Window trimming techniques
Old August 4th 05, 02:35 PM
Jim Burns
Default Window trimming techniques
While our prop is out for some work, we're putting new 1/4" LP Aero side
windows in the Aztec. A couple of the windows need to be trimmed to fit
properly. What methods have proved to be the most successful? Band saw?
cut off wheel? Any others? We need to take about 1/4" to 3/8" off around
two sides so a belt or upright sander won't work, but I intend on finishing
and beveling the edges once the excess is removed. I understand that we
don't want to use anything that will heat the plastic excessively.
Thanks,
Old August 4th 05, 03:00 PM
Bob Noel
The A&P that put in my windows (cherokee 140) used one of those
air-powered rotary grinding things.
Bob Noel
no one likes an educated mule
Old August 4th 05, 03:01 PM
john smith
Sureform tool.
Old August 4th 05, 04:32 PM
Don Tuite
On Thu, 4 Aug 2005 08:35:19 -0500, "Jim Burns"
I just finished working with our mechanic on a replacement windshield
for the 172B we just sold.
He used a rasp -- wouldnt use anything powered. We must have gone
through 40 or 50 iterations. We'd fit the windshield in place, mark
it with a dry-erase market, take it off, and I'd brace it while he
took it down a couple of mils. Over and over. (I'd never have the
patience to be and A&P or build a kitplane.)
When it fit perfectly, he buffed the edges smooth with emery cloth and
applied the felt.
Don
Old August 4th 05, 04:41 PM
pbc76049
Hi Don.
I do plastic for a livng.
Use a 60 grit disc sander to get the
molding to size. After that you can
either scrape or sandthe edges to
a nick free polished state. It doesn't
take but a few minutes to trim plastic this way.
ALSO you can use a SHARPIE brand felt
pen to mark the plastic. All the ink comes
off with alcohol. DON"T use a magic marker
because it won't come off. Red china markers work
well also.
Scott.
Old August 5th 05, 04:48 AM
Jim Burns
Fine toothed band saw worked great, then finished and beveled the edges with
60 grit belt sander.
Old August 18th 05, 03:52 AM
zatatime
Thanks,
I just did my 235 last weekend with the same exact windows. Used a
Dremel with a grinding wheel. Worked like a charm. Then to take out
the slight unevenness I flipped the belt sander upside down and ran
the edge across it once or twice. Bevelled the edge with the Dremel
too.
HTH.
z
Old August 18th 05, 06:35 AM
Jim Burns
Yep, belt sander worked great. Also used a fine toothed blade in a band
saw, finished up with the belt sander.
"zatatime" wrote in message
around
finishing
Thanks,
too.
HTH.
z
Scout/Citabria Window Tom Johnson Soaring 0 October 31st 04 06:35 PM
ISRAELI LINK IN US TORTURE TECHNIQUES MORRIS434 Naval Aviation 0 May 12th 04 05:14 AM
ISRAELI LINK IN US TORTURE TECHNIQUES MORRIS434 Military Aviation 0 May 12th 04 05:13 AM
Undock Window Feature doesn't work Dave Schwartz Simulators 2 January 18th 04 08:51 PM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
