#11
The gross weight should be in the identification and specs section or page
of the Flight Manual that is specific to your airplane. It should have the serial number of your plane on this page. It should also be listed in your W&B section and may be indicated in the charts as an upper weight limit line. Double check that the charts match the gross weight listed in the specs. On ours, there is also an AD that gives us a "Zero Fuel" weight lower than gross, I believe it's 4400 lbs meaning that with empty tanks we can only load it to 4400 lbs, then the rest has to be fuel up to 5200. Jim "Louis L. Perley III" wrote in message ... "Jim Burns" wrote in message ... Thanks, I'm going to check the service manual for ours tonight to see if it mentions retreads. I ended up with Michelin tires, and like yours, the 8 plys were rated to 2550. My earlier post stating 2250 was slightly dyslexic. Jim Any idea how to determine what the Gross Weight on the aircraft is? I know that Piper made 4400, 4800, and 5200 pound models, and they aren't in any specific serial number ranges as far as I can tell. It would appear that it depended on what was ordered at the time, and I've not seen any list of what the various differences were so that I could make some sort of determination that way. I've been searching, but have not yet been able to determine anywhere what the gross weight is on my airframe. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
I double checked our flight manual and everything below is correct in our
case. The front page lists the N number and serial number then states "for serial numbers 27-2505 and above at 5200 lb gross weight", then the weight and balance section lists all the weights includeing empty weight and usefull load which add up to 5200 lbs. I also checked the service manual dated 1981 and it does not mention retread tires and only lists 8 ply tires for the mains, however lists 4 or 6 plys for the nose, but the nose is a 6 inch tire. Maybe our Service Manual isn't new enough, I'll have to check with our A&P. YMMV Jim "Jim Burns" wrote in message ... The gross weight should be in the identification and specs section or page of the Flight Manual that is specific to your airplane. It should have the serial number of your plane on this page. It should also be listed in your W&B section and may be indicated in the charts as an upper weight limit line. Double check that the charts match the gross weight listed in the specs. On ours, there is also an AD that gives us a "Zero Fuel" weight lower than gross, I believe it's 4400 lbs meaning that with empty tanks we can only load it to 4400 lbs, then the rest has to be fuel up to 5200. Jim "Louis L. Perley III" wrote in message ... "Jim Burns" wrote in message ... Thanks, I'm going to check the service manual for ours tonight to see if it mentions retreads. I ended up with Michelin tires, and like yours, the 8 plys were rated to 2550. My earlier post stating 2250 was slightly dyslexic. Jim Any idea how to determine what the Gross Weight on the aircraft is? I know that Piper made 4400, 4800, and 5200 pound models, and they aren't in any specific serial number ranges as far as I can tell. It would appear that it depended on what was ordered at the time, and I've not seen any list of what the various differences were so that I could make some sort of determination that way. I've been searching, but have not yet been able to determine anywhere what the gross weight is on my airframe. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
I've been searching, but have not yet been able to determine anywhere what the gross weight is on my airframe. Maybe I'm reading this wrong, but doesn't your W&B documentation list the gross weight? How else could you load it properly? John Galban=====N4BQ (PA28-180) |
I've been searching, but have not yet been able to determine anywhere what the gross weight is on my airframe. One of the documents required to be in the aircraft is the weight and balance sheet. I have usually found it in the pilot's operating handbook, which must have records pertaining specifically to your airplane. |
Elwood Dowd wrote: I've been searching, but have not yet been able to determine anywhere what the gross weight is on my airframe. One of the documents required to be in the aircraft is the weight and balance sheet. I have usually found it in the pilot's operating handbook, which must have records pertaining specifically to your airplane. As has been extensively discussed in another current thread, there's no requirement that the W&B be in the aircraft, and older planes will not have a POH. In fact, newer planes won't either -- they have AFMs instead. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
"Jim Burns" wrote: Annual report is coming soon. I was told by my mechanic that retread tires are not allowed in my Aztec according to the manual. They actually thought that this was generally the case with all retractable gear aircraft. In light of this, I am putting new tires on the mains. My aircraft also allows for either 7.00 x 6 in 6 or 8 ply, which I thought was interesting. I'll be putting on the 8 ply just to be safe (and the price isn't all that much different either) I see you've got a 1965 Aztec, I don't know what the gross weight is, but our '66 can't use the 6 plys because they are only rated at 1900 lbs each, or 3800 lbs total, the 8 plys are rated at 2250 each, 4500 lbs total. As far as all retractable gear aircraft not being able to use retreads, that's a myth as most retractable gear airplanes actually do use retreads ie. the airlines. There is an FAA AC that advises when installing retreads on retractable gear planes to do a gear swing and make sure they fit in the wells and to be carefull that the sidewalls do not overswell do to heat build up on take off runs. There is no mention of retread tires in our POH or in the manual for the Cessna R182 we flew. We still haven't found any retreads and have ordered new tires which will provide us with good cases for future retreading. I would recommend swinging the gear *every* time you change the tires. I once bought a pair of 6.00x6 McRearys for my Johnson Rocket. One tire would not fit inside one well but fit in the other. The other tire fit inside both wells. I have used Thompson's retreads successfully -- it is partly a matter of the case. |
Similar Threads | ||||
Sources for retread tires?? | Jim Burns | Aviation Marketplace | 15 | November 24th 04 03:48 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Owning | 0 | March 20th 04 04:48 AM |
Tailwheel tires | Dan Thomas | Owning | 10 | November 26th 03 02:53 PM |
12.5-4.5 TIRES ??? | jetflow | Owning | 2 | November 25th 03 04:27 PM |
Changing *BIG* Aircraft Tires [Was Coalition casualties forseptember] | Stephen Harding | Military Aviation | 9 | October 5th 03 06:42 PM |
