LS3a vs Pegasus
I really wanted a Pegase, but I weigh 225 lbs, and best as I can tell by the POH, max pilot weight of a 101 is 185. This is max weight of non lifting surfaces minus empty weight.
If someone can show me different I'll certainly listen! |
LS3a vs Pegasus
On Wednesday, April 27, 2016 at 8:18:32 PM UTC-7, IA DPE wrote:
I really wanted a Pegase, but I weigh 225 lbs, and best as I can tell by the POH, max pilot weight of a 101 is 185. This is max weight of non lifting surfaces minus empty weight. If someone can show me different I'll certainly listen! Never weighed under 245 lbs, put in a tail tank and flew it for years including 1000K gary kemp |
LS3a vs Pegasus
I really wanted a Pegase, but I weigh 225 lbs, and best as I can tell by the POH, max pilot weight of a 101 is 185. This is max weight of non lifting surfaces minus empty weight. If someone can show me different I'll certainly listen! Never weighed under 245, put in a tail tank and flew it for years including my 1000K gary kemp |
LS3a vs Pegasus
I just looked at a digital copy of a manual and it listed max load at 260 lbs. Where did you get the 185 number?
LS3a vs Pegasus
At 03:18 28 April 2016, IA DPE wrote:
I really wanted a Pegase, but I weigh 225 lbs, and best as I can tell by the POH, max pilot weight of a 101 is 185. This is max weight of non lifting surfaces minus empty weight. If someone can show me different I'll certainly listen! This varies per aircraft. Depends on the actual empty weight of non-lifting components (fuselage, stabilizer), and therefore damage history and equipment fitted. I have two in maintenance with a 225+ lbs max weight (227 and 231). 242 (and a bit) is maximum load per design specifications (seatbelts and attachment) if max non-lifting is not reached before that. |
LS3a vs Pegasus
On Tuesday, April 26, 2016 at 4:51:47 PM UTC-4, wrote:
Let me know if your going to sell your 15, I would be interested in it if you put her up for sale. Dan I noticed your interest in an ASW-15B. Mine is for sale and is posted on Wings & Wheels. Jack |
Similar Threads | ||||
Wanted: LS3A or LS3A-17 (USA) | Uniform Zulu | Soaring | 1 | November 21st 07 07:36 PM |
LS3A performance | Rob Dunning | Soaring | 7 | July 7th 07 03:38 PM |
FS - LS3a | Simon Waddell | Soaring | 0 | January 17th 04 04:05 PM |
OPINIONS ON AN LS3A | Gordon Schubert | Soaring | 6 | November 14th 03 10:41 AM |
Drag of LS3 compared LS3a. | Peter Warburton | Soaring | 0 | August 18th 03 06:59 AM |
