Wedekind sleeve
Need the plastic inner bushing for a Wedekind sleeve on a 90 deg l'Hotelier connector.
Any ideas for source of supply? Google search no joy! Thanks |
Wedekind sleeve
On Tuesday, February 4, 2014 5:00:51 PM UTC-5, Hartley Falbaum wrote:
Need the plastic inner bushing for a Wedekind sleeve on a 90 deg l'Hotelier connector. Any ideas for source of supply? Google search no joy! Thanks Are you referring to the plastic (red) safety sleeves? If so, when I owned an LS-1f I was able to purchase from Pacific Aero sports r/Jim N9XL/H201B |
Wedekind sleeves are no longer made, neither are Uerling (spelling?). The "Red" sleeves are also not what you want, I believe they had some sort of issue, not exactly sure what.
The only sleeves I know of are known as "White LS" sleeves. I have a set of them on my LS1-f, they work awesome, and "installation" takes literally 5 seconds with no modification to the aircraft. Call Chris Klix at Pacific Aerosport, he sells them, I think mine were $35 per sleeve a few years ago. Good luck |
Wedekind sleeve
On Tuesday, February 4, 2014 11:00:51 PM UTC+1, Hartley Falbaum wrote:
Need the plastic inner bushing for a Wedekind sleeve on a 90 deg l'Hotelier connector. Any ideas for source of supply? Google search no joy! Thanks Wedekind sleeves and also spare parts are available from LTB Lindner http://www.ltb-lindner.com/home.104.html |
Wedekind sleeve
On Wednesday, February 5, 2014 2:34:42 AM UTC-5, wrote:
On Tuesday, February 4, 2014 11:00:51 PM UTC+1, Hartley Falbaum wrote: Need the plastic inner bushing for a Wedekind sleeve on a 90 deg l'Hotelier connector. Any ideas for source of supply? Google search no joy! Thanks Wedekind sleeves and also spare parts are available from LTB Lindner http://www.ltb-lindner.com/home.104.html Many thanks! I have sent them an email. They were very good to work with, replacing the master brake cylinder on our G102 Club III |
Similar Threads | ||||
Wedekind sleeve for Std Cirrus | John Galloway | Soaring | 8 | July 9th 13 02:15 PM |
Wedekind Sleeves for GROB ASTIR CS | Juliet11[_2_] | Soaring | 2 | April 1st 13 03:39 PM |
Wedekind Safety Sleeves | ContestID67 | Soaring | 3 | March 5th 07 01:04 PM |
Wedekind Safety Sleeves | Huds | Soaring | 5 | May 8th 05 03:07 AM |
Source for Wedekind sleeves - AS-W20a | Mark Grubb | Soaring | 7 | April 6th 04 08:19 PM |
