss of air flow into the battery. So, although they are valve regulated I don't think they 'breathe' much, at least not in. Also in that group of photos is a housing I've made, different from but based on an example I saw Darryl Ramm make, that forms a handle, protects the battery terminals, holds a Klixon aircraft rated circuit breaker and two Anderson Powerpole connector sets. Using clear Lexan for the top is a trick from hospitals, they will sometimes make electrical devices out of clear polycarbonate- you can inspect the terminals that way and see a failure developing. Also makes it easier to work on. Having two outputs is very useful as well. Brian SLA == VRLA == AGM it is all the same stuff. But why use a TLA when you can use a LFLA :-) Some VRLA batteries are also referred to technically as recombinant, or valve regulated lead acid recombinant, or lead acid recombinant batteries. All basically the same stuff. Most situations where glider pilots are referring to "gell cell" they turn out to be VRLA batteries. There really is no benefit of the old gel cell technology (electrolyte gelled with a silica powder) and some disadvantages, including repeated deep cycling and rapid charging causing gas pockets in the gel. VRLA construction tends to be a bit more robust against misshandling - with the plates really solidly packed in a compressed sandwich that gel cells, but both are pretty robust. The neoprene valves that Brian describes hold a slight over pressure of the battery and prevent gas escaping under normal charge situations. The valves will vent if the battery gets hot and/or is overcharged. This why its normally OK to operate a VRLA battery in any orientation but just don't charge them when upside down or they can blow out a few drops of acid with the venting gas (even if they have absorber designed to catch that acid). Darryl |
Similar Threads | ||||
Still interested in Lithium batteries for your glider? | Eric Greenwell | Soaring | 5 | March 5th 05 02:32 PM |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
Battery Chargers | Mike Rapoport | Owning | 11 | December 2nd 03 11:55 PM |
Rechargable AA batteries and chargers | TripFarmer | General Aviation | 2 | October 17th 03 06:34 PM |
Rechargable batteries and chargers....... | TripFarmer | Products | 2 | October 17th 03 06:31 PM |
