orange red nose color
Old July 29th 14, 06:33 AM posted to rec.aviation.soaring
Andrew[_13_]
Default orange red nose color
SH uses RAL colors, using a 2-component urethane-acrylic paint
(paint and hardener) which really needs to be applied professionally
e.g. by a dealer (its toxic). This produces a very durable paint job,
and probably this is the way to go for any large paint areas. For
touch up of small areas, the same RAL colors are available in the USA
as single-component acrylic spay cans, and these can be applied by
anyone. If its not clear which RAL code you have from your aircraft
manual, SH should be able to tell you the RAL code they used. I
found minor scratches on my Ventus paint (5 years from the SH
factory) were perfectly matched with a single-component acrylic
spray can of the same RAL code. I got a spray can from
artprimo.com. Before that, I had tried a lot of local automotive
suppliers, but they didn't seem to be aware of RAL color codes, and I
really didn't get much help from them, except an occasional offer to
special-order much larger quantities than I needed.
At 00:56 29 July 2014, Ron Gleason wrote:
On Monday, 28 July 2014 12:31:59 UTC-6, Peter Scholz wrote:
Am 28.07.2014 16:13, HGXC wrote:
On Sunday, July 27, 2014 8:44:50 PM UTC-4,
On Sunday, July 27, 2014 5:58:30 AM UTC-5, HGXC wrote:
I have a early Ventus and it came with a orange/red nose
and tip
paint. Where can I find the matching color of that paint? I have a
few
scrapes that I want to touch up.
Dennis
The color is probably an RAL color. Perhaps 3024. It is a
european
color system. Check with auto paint suppliers.
I see the 3024, was this a guess or did you know someone who
had a
ventus or SH glider?
Dennis
Be aware that those colours fade out in sunlight, so touching up
with
"fresh" colour might be detectable for a few years. I would
consider
repainting the whole nose/wingtip instead.
Peter Scholz
ASW24 JE
Dennis, the maintenance manual for my Ventus 2CX states
Orange - (RAL-Code No. 2004) or Red (RAL-Code No. 3000 or
3024)
This is a 2004 manual
Old July 29th 14, 02:13 PM posted to rec.aviation.soaring
HGXC[_2_]
and tip
few
Dennis
european
had a
Dennis
with
consider
Peter Scholz
ASW24 JE
3024)
Thanks Ron, (nice glider!), My manual is 1981 and does not mention any paint that i can find. I looked at the RAL colors and I think the 3024 looks right or closer then the others. I got a call to the US dealer. IF anyone has a older Ventus in the 80's and can find the color in the manual, that would be great.
Dennis
!|!|!|!|::::: Annoying Orange Genitals :::::|!|!|!|! Annoying Orange Genitals Owning 0 March 23rd 11 09:35 AM
Color P-38 Nose Art Hub Plott III Aviation Photos 0 August 10th 07 08:35 PM
"orange peel" and dope Michael Horowitz Home Built 3 June 17th 05 03:40 AM
Near-miss over Orange County, Calif 6/30 8:08 pm? HBYardSale General Aviation 4 July 13th 03 02:03 PM
