Bleeding brakes on Tripacer
I don't actually own a Tripacer but I do have the landing gear which
is being mounted on my homebuilt. I was painting the landing gear and wheels last weekend, which included sand blasting everything such as the backing plate. I had to remove the brakes and wheel cylinder so that I could do a proper job. As I was re-assembling the stuff, I was struck by what appeared to be the lack of a bleeder screw so that the wheel cylinder could be filled with fluid, when the time comes. There is no bleeder screw with a passage directly into the cylinder, as is the practice in the automotive world, but there is a set screw on top of the threaded portion of the cylinder that fits through the backing plate. At first, I had no idea what this set screw's function was, until I began thinking about how the heck I was going to bleed the brakes. The way the cylinder is designed, there is the cylinder itself, with the two pistons to push on the brake shoes of the drum brakes. Then machined to the cylinder is a threaded arm that sticks through the backing plate. This is snugged to the backing plate by a nut against a lock washer. This leaves a longish threaded part to which another piece is attached. This is threaded onto the threads and to this last piece, the brake line is attached. This second part, is machined to fit the flange of the brake line and accept the threads of the brakeline coupler. On top of this second piece is what appears to be a set screw. It's in the wrong place to be a bleeder valve, but that's the only thing I can think it is. I'm half tempted to drill through the backing plate into the cylinder and tap threads for a real bleeder valve. Can anyone tell me, is that little set screw really intended to be a bleeder valve for the wheel cylinder? If so, I'm going to be tempted to attempt to remove everything on the outside of the backing plate but the wheel cylinder, and squirt brake fluid into the cylinder using a syringe until it's filled, then screw the brakeline attachment fitting on, attach the brakeline and bleed from there. Many thanks, Corky Scott |
Corky Scott wrote in message ... As I was re-assembling the stuff, I was struck by what appeared to be the lack of a bleeder screw so that the wheel cylinder could be filled with fluid, when the time comes. Nope - the screw is to bleed AIR from the system. Fill the master and bleed downwards - just like every other a/c and car/truck/bus......... |
On Thu, 31 Jul 2003 00:51:44 +1000, "RT" wrote:
Corky Scott wrote in message ... As I was re-assembling the stuff, I was struck by what appeared to be the lack of a bleeder screw so that the wheel cylinder could be filled with fluid, when the time comes. Nope - the screw is to bleed AIR from the system. Fill the master and bleed downwards - just like every other a/c and car/truck/bus......... I was an auto mechanic in a former life. I've bled a lot of brake lines and hydraulic systems. In every single auto or truck I've dealt with, there was always a bleeder screw right at the cylinder or caliper, usually at the high point, to facilitate removing air. The wheel cylinder for the Tripacer is unlike anything I've ever seen before and appears intrinsically unable to bleed the cylinder properly as the bleeder is inches away from the cylinder. However, knowing now that that's what it's for, I'm going to take another careful look at the cylinder to make sure that it doesn't have to be mounted in a specific way. Thanks for the information. Corky Scott |
Similar Threads | ||||
oil change on my Tripacer | mike regish | Owning | 2 | June 22nd 04 12:20 AM |
oil change on my Tripacer | mike regish | Owning | 0 | June 19th 04 07:00 PM |
McCaully wheels & brakes available | Roger Long | Owning | 0 | March 4th 04 02:19 PM |
WTB: Pair 500x5 Tires, Wheels, Brakes | Spar | Aviation Marketplace | 0 | February 16th 04 10:13 PM |
Updated information on Tripacer for sale in Durham NC, USA | Lori Fields | General Aviation | 0 | December 9th 03 04:05 PM |
