Blood Oxygen level question.
Old January 26th 07, 05:09 PM posted to rec.aviation.soaring
Udo
Default Blood Oxygen level question.
How long does it take for the blood oxygen level to normalize at 15000
ft, after one discovers the flow meter was not adjusted correctly?
Also at what altitude does Oxygen become beneficial, assuming an
average person? Are there any factors, other then altitude it self,
that can lower Blood oxygen level during flight assuming supplemental
oxygen is not used between 5000 and 10000 ft and the pilot has a normal
cardio vascular health? What oxygen level is considered optimum at sea
level and 10000ft to 15000ft?
Udo
Old January 26th 07, 06:14 PM posted to rec.aviation.soaring
Mike[_8_]
Udo,
I found the following helpful when looking for answers and solutions.
http://www.aeromedix.com/aeromedix/a...eox/index.html
Mike
Udo
Old January 26th 07, 06:28 PM posted to rec.aviation.soaring
nimbus
I am also looking for the following information:
Oxygen consumption in function of altitude, age of pilot.
The objective is to determine when I have to go down when I see a
specific oxygen pressure in my bottle.
Many thanks for any help.
Bruno
On 26 jan, 19:14, "Mike" wrote:
Udo,
Mike
Udo
Old January 26th 07, 07:02 PM posted to rec.aviation.soaring
Craig
My experience with a pulse oxymeter in an altitude chamber was that
blood oxygen levels responds very quickly to changes in available
oxygen. This was reinforced by the instructor also. Just breathing
once or twice from the mouth while using a cannula will reduce blood
oxygen, but it recovers quickly when breathing through the nose
resumes.
The altitude chamber instructor cited loss of visual acuity and night
vision over 5,000 ft. and also emphasized that prior exposure to even
very small amounts of carbon monoxide prior to or during flight
significantly reduces blood oxygen due to COs much higher affinity for
hemoglobin.
Best regards,
Craig
Old January 26th 07, 08:00 PM posted to rec.aviation.soaring
Shawn
Seconds really if you start sufficient flow. The body is good at
getting O2 into the blood. However side effects may linger (e.g. headache).
average person?
Average? A 55 kg 26 year old female who walks 10 miles every day would
be a good baseline for an average healthy human YMMV :-)
*Your* best bet is to buy a pulse oximeter (e.g. Nonin 9500) available
for less than 200 USD these days, check your resting pO2, then go fly.
Go on O2 and titrate it accordingly to maintain that normal oxygen level.
As altitude increases, the kidneys dump water (altitude diuresis). The
problems associated with dehydration are being discussed (or ignored) in
other threads, so avoid one cause of the problem and keep the O2 on.
As for what level of saturation is optimum, why let it drop any below
normal resting?
Shawn
Old January 26th 07, 09:06 PM posted to rec.aviation.soaring
HL Falbaum
We can get very scientific here, but why?
Oxygen is cheap--get a pulseox and use it ia few times, then spot check.
Sometimes the flowmeters are "off" a bit.
If you must conserve, due to lack of supply, then aim for a pO2 of greater
than 90.
If it is necessary to conserve often, then get a bigger supply, or be more
efficient, such as a EDS (medical equivalent is a CPAP)--
Hartley Falbaum
"Shawn" wrote in message
Seconds really if you start sufficient flow. The body is good at getting
average person?
Average? A 55 kg 26 year old female who walks 10 miles every day would be
*Your* best bet is to buy a pulse oximeter (e.g. Nonin 9500) available for
less than 200 USD these days, check your resting pO2, then go fly. Go on
normal resting?
Shawn
Old January 26th 07, 10:27 PM posted to rec.aviation.soaring
Shawn
I used to work in a hemoglobin research lab and my wife is a science
geek M.D. I could bore you to tears. :-)
than 90.
CPAP is something else, for treating breathing problems during sleep.
Hopefully you won't need one of those flying!
Shawn
Old January 26th 07, 11:07 PM posted to rec.aviation.soaring
HL Falbaum
I used to work in a hemoglobin research lab and my wife is a science geek
greater than 90.
more efficient, such as a EDS (medical equivalent is a CPAP)--
Shawn
My apologies to the group--I re-read my post and must correct an error--
I know the difference between pO2 and SaO2. My "90" number is SaO2, of
course. This is the number you get from your pulseox meter.
Major brain disconnect on the CPAP
Sorry
Hartley Falbaum
Old January 26th 07, 11:23 PM posted to rec.aviation.soaring
raulb
I recently spent A LOT of time in the hospital on oxygen 24/7. It was
found that if, when I was active (exercise) and my blood ox level went
down to 80-85 or so, sitting for a minute or so on the oxygen (2
liters/minute) and it would be back up to around 96--and this was with
a partially collapsed lung. It was, however, also at about 200 ft MSL
and not at 15k.
Udo
Old January 27th 07, 12:51 AM posted to rec.aviation.soaring
Richard[_1_]
Udo
O2 Concentrator instead of O2 tank tom Piloting 96 December 7th 06 07:22 PM
Medal Winners: Air Traffic Control Tapes Montblack Home Built 89 February 9th 06 03:25 PM
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
