PW-5 Brake Cable Replacement
To All,
The brake on our PW-5 has failed. The brake cable end that attaches to the hand brake handle came loose from the handle. The cable was attached to a pin that fits into the brake handle. The steel pin is retained in the brake handle by a snap ring. The pin was evidently soldered or welded onto the steel cable. Has anyone experienced such a failure? If so, how did you go about replacing and installing the cable? We have purchased a replacement cable from Poland but it arrived with only a single swagged ball at one end. Trying to weld or solder the existing pin onto the new cable seems to be a very risky proposition. Any help will be greatly appreciated. Charley |
On Thursday, July 31, 2014 8:44:24 AM UTC-6, wrote:
To All, The brake on our PW-5 has failed. The brake cable end that attaches to the hand brake handle came loose from the handle. The cable was attached to a pin that fits into the brake handle. The steel pin is retained in the brake handle by a snap ring. The pin was evidently soldered or welded onto the steel cable. Has anyone experienced such a failure? If so, how did you go about replacing and installing the cable? We have purchased a replacement cable from Poland but it arrived with only a single swagged ball at one end. Trying to weld or solder the existing pin onto the new cable seems to be a very risky proposition. Any help will be greatly appreciated. Charley Likely to be some form of a motorcycle brake or clutch cable. Best to find an old fashion motorcycle shop and see if they can find or make a cable for you. The newer shops only know how to look up part number so are not much help. |
Similar Threads | ||||
G102 Club III Brake replacement | Hartley Falbaum | Soaring | 1 | June 7th 12 07:36 PM |
Blanik L-13 elevator cable replacement | Brad[_5_] | Soaring | 7 | April 24th 10 06:56 PM |
Pilatus B-4 Wheel Brake Cable | thermalrider | Soaring | 2 | January 28th 06 11:12 PM |
Prop Cable - Replacement Needed | zatatime | Owning | 0 | May 7th 04 04:37 PM |
Nimbus 3 25.5 tip spoiler cable replacement | tango4 | Soaring | 0 | May 3rd 04 09:05 PM |
