Adiabatic lapse rate
Does the lapse rate equation hold in all cases? I was recently
wondering what kind of temperature would be reached at 35 Kft over Arctic Canada in January. It seemed that the lapse rate equation would lead you to expect temperatures that would be causing nitrogen and carbon dioxide to be condensing which doesn't seem likely. |
Everett M. Greene wrote:
Does the lapse rate equation hold in all cases? I was recently wondering what kind of temperature would be reached at 35 Kft over Arctic Canada in January. It seemed that the lapse rate equation would lead you to expect temperatures that would be causing nitrogen and carbon dioxide to be condensing which doesn't seem likely. The equation breaks at tropopause, and your requested altitude is quite near it, if not above. AFAIK, you need measurements for the temperature, as the equation cannot handle it. -- Tauno Voipio (CPL(A)) tauno voipio (at) iki fi |
On 10/21/2007 11:44 AM, Everett M. Greene wrote the following: Does the lapse rate equation hold in all cases? Don't count on it in the real world. I was once in the clear at 6,000 feet, 0 degrees C, and confidently told my wife that Approach would soon drop us into the clouds at 4,000 feet but that we didn't have to worry about ice because it would be +4 degrees. When we got there it was -- ta da -- 0 degrees! We immediately started picking up some light ice, requested and got a descent to 3,000, and all was well. |
Lapse rate is dependent on humidity. The dry rate is rapid,
the wet rate can be anything, even a temperature rise as the condensation raises the temperature [makes thunderstorms-hurricanes], the average lapse rate is just that, a mathematical average. "Mitty" wrote in message ... | | | On 10/21/2007 11:44 AM, Everett M. Greene wrote the following: | Does the lapse rate equation hold in all cases? | Don't count on it in the real world. I was once in the clear at 6,000 feet, 0 | degrees C, and confidently told my wife that Approach would soon drop us into | the clouds at 4,000 feet but that we didn't have to worry about ice because it | would be +4 degrees. When we got there it was -- ta da -- 0 degrees! We | immediately started picking up some light ice, requested and got a descent to | 3,000, and all was well. |
On Oct 21, 12:44 pm, (Everett M.
Greene) wrote: Does the lapse rate equation hold in all cases? I was recently wondering what kind of temperature would be reached at 35 Kft over Arctic Canada in January. It seemed that the lapse rate equation would lead you to expect temperatures that would be causing nitrogen and carbon dioxide to be condensing which doesn't seem likely. The adiabatic lapse rate only holds true in the troposphere. The troposphere is heated from below by convective air currents, and this is where the 3C/1000' comes from. In contrast, the stratosphere absorbes solar radiation directly, and hence has a negative lapse rate. In the polar regions the troposphere is thinner, about 20kft high (also depends on season). So you cannot apply the tropospheric lapse rate up to 35 Kft. |
On Oct 21, 2:29 pm, Mitty wrote:
On 10/21/2007 11:44 AM, Everett M. Greene wrote the following: Does the lapse rate equation hold in all cases? Don't count on it in the real world. I was once in the clear at 6,000 feet, 0 degrees C, and confidently told my wife that Approach would soon drop us into the clouds at 4,000 feet but that we didn't have to worry about ice because it would be +4 degrees. When we got there it was -- ta da -- 0 degrees! We immediately started picking up some light ice, requested and got a descent to 3,000, and all was well. In fact I've noticed when there is ice about and the temp is near freezing that it tends to stay that way -- no rate at all!! It's as if the model is more like the ice-water mix where the temp is constrained at 32F until all the ice is melted or all the water frozen. Look out, huh! It's an interesting question on the instrument written but the real world is a lot different. Bill Hale |
"Everett M. Greene" wrote in message ... Does the lapse rate equation hold in all cases? I was recently wondering what kind of temperature would be reached at 35 Kft over Arctic Canada in January. It seemed that the lapse rate equation would lead you to expect temperatures that would be causing nitrogen and carbon dioxide to be condensing which doesn't seem likely. As you pass through the tropopause at approx 36,000 and -56 C the temperature rises in the stratosphere as solar radiation is bounced back up through the stratosphere by ozone (O3). As you get right on the fringes of the atmosphere the temperature rise is enormous. The main issue in the troposphere is that well known greenhouse gas water vapour. The adiabatic lapse rate is entirely dependent on the amount of water in the air and you can calculate that using the wet and dry bulb thermometers. |
S Green wrote: "Everett M. Greene" wrote in message ... Does the lapse rate equation hold in all cases? I was recently wondering what kind of temperature would be reached at 35 Kft over Arctic Canada in January. It seemed that the lapse rate equation would lead you to expect temperatures that would be causing nitrogen and carbon dioxide to be condensing which doesn't seem likely. A few years back, my (then) 4th grade son did his science fair project on how temperature changes with altitude. Over the course of a year, and probably a dozen or more family flights, he measured the OAT as a function of altitude during our climb-outs and descents. He got data from sea level up to 14,000. Amazingly enough, it averaged out to almost exactly 2 deg C/1000'. He noted that the greatest deviations from that occurred very close to the ground (within 2000' AGL) and when we were in clouds (IMC). Now, our Cherokee 6 can't climb up to FL 350, so I have no personal experience with how high the standard lapse rate holds. However, my son will tell you that for a clear day, above 2000' AGL, it seems to hold very very well. Oh....and he got first place for his science project. I couldn't be a prouder pilot-papa. -- Dane |
"Peter" wrote in message ... (Dane Spearing) wrote Now, our Cherokee 6 can't climb up to FL 350, so I have no personal experience with how high the standard lapse rate holds. However, my son will tell you that for a clear day, above 2000' AGL, it seems to hold very very well. He got lucky. I can't remember a flight here (UK) where the lapse rate was anything like 2C/1000ft. Yesterday, +10C on the ground, +8C at 5000ft. That might have been because there was an inversion from the ground up to say 2000 ft, a higher temperature that ground level. |
Bill wrote: In fact I've noticed when there is ice about and the temp is near freezing that it tends to stay that way -- no rate at all!! I've noticed that too, and always assumed its because of the ice buildup on the thermometer. |
Similar Threads | ||||
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
Wx Time Lapse Videos | Jay Beckman | Piloting | 0 | September 20th 05 07:32 AM |
How saturated adiabatic lapse rate varies with temperature | Andrew Sarangan | Piloting | 5 | February 15th 05 03:38 PM |
Atmospheric stability and lapse rate | Andrew Sarangan | Piloting | 39 | February 11th 05 06:34 AM |
Lapse Rate Question | Waduino | Soaring | 0 | October 1st 03 07:32 PM |
