Continental E-225-4 question
Rip wrote:
Jim, sadly there is no mogas STC for the Navion, with any engine. Rip Yep, I even talked to Petersen about this (the EAA doesn't touch 6 cyls). All they knew was they had tested it and it had failed the vapor lock test. They couldn't remember which engine, fuel system, or model Navion they had used. |
Most if not all Mogas today has Methanol in it as a replacement for
the oxygenation agent MTBE. Gas pumps are not typically labled as to alcohol content. Both Petersen and EAA autogas STC's are not valid with autofuels containing alcohol. At a recent IA seminar held by the FAA we were reminded that even with an autogas STC if an airplane is operated using a fuel containing any alcohol that the airplane would be considered by them to be "unairworthy". Unairworthy to the FAA also means uninsured to most aviation underwriters. So you won't have a problem until you have a problem! Methanol is hydroscopic which means it holds water. This water will, over time, rust the steel parts in the fuel system. Gary Plewa On May 31, 6:42 am, Ron Natalie wrote: Rip wrote: Jim, sadly there is no mogas STC for the Navion, with any engine. Rip Yep, I even talked to Petersen about this (the EAA doesn't touch 6 cyls). All they knew was they had tested it and it had failed the vapor lock test. They couldn't remember which engine, fuel system, or model Navion they had used. |
Thanks - did you notice the thread titled Gasohol? That cites a document and
others have concurred that there are some states now where you can not buy Methanol free fuel. Back to the 100LL it seems...and think about all those mogas STCs that have just become invalid. -- Jim Carter Rogers, Arkansas "Gary" wrote in message oups.com... Most if not all Mogas today has Methanol in it as a replacement for the oxygenation agent MTBE. Gas pumps are not typically labled as to alcohol content. Both Petersen and EAA autogas STC's are not valid with autofuels containing alcohol. At a recent IA seminar held by the FAA we were reminded that even with an autogas STC if an airplane is operated using a fuel containing any alcohol that the airplane would be considered by them to be "unairworthy". Unairworthy to the FAA also means uninsured to most aviation underwriters. So you won't have a problem until you have a problem! Methanol is hydroscopic which means it holds water. This water will, over time, rust the steel parts in the fuel system. Gary Plewa On May 31, 6:42 am, Ron Natalie wrote: Rip wrote: Jim, sadly there is no mogas STC for the Navion, with any engine. Rip Yep, I even talked to Petersen about this (the EAA doesn't touch 6 cyls). All they knew was they had tested it and it had failed the vapor lock test. They couldn't remember which engine, fuel system, or model Navion they had used. |
Gary wrote:
Most if not all Mogas today has Methanol in it as a replacement for the oxygenation agent MTBE. Gas pumps are not typically labled as to alcohol content. Both Petersen and EAA autogas STC's are not valid with autofuels containing alcohol. At a recent IA seminar held by the FAA we were reminded that even with an autogas STC if an airplane is operated using a fuel containing any alcohol that the airplane would be considered by them to be "unairworthy". Unairworthy to the FAA also means uninsured to most aviation underwriters. So you won't have a problem until you have a problem! Methanol is hydroscopic which means it holds water. This water will, over time, rust the steel parts in the fuel system. I do the water test on every every tank I put in the plane. So far here in central northern Oregon I can get alcohol-free gas. Don't know how long it will last, though. Also I will shortly be moving to Idaho and have no idea what is available there. So, sadly, I agree that the life of the mogas STC is limited. -- Frank Stutzman Bonanza N494B "Hula Girl" Hood River, OR (soon to be Boise, ID) |
In article .com,
Gary wrote: Most if not all Mogas today has Methanol in it as a replacement for the oxygenation agent MTBE. Gas pumps are not typically labled as to alcohol content. Both Petersen and EAA autogas STC's are not valid with autofuels containing alcohol. At a recent IA seminar held by the FAA we were reminded that even with an autogas STC if an airplane is operated using a fuel containing any alcohol that the airplane would be considered by them to be "unairworthy". Unairworthy to the FAA also means uninsured to most aviation underwriters. So you won't have a problem until you have a problem! Methanol is hydroscopic which means it holds water. This water will, over time, rust the steel parts in the fuel system. Gary Plewa Gary, You are confusing methanol with ethanol. Neither is approved for aviation fuel usage. Both are hydroscopic -- methanol more than ethanol. Both have materials incompatibilities. Both increase fuel consumption and reduce power. Ethanol is the alcohol of choice (Per Archer-Daniels Midland) for gasohol. It is also the stuff you drink. Methanol will destroy your eyes. |
Gary, You are confusing methanol with ethanol. Neither is approved for aviation fuel usage. Both are hydroscopic -- methanol more than ethanol. Both have materials incompatibilities. Both increase fuel consumption and reduce power. Ethanol is the alcohol of choice (Per Archer-Daniels Midland) for gasohol. It is also the stuff you drink. Methanol will destroy your eyes. Yup, you are absolutely right. After I hit the return key I realized my mistake. Grain alcohol (i.e. moonshine) is used in Gasoline, hence the increase in corn prices. Not denatured alcohol (e.g. Methanol). |
Gary wrote:
Yup, you are absolutely right. After I hit the return key I realized my mistake. Grain alcohol (i.e. moonshine) is used in Gasoline, hence the increase in corn prices. Not denatured alcohol (e.g. Methanol). Methanol is not the same as denatured alcohol, either. Denatured alcohol is ethanol that has been intentionally contaminated with methanol. |
Similar Threads | ||||
Question about wings on Continental Airlines plane? | [email protected] | Piloting | 5 | December 13th 06 02:50 AM |
Continental 757 18R @ MCO | Glen in Orlando | Aviation Photos | 4 | November 30th 06 03:15 AM |
Continental O-200 ? | Stealth Pilot | Home Built | 48 | September 23rd 06 06:32 PM |
Continental 0-200 | Robert | Home Built | 0 | August 31st 05 11:57 AM |
Continental IO-360 question | Jeff P | Owning | 0 | September 21st 03 08:03 PM |
