Aircraft Recovery Dolly
These?
http://www.harborfreight.com/cpi/cta...emnumber=93368 "Jay Masino" wrote in message ... Here's a design that I've been mulling over. Since I don't have the ability to weld something up, I was considering a double thickness of 3/4" pressure treated plywood. If you can get a 2' x 4' piece, then cut it in half and glue/screw the two together to get a 2' x 2' slab of plywood that's 1 1/2" thick. Then mount 4 of something like these: http://www.northerntool.com/webapp/w...029422_1029422 using through-bolts, fender washers and locknuts. You'd get approx 1200' capacity with not too much cost. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Similar Threads | ||||
LS4 tail dolly | Leigh | Soaring | 0 | May 30th 08 02:02 AM |
ASK-21 - is a tail dolly necessary? | Dave Springford | Soaring | 7 | December 31st 07 08:43 AM |
FS: ASW-24 Tail Dolly | [email protected] | Soaring | 0 | December 26th 06 02:40 PM |
WTB: used tail dolly | David Campbell | Soaring | 5 | April 17th 06 03:19 PM |
assembly dolly | Udo Rumpf | Soaring | 0 | April 29th 05 04:17 PM |
