Canadian pilot posts ILLEGAL flight into US on OLC
Old July 25th 19, 03:22 AM posted to rec.aviation.soaring
2G
Default Canadian pilot posts ILLEGAL flight into US on OLC
This pilot made a DEEP entry into the US w/o, apparently, following the laws of the US:
https://www.onlinecontest.org/olc-3....l?dsId=7436890
Here is what you have to do PRIOR to flying into the US, regardless of whether or not you are a US citizen:
https://www.faa.gov/air_traffic/publ...ions/airspace/
Here is just one excerpt:
All civil, private aircraft entering the U.S. must first land at an airport of entry before continuing to their destinations, unless other arrangements are made with U.S. CBP.
The penalties for violating these laws is pretty stiff, including confiscation of the offending aircraft. And, if you are going to break US law anyhow, DON'T post your flight on the Internet!
Old July 25th 19, 03:52 AM posted to rec.aviation.soaring
Charles Longley
You need to read up on the laws a little bit. You don’t need to clear customs if you don’t land.
Old July 25th 19, 04:02 AM posted to rec.aviation.soaring
True, but don't forget the overflight fees:
Fees in U.S.-Controlled Airspace:
The FAA charges overflight fees to operators of aircraft that fly in U.S.-controlled airspace, but neither take off nor land in the United States.
https://www.faa.gov/air_traffic/inte...erflight_fees/
Old July 25th 19, 04:42 AM posted to rec.aviation.soaring
Ramy[_2_]
Tom, ask yourself who you made look bad by your post.
Ramy
JS[_5_]
Is this the fun police?
Old July 25th 19, 04:48 AM posted to rec.aviation.soaring
Charles Longley
Pretty awesome flight!
Old July 25th 19, 05:15 AM posted to rec.aviation.soaring
Should have just asked for asylum on 123.3
Old July 25th 19, 05:21 AM posted to rec.aviation.soaring
No service, no fee. If he opened a flight plan, that's all that's required.
Of course, that doesn't work in TFR's because gliders are specifically excluded - WTF?
By the way, if you ever file a flight plan for a glider, type is GLID/
Old July 25th 19, 05:54 AM posted to rec.aviation.soaring
AS
Just for clarification - how is US-controlled airspace defined in this case? Does that mean any airspace over US territory regardless whether an ATC service was provided or controlled airspace like Class A, B, etc.? The pilot of the Arcus M took good care staying out of Class A and there is no other controlled airspace in his flight path, so would that overflight fee apply?
And yes - that was an awesome flight! :-)
Uli
'AS'
Old July 25th 19, 06:10 AM posted to rec.aviation.soaring
Bruce Hoult
I'm not a member so I can only see the small map. It appears the Arcus entered US airspace just north of Babb MT, and continued approximately 240 km to near Wolf Creek before very closely retracing its path.
On the following FAA web page ...
.... I see a charge current Jan 1 2019 for En-route overflight of $61.75 per 100 nautical miles great circle distance from POINT OF ENTRY to POINT OF EXIT from U.S.-controlled airspace.
I estimate the distance from point of entry to point of exit on the 49th parallel to be something on the order of two or three miles. Accordingly the fee that might be due would be in the range of maybe $1.20 to $1.80.
Does the original poster have knowledge or evidence of any communications that might have taken place between the glider and US ATC, or that no such communication took place?
canadian flight plan advice for a U.S. pilot Cirrus Piloting 9 October 29th 06 09:10 PM
Classic RAS posts: Chip Bearden and "pilot relief" Eric Greenwell Soaring 5 February 20th 04 03:59 AM
bushies file illegal flight plan Gordon Naval Aviation 33 January 13th 04 08:05 PM
bushies file illegal flight plan Bob Dornier Military Aviation 19 December 10th 03 03:29 AM
bushies file illegal flight plan JamesF1110 Naval Aviation 1 December 8th 03 12:06 AM
