Engine Baffling Supplier
As the 74 Cherokee ages, the engine baffling (0-320 E3D) is starting to
show its age. Various places have been stop drilled over the years and it is time for replacement. I really don't want used salvage parts because they are likely in the same condition as what I have. The intercylinder baffles and hooks appear to be Lycoming manufactured hardware and ECI makes inexpensive replacements. Those don't need replacing (readily available, reasonably priced PMA alternatives - of COURSE you don't need THOSE). However, the outer shrouding that needs replacing appears to be Piper designed/supplied. Where can you get this stuff new so that the 2-3 pieces I need won't cost as much as a new engine? 1 piece from the DesMoines Flight Service database lists for $885.00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! Any sources? Thanks, Mike |
Mike Spera wrote: However, the outer shrouding that needs replacing appears to be Piper designed/supplied. Where can you get this stuff new so that the 2-3 pieces I need won't cost as much as a new engine? 1 piece from the DesMoines Flight Service database lists for $885.00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! Is there enough of it left that you can fabricate it yourself (using acceptable materials and methods)? When I overhauled my 140, the A&Ps had me make some replacement parts for the baffling. -- Bob Noel (goodness, please trim replies!!!) |
Is there enough of it left that you can fabricate it yourself (using acceptable materials and methods)? Actually, Most of it is fine. I just have a couple of pieces that have cracked here and there. I suppose I could just fabricate some repair pieces in a pinch. I was just wondering if there was a source for new ones that I had not heard of. Thanks, Mike |
"Mike Spera" wrote in message ... As the 74 Cherokee ages, the engine baffling (0-320 E3D) is starting to show its age. Various places have been stop drilled over the years and it is time for replacement. I really don't want used salvage parts because they are likely in the same condition as what I have. The intercylinder baffles and hooks appear to be Lycoming manufactured hardware and ECI makes inexpensive replacements. Those don't need replacing (readily available, reasonably priced PMA alternatives - of COURSE you don't need THOSE). However, the outer shrouding that needs replacing appears to be Piper designed/supplied. Where can you get this stuff new so that the 2-3 pieces I need won't cost as much as a new engine? 1 piece from the DesMoines Flight Service database lists for $885.00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! Any sources? Thanks, Mike Find an RV builder in your area and look at the baffles in his/her airplane. The entire baffle "kit" is roughly $200. My guess is that you could make the parts fit and could claim them as owner fabricated replacement parts. KB |
On Jan 21, 6:43*pm, "Kyle Boatright" wrote:
"Mike Spera" wrote in message ... As the 74 Cherokee ages, the engine baffling (0-320 E3D) is starting to show its age. Various places have been stop drilled over the years and it is time for replacement. I really don't want used salvage parts because they are likely in the same condition as what I have. The intercylinder baffles and hooks appear to be Lycoming manufactured hardware and ECI makes inexpensive replacements. Those don't need replacing (readily available, reasonably priced PMA alternatives - of COURSE you don't need THOSE). However, the outer shrouding that needs replacing appears to be Piper designed/supplied. Where can you get this stuff new so that the 2-3 pieces I need won't cost as much as a new engine? 1 piece from the DesMoines Flight Service database lists for $885.00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! Any sources? Thanks, Mike Find an RV builder in your area and look at the baffles in his/her airplane. The entire baffle "kit" is roughly $200. My guess is that you could make the parts fit and could claim them as owner fabricated replacement parts. KB- Hide quoted text - - Show quoted text - Claim, schmame - IRAN - make the needed "repairs" and install... Each separate piece is simply a repair of the baffling system... Needs only the barest of mentions by the A&I... Fat Albert is going to get an engine overhaul (when crusty old mechanic gets a round tuit)... Also planned is IRAN the baffles... They will be gorgeous when done... denny denny |
Find an RV builder in your area and look at the baffles in his/her airplane. The entire baffle "kit" is roughly $200. My guess is that you could make the parts fit and could claim them as owner fabricated replacement parts. KB Owner fabricated parts doesn't give you license to make the part however you want to make it. Owner fabricated parts still have to meet the original type certificate. That means either working from drawings or reverse engineering the existing, making sure you match not only the materials but also any manufacturing process that may alter the material properties, e.g. heat treating. The final part must still be a faithful duplicate of the part you are replacing. All the owner fabrication rule does is get you around having a PMA approval on the part. |
"Ray Andraka" wrote in message ... Find an RV builder in your area and look at the baffles in his/her airplane. The entire baffle "kit" is roughly $200. My guess is that you could make the parts fit and could claim them as owner fabricated replacement parts. KB Owner fabricated parts doesn't give you license to make the part however you want to make it. Owner fabricated parts still have to meet the original type certificate. That means either working from drawings or reverse engineering the existing, making sure you match not only the materials but also any manufacturing process that may alter the material properties, e.g. heat treating. The final part must still be a faithful duplicate of the part you are replacing. All the owner fabrication rule does is get you around having a PMA approval on the part. My point, perhaps not communicated well, was that the Original Poster might be able to buy Van's baffle kit and use it as a starting point. I'd guess that Van's baffle kit is a very close match to anything supplied by Cessna, Beech, Piper, etc. for a similar engine. Beats the heck out of starting from scratch. Beyond that, we're talking baffles, not having the OP machine new connecting rods for his engine. Baffles are pretty simple and the OP should be able to make a determination as to whether the kit part would or wouldn't work. KB |
Similar Threads | ||||
Fiberglass Wheel Pants Supplier? | JB | Owning | 1 | October 19th 04 04:28 AM |
need link for SS rivet supplier | Charles S | Home Built | 1 | May 9th 04 02:34 AM |
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? | jls | Home Built | 3 | February 3rd 04 12:15 AM |
Amsteel Blue Supplier | Sweeny | Soaring | 1 | October 31st 03 12:46 PM |
ADV: MIle High supplier | David Campbell | Soaring | 0 | August 7th 03 02:16 AM |
