Best 3 antennae combo for PowerFLARM?
Old April 13th 19, 07:33 PM posted to rec.aviation.soaring
Default Best 3 antennae combo for PowerFLARM?
Going to try dual Craggy Aero 1/2 wave antennas on FLARM 1 and FLARM 2 mounted on both canopy rails just in front of the vent window.
If you are running FLARM 1 and FLARM 2 antennae, where did you mounted the 3rd FLARM short diapole ADS-B antennae?
I find many aftermarket 916MHz PowerFLARM antennae but no aftermarket PowerFLARM ADS-B antennae tuned to 1090MHz. Besides the stock PowerFLARM ADS-B dipole, are there other 1090MHz ADS-B antennae worth considering?
How about it Richard @ Craggy Aero?
Old April 13th 19, 08:53 PM posted to rec.aviation.soaring
JS[_5_]
I've been using Craggy's 500107 on the glare shield, and no B antenna.
1/4 wave antenna high performance with a slim profile. It operates at 916MHz. The overall antenna length is 2 7/8-inches (73mm). It features a bulkhead mount, flexible whip and, cable to PowerFlarm A or B with 4" square ground plane.
Looks much less ghastly than the dipole antenna and works very well.
Installed with ground plane velcroed to the underside so it's easy to remove the canopy or tear away if needed.
5Z and I checked range last Sunday, were fine with both our installs.
ADS-B reception is fine with the stock dipole antenna below the glare shield.
Personally don't care to see or hear about Mode C.
Old April 13th 19, 08:55 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Recall that the FLARM antenna tuning is much more critical since FLARM transmitted power is 0.010 watts (Portable) and 0.018 watts (CORE), and the transmitted power of transponders is 150 or 250 watts (Becker ad). The stock Mode C/S/ADS-B antenna works great with ranges beyond anything you'd ever want to display.
Old April 14th 19, 12:59 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
The same antenna as FLARM A & B with a different connector works well with the ADS-B IN, event thought it is tuned to 916.
Richard
www.craggyaero.com
Old April 14th 19, 01:01 AM posted to rec.aviation.soaring
I mount Flarm A on the top of the instrument panel and the Flarm B and ADS-B in the nose on opposite sides.
Richard
www.craggyaero.com
Old April 15th 19, 02:57 AM posted to rec.aviation.soaring
Richard
www.craggyaero.com
If your glider doesn't have metal or carbon fiber, seems like the big obstacle to the radio waves is the pilot's body. Would it make sense to mount one (FLARM) antenna in front of the pilot and the other (FLARM) one behind?
VOR Antennae Installation guynoir Home Built 1 November 8th 06 03:37 AM
FS Cambridge L-NAV and GPS-NAV combo [email protected] Soaring 2 October 15th 06 03:16 PM
Pitot tube for the antennae Ernest Christley Home Built 12 May 29th 06 05:05 AM
Which antennae please? Robert Loer Home Built 1 October 27th 04 11:55 PM
WTB Looking for a used EGT/CHT combo [email protected] Aviation Marketplace 0 August 29th 04 08:16 PM
